02-13-2009, 06:58 | #1 (permalink) |
Freak Poster Join Date: Apr 2007 Location: in ur heart
Member: 481933 Status: Offline Sonork: 100.1582701 Thanks Meter: 107 | Strange problem after gdfs repir by testpoint ONE MORE THING WHEN I CONNECT USB CABLE TO HANDSET IT DETECT THE HANDSET AS A USB FALSH DEVICE. I CONFUSE ABT THIS WHAT IS THE PROBLEM SOMEBUDY HELP ME ABT THIS & THANKS IN ADVANCE HEER I POST ALL LOGS FOR THIS HANDSET DURING GDFS REPIR TP STAGE 1 & 2 LOGS 2/12/2009 8:37:26 PM TESTPOINT REPAIR STAGE #1 STARTED 2/12/2009 8:37:26 PM Open COM port OK 2/12/2009 8:37:28 PM ChipID:9900,EMP protocol:0301 2/12/2009 8:37:28 PM Speed:921600 2/12/2009 8:37:29 PM OTP: LOCKED:1 CID:49 PAF:1 IMEI:35306601453106 CERT:N/A 2/12/2009 8:37:29 PM FLASH CID:52 COLOR:RED 2/12/2009 8:37:30 PM LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 2/12/2009 8:37:30 PM PREPARING... 2/12/2009 8:37:37 PM ATTACH TP #1 AND PRESS "READY" 2/12/2009 8:38:16 PM RELEASE TP #1 AND PRESS "READY" 2/12/2009 8:38:34 PM TP #1 LOOKS OKAY 2/12/2009 8:38:42 PM DONE 2/12/2009 8:38:42 PM Elapsed: 76 secs. 2/12/2009 8:38:54 PM TESTPOINT REPAIR STAGE #2 STARTED 2/12/2009 8:38:54 PM Open COM port OK 2/12/2009 8:38:54 PM ChipID:9900,EMP protocol:0301 2/12/2009 8:38:54 PM Speed:921600 2/12/2009 8:38:55 PM ATTACH TP #2 AND PRESS "READY" 2/12/2009 8:39:23 PM Trying to launch embedded bootloader... 2/12/2009 8:39:39 PM PROCEDURE WAS STOPPED BY USER 2/12/2009 8:39:39 PM TP #2 INCORRECT OR STAGE #1 NOT EXECUTED 2/12/2009 8:39:40 PM Elapsed: 45 secs. 2/12/2009 8:39:47 PM TESTPOINT REPAIR STAGE #2 STARTED 2/12/2009 8:39:47 PM Open COM port OK 2/12/2009 8:40:03 PM ChipID:9900,EMP protocol:0301 2/12/2009 8:40:03 PM Speed:921600 2/12/2009 8:40:04 PM ATTACH TP #2 AND PRESS "READY" 2/12/2009 8:40:18 PM Trying to launch embedded bootloader... 2/12/2009 8:40:18 PM TP #2 LOOKS OKAY 2/12/2009 8:40:18 PM RELEASE TP #2 AND PRESS "READY" 2/12/2009 8:40:23 PM INT LDRB2020_PRELOADER_FOR_SETOOL2 2/12/2009 8:40:26 PM WRITING EROM... 2/12/2009 8:40:29 PM DONE 2/12/2009 8:40:29 PM Elapsed: 42 secs. GDFS & EROM WRITING LOG 2/12/2009 8:40:29 PM Elapsed: 42 secs. 2/12/2009 8:41:48 PM Open COM port OK 2/12/2009 8:41:54 PM ChipID:9900,EMP protocol:0301 2/12/2009 8:41:54 PM Speed:921600 2/12/2009 8:41:55 PM OTP: LOCKED:1 CID:49 PAF:1 IMEI:35306601453106 CERT:N/A 2/12/2009 8:41:55 PM FLASH CID:49 COLOR:BROWN 2/12/2009 8:41:57 PM LDR:060721 1021 DB2020_SERVICE_LOADER 2/12/2009 8:41:57 PM Flash ID check:897E 2/12/2009 8:41:57 PM Flash props sent ok 2/12/2009 8:41:57 PM writing "E:\boxes\se tool\v0.915033\gdfs_in_ssw_format\db2020\W710_GDFS _SSW.ssw" 2/12/2009 8:41:58 PM CURRENT FLASH FILE CID:49 2/12/2009 8:41:58 PM SSW uses full hash, hash len is:640 2/12/2009 8:41:58 PM Will flash 32 blocks... 2/12/2009 8:42:32 PM SSW loading returns:0 2/12/2009 8:42:33 PM Setting up GDFS... 2/12/2009 8:42:33 PM OTP WRITE NOT EXECUTED 2/12/2009 8:42:33 PM WRITING CLEAR SIMLOCK UNITS... 2/12/2009 8:42:33 PM ALL UNLOCK/LOCK CODES SET TO "71540268" 2/12/2009 8:42:35 PM SIGNING... 2/12/2009 8:42:37 PM Elapsed: 49 secs. 2/12/2009 8:46:52 PM Open COM port OK 2/12/2009 8:46:57 PM ChipID:9900,EMP protocol:0301 2/12/2009 8:46:57 PM Speed:921600 2/12/2009 8:46:58 PM OTP: LOCKED:1 CID:49 PAF:1 IMEI:35306601453106 CERT:N/A 2/12/2009 8:46:58 PM FLASH CID:49 COLOR:BROWN 2/12/2009 8:47:00 PM LDR:060721 1021 DB2020_SERVICE_LOADER 2/12/2009 8:47:00 PM Flash ID check:897E 2/12/2009 8:47:00 PM Flash props sent ok 2/12/2009 8:47:00 PM writing "E:\boxes\se tool\v0.915033\eroms\db2020\DB2020EROM_CNV_RED52_B ROWN_CID49_DB2020.ssw" 2/12/2009 8:47:01 PM CURRENT FLASH FILE CID:49 2/12/2009 8:47:01 PM SSW uses full hash, hash len is:40 2/12/2009 8:47:01 PM Will flash 2 blocks... 2/12/2009 8:47:04 PM SSW loading returns:0 2/12/2009 8:47:04 PM Setting up GDFS... 2/12/2009 8:47:05 PM OTP WRITE NOT EXECUTED 2/12/2009 8:47:05 PM WRITING CLEAR SIMLOCK UNITS... 2/12/2009 8:47:05 PM ALL UNLOCK/LOCK CODES SET TO "01500004" 2/12/2009 8:47:06 PM SIGNING... 2/12/2009 8:47:09 PM Elapsed: 16 secs. 2/12/2009 8:47:16 PM SIGNED MODE (USING SERVER) 2/12/2009 8:47:16 PM ALTERNATIVE SECURITY BYPASS ENABLED. 2/12/2009 8:47:16 PM Open COM port OK 2/12/2009 8:47:21 PM ChipID:9900,EMP protocol:0301 2/12/2009 8:47:21 PM Speed:921600 2/12/2009 8:47:21 PM Flash ID check:897E 2/12/2009 8:47:21 PM Flash props sent ok 2/12/2009 8:47:21 PM OTP: LOCKED:1 CID:49 PAF:1 IMEI:35306601453106 CERT:N/A 2/12/2009 8:47:22 PM FLASH CID:52 COLOR:RED 2/12/2009 8:47:23 PM 2/12/2009 8:47:23 PM Model:W710i 2/12/2009 8:47:23 PM Brand:Generic Trade 2/12/2009 8:47:23 PM MAPP CXC article: R1JC002 prgCXC1250433_NAM_1_CH 2/12/2009 8:47:23 PM MAPP CXC version: R1JC002 2/12/2009 8:47:23 PM Language Package:AMERICA_2 2/12/2009 8:47:23 PM CDA article: CDA102566/49 2/12/2009 8:47:23 PM CDA version: R4A 2/12/2009 8:47:23 PM Default article: cxc1250441 2/12/2009 8:47:23 PM Default version: R1JC002 2/12/2009 8:47:23 PM PROVIDER: 000-00 2/12/2009 8:47:23 PM SIMLOCKS NOT DETECTED 2/12/2009 8:47:23 PM 2/12/2009 8:47:23 PM RESTORATION FILE NOT PRESENT 2/12/2009 8:47:23 PM "R1JC002_CXC1250433_NAM_1_CH" 2/12/2009 8:47:23 PM YOU MUST PERFORM FULL FLASHING 2/12/2009 8:47:23 PM WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED 2/12/2009 8:47:23 PM 2/12/2009 8:47:23 PM BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE HERE IS FLASHING LOG 2/12/2009 8:54:34 PM v0.915033/UNI 2/12/2009 8:54:34 PM CARD SERIAL: 00013029 2/12/2009 8:54:34 PM Loaded 51 flash descriptors 2/12/2009 8:54:57 PM SIGNED MODE (USING SERVER) 2/12/2009 8:55:06 PM ChipID:9900,EMP protocol:0301 2/12/2009 8:55:06 PM 2/12/2009 8:55:06 PM PHONE STATE: "RETAIL" 2/12/2009 8:55:06 PM FLASH CID: 0052 2/12/2009 8:55:06 PM Speed:921600 2/12/2009 8:55:07 PM OTP: LOCKED:1 CID:49 PAF:1 IMEI:35306601453106 CERT:RED 2/12/2009 8:55:07 PM FLASH CID:52 COLOR:RED 2/12/2009 8:55:08 PM PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 2/12/2009 8:55:09 PM LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 2/12/2009 8:55:09 PM Flash ID check:897E 2/12/2009 8:55:09 PM Flash props sent ok 2/12/2009 8:55:09 PM writing "E:\se tool\flash files\SE\w710\52\R1JC002_1250433_GENERIC_CH.ssw" 2/12/2009 8:55:13 PM CURRENT FLASH FILE CID:52 2/12/2009 8:55:13 PM SSW uses full hash, hash len is:9200 2/12/2009 8:55:14 PM Will flash 460 blocks... 2/12/2009 8:59:25 PM SSW loading returns:0 2/12/2009 8:59:26 PM writing "E:\se tool\flash files\SE\w710\52\R1JC002_FS_C_ASIA_CH_RED_CID52.ss w" 2/12/2009 8:59:29 PM CURRENT FLASH FILE CID:52 2/12/2009 8:59:29 PM SSW uses full hash, hash len is:4020 2/12/2009 8:59:29 PM Will flash 201 blocks... 2/12/2009 9:01:20 PM SSW loading returns:0 2/12/2009 9:01:24 PM LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 2/12/2009 9:01:24 PM loader startup: executed 2/12/2009 9:01:35 PM loader GDFS startup: executed 2/12/2009 9:01:53 PM loader filesystem startup: executed 2/12/2009 9:01:53 PM loader unlock: executed 2/12/2009 9:01:53 PM writing "tpa/preset/custom/C3_PCA_G3v2.cer" 2/12/2009 9:01:53 PM writing "tpa/preset/custom/CONTENT_DOWNLOAD_HOOK_2.itm" 2/12/2009 9:01:53 PM writing "tpa/preset/custom/customize.xml" 2/12/2009 9:01:53 PM writing "tpa/preset/custom/DESKTOP_HOOK_2.itm" 2/12/2009 9:01:54 PM writing "tpa/preset/custom/Entrust.net Root Certificate.cer" 2/12/2009 9:01:54 PM writing "tpa/preset/custom/Entrust.net_WTLS_Root_Certificate.wcrt" 2/12/2009 9:01:54 PM writing "tpa/preset/custom/FM_PICTURES_HOOK_3.itm" 2/12/2009 9:01:56 PM writing "tpa/preset/custom/FM_SOUNDS_HOOK_3.itm" 2/12/2009 9:01:56 PM writing "tpa/preset/custom/FM_THEMES_HOOK_3.itm" 2/12/2009 9:01:56 PM writing "tpa/preset/custom/FM_VIDEOS_HOOK_3.itm" 2/12/2009 9:01:56 PM writing "tpa/preset/custom/GAMES_HOOK_3.itm" 2/12/2009 9:01:56 PM writing "tpa/preset/custom/GTE_CyberTrust_Root.cer" 2/12/2009 9:01:57 PM writing "tpa/preset/custom/GTE_Cybe_Trust_Root_WTLS.wcrt" 2/12/2009 9:01:57 PM writing "tpa/preset/custom/Root.cer" 2/12/2009 9:01:57 PM writing "tpa/preset/custom/SEMC_E2E_Root_CA.crt" 2/12/2009 9:01:57 PM writing "tpa/preset/custom/SETT_RINGTONE_HOOK_3.itm" 2/12/2009 9:01:57 PM writing "tpa/preset/custom/ThawtePremium.der" 2/12/2009 9:01:57 PM writing "tpa/preset/custom/ThawteServerCA.cer" 2/12/2009 9:01:57 PM writing "tpa/preset/custom/Utiroot.cer" 2/12/2009 9:01:57 PM writing "tpa/preset/custom/VeriSignClass3Root.cer" 2/12/2009 9:01:57 PM writing "tpa/preset/custom/Verisign_Class_3_CA_WTLS.wcrt" 2/12/2009 9:01:57 PM Phone detached 2/12/2009 9:01:59 PM Elapsed: 422 secs. 2/12/2009 9:03:46 PM SIGNED MODE (USING SERVER) 2/12/2009 9:03:54 PM ChipID:9900,EMP protocol:0301 2/12/2009 9:03:54 PM 2/12/2009 9:03:54 PM PHONE STATE: "RETAIL" 2/12/2009 9:03:54 PM FLASH CID: 0052 2/12/2009 9:03:54 PM Speed:921600 2/12/2009 9:03:54 PM Flash ID check:897E 2/12/2009 9:03:54 PM Flash props sent ok 2/12/2009 9:03:54 PM OTP: LOCKED:1 CID:49 PAF:1 IMEI:35306601453106 CERT:RED 2/12/2009 9:03:54 PM FLASH CID:52 COLOR:RED 2/12/2009 9:03:56 PM 2/12/2009 9:03:56 PM Model:W710i 2/12/2009 9:03:56 PM Brand:Generic Trade 2/12/2009 9:03:56 PM MAPP CXC article: R1JC002 prgCXC1250433_NAM_1_CH 2/12/2009 9:03:56 PM MAPP CXC version: R1JC002 2/12/2009 9:03:56 PM Language Package:AMERICA_2 2/12/2009 9:03:56 PM CDA article: CDA102566/49 2/12/2009 9:03:56 PM CDA version: R4A 2/12/2009 9:03:56 PM Default article: cxc1250441 2/12/2009 9:03:56 PM Default version: R1JC002 2/12/2009 9:03:56 PM PROVIDER: 000-00 2/12/2009 9:03:56 PM SIMLOCKS NOT DETECTED 2/12/2009 9:03:56 PM 2/12/2009 9:03:56 PM SEARCH:E:\se tool\flash files\SE\w710\52\R1JC002_1250433_GENERIC_CH.ssw 2/12/2009 9:03:59 PM SEARCH:E:\se tool\flash files\SE\w710\52\R1JC002_FS_C_ASIA_CH_RED_CID52.ss w 2/12/2009 9:04:02 PM RESTORATION FILE NOT PRESENT 2/12/2009 9:04:02 PM "R1JC002_CXC1250433_NAM_1_CH" 2/12/2009 9:04:02 PM YOU MUST PERFORM FULL FLASHING 2/12/2009 9:04:02 PM WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED 2/12/2009 9:04:02 PM 2/12/2009 9:04:02 PM BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE 2/12/2009 9:04:02 PM 2/12/2009 9:04:02 PM SECURITY UNITS BACKUP CREATED. 2/12/2009 9:04:02 PM Elapsed: 15 sec ANY BUDY HELP PLS B/R VICKY |
s500i network problem after gdfs repair | infogsm | D-Unlock Suite | 1 | 03-17-2009 00:30 |
K300i problem after GDFS flashing ? | Patrick | SonyEricsson (USB-Smart) | 3 | 12-02-2005 01:34 |
Strange problem after unlocking C616v | Big Tone | NEC | 4 | 03-07-2005 19:31 |
R220 and T100 strange problem after flashing with UST | Lutfe | UST Pro II | 3 | 10-25-2003 12:21 |
Strange problem after repairing Contact Service in 8310 | kingofhearts | Nokia Digital Core Technology 4 ( DCT-4 ) | 1 | 08-01-2002 03:59 |
