04-02-2010, 07:24 | #1 (permalink) |
Freak Poster Join Date: Feb 2009 Location: Research In Motion Age: 38
Member: 979016 Status: Offline Sonork: 1592061 Thanks Meter: 150 | strange problem of k510i RUNNING v 1.01/UNI CARD SERIAL 00100072 USBFLASH DRIVER VERSION 02.02.00.05 SIGNED MODE (USING SERVER) PRELOADER SECURITY BYPASS ENABLED CFG:101100000000 ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 FLASH ID: 897E OTP: LOCKED:1 CID:49 PAF:1 IMEI:35914800099862 CERT:RED FLASH CID:49 COLOR:RED Model (from GDFS):K510i Brand:Generic MAPP CXC article: R4EA031 prgCXC1250232_CHINA_CO MAPP CXC version: R4EA031 Language Package: C_ASIA CDA article: CDA102459/1 CDA version: R2A Default article: cxc1250246 Default version: R4EA031 PROVIDER: 000-00 SIMLOCKS NOT DETECTED USERCODE:0000 RESTORATION FILE PRESENT FOR DETECTED FIRMWARE BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE Elapsed: 15 secs. SIGNED MODE (USING SERVER) PRELOADER SECURITY BYPASS ENABLED CFG:101100000000 ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35914800099862 CERT:RED PATCH:061204 1529 HAN_DB2010_MEM_PATCHER_R2A007_CXC9876543210 0 LDR:060718 0842 LIE_DB2010_FLASHLOADER_R2A003_CXC1326738 FLASH ID: 897E LDR:070524 1030 AN2CXC1327364_COMPACT_SEMC_CS_LOADER__R3A010 Executing CSCA-based unlock. Backup security data... loader GDFS startup executed Erasing locks... DISCONNECT PHONE NOW REMOVE SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PROCEDURE WAS STOPPED BY USER Can't find attached phone with IMEI 35914800099862 CSCA UNLOCK FAILED Elapsed: 71 secs. SIGNED MODE (USING SERVER) PRELOADER SECURITY BYPASS ENABLED CFG:101100000000 ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 FLASH ID: 897E OTP: LOCKED:1 CID:49 PAF:1 IMEI:35914800099862 CERT:RED FLASH CID:49 COLOR:RED Model (from GDFS):K510i Brand:Generic MAPP CXC article: R4EA031 prgCXC1250232_CHINA_CO MAPP CXC version: R4EA031 Language Package: C_ASIA CDA article: CDA102459/1 CDA version: R2A Default article: cxc1250246 Default version: R4EA031 PROVIDER: 000-00 SIMLOCKS NOT DETECTED USERCODE:0000 RESTORATION FILE PRESENT FOR DETECTED FIRMWARE BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE Elapsed: 6 secs. SIGNED MODE (USING SERVER) PRELOADER SECURITY BYPASS ENABLED CFG:101100000000 ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35914800099862 CERT:RED PATCH:061204 1529 HAN_DB2010_MEM_PATCHER_R2A007_CXC9876543210 0 LDR:060718 0842 LIE_DB2010_FLASHLOADER_R2A003_CXC1326738 FLASH ID: 897E writing "H:\SE TOOL\SeTool Flash file\K SERIES\K510\R4EA031_1250231_GENERIC_CO.ssw.cry" CURRENT FLASH FILE CID:49 SSW uses dynamic hash, dynamic hash len is: 327 Will flash 327 blocks... writing "H:\SE TOOL\SeTool Flash file\K SERIES\K510\R4EA031_APAC_fs.ssw.cry" CURRENT FLASH FILE CID:49 SSW uses dynamic hash, dynamic hash len is: 105 Will flash 105 blocks... LDR:070524 1030 AN2CXC1327364_COMPACT_SEMC_CS_LOADER__R3A010 loader GDFS startup executed loader FILESYSTEM startup executed using GENERIC phone customization tpa/preset/custom/C3_PCA_G3v2.cer tpa/preset/custom/CONTENT_DOWNLOAD_HOOK_2.itm tpa/preset/custom/customize.xml tpa/preset/custom/DESKTOP_HOOK_2.itm tpa/preset/custom/Entrust.net Root Certificate.cer tpa/preset/custom/Entrust.net_WTLS_Root_Certificate.wcrt tpa/preset/custom/FM_PICTURES_HOOK_3.itm tpa/preset/custom/FM_SOUNDS_HOOK_3.itm tpa/preset/custom/FM_THEMES_HOOK_3.itm tpa/preset/custom/FM_VIDEOS_HOOK_3.itm tpa/preset/custom/GAMES_HOOK_3.itm tpa/preset/custom/GTE_CyberTrust_Root.cer tpa/preset/custom/GTE_Cybe_Trust_Root_WTLS.wcrt tpa/preset/custom/Root.cer tpa/preset/custom/SEMC_E2E_Root_CA.crt tpa/preset/custom/SETT_RINGTONE_HOOK_3.itm tpa/preset/custom/ThawtePremium.der tpa/preset/custom/ThawteServerCA.cer tpa/preset/custom/Utiroot.cer tpa/preset/custom/VeriSignClass3Root.cer tpa/preset/custom/Verisign_Class_3_CA_WTLS.wcrt Phone detached Elapsed: 341 secs. SIGNED MODE (USING SERVER) PRELOADER SECURITY BYPASS ENABLED CFG:101100000000 ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 FLASH ID: 897E OTP: LOCKED:1 CID:49 PAF:1 IMEI:35914800099862 CERT:RED FLASH CID:49 COLOR:RED Model (from GDFS):K510i Brand:Generic MAPP CXC article: R4EA031 prgCXC1250231_GENERIC_CO MAPP CXC version: R4EA031 Language Package: APAC CDA article: CDA102459/1 CDA version: R2A Default article: cxc1250246 Default version: R4EA031 PROVIDER: 000-00 SIMLOCKS NOT DETECTED USERCODE:0000 RESTORATION FILE PRESENT FOR DETECTED FIRMWARE BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE Elapsed: 6 secs. plz help |
04-02-2010, 08:49 | #2 (permalink) |
No Life Poster Join Date: Jun 2006 Location: {JUST@PRAY@FOR@ME} Age: 39
Member: 288504 Status: Offline Sonork: .:100.1587032:. Thanks Meter: 2,266 | CID 49 standalone method 1. select com/ufs/usb as interface 2. go to semc tab 3. select correct model 4. on settings tab, uncheck all settings. 5. back on semc tab 6. press unlock button you can not use USB as interface, if SCRC damaged ( IMEI mismatch in IDENTIFY output ) restoration files required for that method. that files could be downloaded from support area or created automatically : place main part of unsupported firmware in firmware area,press identify and attach phone with unsupported firmware. |
STRANGE PROBLEM OF LG G8000i | smr29126 | LG | 2 | 10-05-2006 07:09 |
Strange Problem Of Nokia-6230i | sDinesh | Twisterflasher | 10 | 05-01-2006 18:51 |
Anothere strange problem of 7610 | SRNOURI | Nokia Hardware & Hardware Repair | 3 | 02-22-2006 02:56 |
Strange Problem of Cruiser V2.00 and V2.10 | gsmdoctorca | Cruiser Suite | 7 | 01-19-2005 17:43 |
strange problem of BF 3 not unlock ver CPX103 00 | GSM MIND | BF, BG, TH, BHx Series | 7 | 07-26-2004 18:42 |
