05-28-2010, 18:25 | #1 (permalink) |
Freak Poster Join Date: Nov 2009 Location: Dubai
Member: 1172242 Status: Offline Sonork: helpfull_hkt Thanks Meter: 70 | Successfully Unlocked/repaired Phones By SETool RUNNING v 1.07/UNI CARD SERIAL 00039*** USBFLASH DRIVER VERSION 02.02.00.05 SIGNED MODE (USING SERVER) CFG:100000000000 SERVER CREDITS LEFT/USED: 10/20 CARD COUNTERS: FLASH 86, UNLOCK 88 Elapsed: 2 secs. SIGNED MODE (USING SERVER) CFG:100000000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "GREEN" BUTTON... PROCEDURE WAS STOPPED BY USER Can't load ID loader ! Elapsed: 96 secs. SIGNED MODE (USING SERVER) CFG:100010000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "GREEN" BUTTON... EROM "R8A017" AID: 0001 SOFTWARE AID: 0001 SIMLOCK STATE: "NOT TAMPERED" LOADER AID: 0002 FLASH ID: "00EC/0040" LOADER VERSION: "R4A012" PHONE IMEI:35938703094776 Checking for signature... Waiting for calculation process... RESPONSE: "SUCCESS" [1048] GOT SEED:F0982F6F80DB7B358023170E OMAP P96 AUTH PASSED GOT SEED:674008ED6F80DB7B35802317 CCPU P96 AUTH PASSED Unlock DONE Elapsed: 44 secs. SIGNED MODE (USING SERVER) CFG:100010000000 SERVER CREDITS LEFT/USED: 9/21 CARD COUNTERS: FLASH 86, UNLOCK 88 Elapsed: 3 secs. Last edited by helpfull_hkt; 05-28-2010 at 18:30. |
05-29-2010, 09:25 | #2 (permalink) |
No Life Poster Join Date: Apr 2010 Location: pakistan Age: 48
Member: 1275418 Status: Offline Thanks Meter: 432 | c702 unlock ok SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") CFG:110000000000 ChipID:C900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,52,1,35438702480826] OTP LOCKED:1 CID:52 PAF:1 IMEI:35438702480826 CERT:RED LDR:2010-02-03 16:11 CXC1250843_DB31XX_CS_LOADER_ACC_SDRAM_R2A093 LDR:2010-02-03 16:12 CXC1250780_DB31XX_CS_LOADER_APP_SDRAM_R2A093 Model (from GDFS):C702 MAPP CXC article: R3CA037 prg12049289_GENERIC_NG MAPP CXC version: R3CA037 Language Package: NORDIC CDA article: 1211-0453 CDA version: R2A Default article: 1202-6843 Default version: R3CA037 PROVIDER: MULTIPLE Extended LOCKED Elapsed: 11 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") CFG:110000000000 Will backup GDFS now. ChipID:C900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,52,1,35438702480826] OTP LOCKED:1 CID:52 PAF:1 IMEI:35438702480826 CERT:RED LDR:2010-02-03 16:11 CXC1250843_DB31XX_CS_LOADER_ACC_SDRAM_R2A093 LDR CAPS:SYSTEM FLASH SIGNATURE AUTH LDR:2010-02-03 16:12 CXC1250780_DB31XX_CS_LOADER_APP_SDRAM_R2A093 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA got 101 TA units got 27 TA units got 1840 GDFS units gdfs read done,gdfs_35438702480826.zip written Phone detached Elapsed: 47 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") CFG:110000000000 ChipID:C900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,52,1,35438702480826] OTP LOCKED:1 CID:52 PAF:1 IMEI:35438702480826 CERT:RED LDR:2009-06-26 15:53 CXC1250778_DB31XX_PRODUCTION_LOADER_APP_SDRAM_R2A0 82 DEVICE KEY:6C4AC904B24B3657BD9B1819C8886550 (0) LDR:2009-04-21 18:17 CXC1250781_DB31XX_RESET_LOADER_ACC_SDRAM_R2A081 LDR:2009-04-21 18:18 CXC1250782_DB31XX_RESET_LOADER_APP_SDRAM_R2A081 GOT SEED:6A9C30513480536825A06375 P96 AUTH PASSED RESETTING SECURITY TO FACTORY STATE... RESTARTING... ChipID:C900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,52,1,35438702480826] OTP LOCKED:1 CID:52 PAF:1 IMEI:35438702480826 CERT:BROWN LDR:2009-06-26 15:52 CXC1250777_DB31XX_PRODUCTION_LOADER_ACC_SDRAM_R2A0 82 LDR:2009-06-26 15:53 CXC1250778_DB31XX_PRODUCTION_LOADER_APP_SDRAM_R2A0 82 WRITING SEMCBOOT... PREPARING SECURITY... WRITING CLEAR SIMLOCK UNITS... ALL UNLOCK/LOCK CODES SET TO "63506284" CHANGING DOMAIN TO "RED" SIGNING... DEVICE KEY RESTORED Unlock FINISHED Elapsed: 39 secs. |
05-30-2010, 08:19 | #3 (permalink) |
No Life Poster Join Date: Jun 2006 Location: ..::SL3 Unlock Source::.. Age: 38
Member: 293662 Status: Offline Sonork: 100.1622609 Thanks Meter: 317 | Look At this bro http://forum.gsmhosting.com/vbb/f473...etool-1010771/ |
12-14-2010, 16:51 | #5 (permalink) |
Member: 1172242 Status: Offline Sonork: helpfull_hkt Thanks Meter: 70 | J20_HAZEL successfully unlock Done 6 credits with Setool RUNNING v 1.09/UNI CARD SERIAL 00039329 USBFLASH DRIVER VERSION 02.02.00.05 SIGNED MODE (USING SERVER) CFG:100000000000 ChipID:F100,EMP protocol:0401 PHONE STATE: "RETAIL" FLASH CID: 0053 OTP LOCKED:1 CID:53 PAF:1 IMEI:01227300051786 CERT:RED LDR:2009-10-26 14:07 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A087 LDR:2009-10-26 14:08 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A087 Model (from GDFS):J20i MAPP CXC article: R7BA081 prg1231-9304_GENERIC_SY MAPP CXC version: R7BA081 Language Package: M-EAST-N-AFR CDA article: 1237-0606 CDA version: R3A Default article: 1231-9366 Default version: R7BA081 PROVIDER: 000-00 SIMLOCKS NOT DETECTED SECURITY UNITS BACKUP CREATED. Elapsed: 11 secs. SIGNED MODE (USING SERVER) CFG:100010000000 ChipID:F100,EMP protocol:0401 PHONE STATE: "RETAIL" FLASH CID: 0053 OTP LOCKED:1 CID:53 PAF:1 IMEI:01227300051786 CERT:RED LDR:2009-10-26 14:07 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A087 LDR CAPS:SYSTEM FLASH SIGNATURE AUTH LDR:2009-10-26 14:08 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A087 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock. Checking for signature... Waiting for calculation process... RESPONSE: "SUCCESS" [1038] GOT SEED:A51F9F678035F12F00A0A40C P96 AUTH PASSED Backup security data... Erasing locks... Unlock DONE Elapsed: 16 secs. |
12-18-2010, 13:41 | #6 (permalink) |
Member: 1172242 Status: Offline Sonork: helpfull_hkt Thanks Meter: 70 | Samsung m5650 direct unlock with se tool successfully this is the steps how to unlock samsung m5650 by setool : 1. must have setool activated 2.use latest update 1.09 3.go to setting enable signed mode 4.press volume down key + camera key then plug usb cable 5. press unlock 6. enter code gived on software and enjoy SIGNED MODE (USING SERVER) CFG:100000000000 ChipID900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,26,0,35866703097464] OTP LOCKED:1 CID:26 PAF:0 IMEI:35866703097464 CERT:BROWN LDR:090923 1531 MATCXC1723918_C9_DB3200_PRODUCTION_LOADER_ACC_SDRA M_P2A LDR CAPS:SYSTEM FLASH SIGNATURE LDR:090923 1533 MATCXC1723919_1C9_DB3200_PRODUCTION_LOADER_APP_SDR AM_JEFF_CABS_P2A LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM SIGNING... UNFREEZE CODE: 09490253 [NETWORK UNLOCK] #7465625*638*25203193# Unlock DONE Elapsed: 110 secs. |
