04-11-2009, 13:44 | #1 (permalink) |
Cheater -Don't Deal with him- Join Date: May 2006 Age: 38
Member: 283204 Status: Offline Sonork: 100.1577140 Thanks Meter: 1,098 | <<<<<succsssfully unlock t280 with se-tool>>>>> v0.915033/UNI CARD SERIAL: 00061898 Loaded 51 flash descriptors PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... ROM version: 0502 Locosto HS detected, booting... FLASH ID: 0089/8904 (00040000) SECURITY AREA BACKUP CREATED. PHONE IMEI:35342202435026 USERLOCK RESET TO "0000" TOTAL CALL TIME RESET Firmware lock check determined. SIMLOCK PATCH EXECUTED Updating TA... Elapsed: 99 secs. br: Harkishan |
The Following User Says Thank You to Harkishan singh For This Useful Post: |
04-12-2009, 21:47 | #7 (permalink) |
Insane Poster Join Date: Apr 2007 Location: Pakistan
Member: 498498 Status: Offline Thanks Meter: 15 | t280i unlock done 4/2/2009 12:56:46 PM v0.915034/UNI 4/2/2009 12:56:46 PM CARD SERIAL: 000000 4/2/2009 12:56:46 PM Loaded 51 flash descriptors 4/2/2009 12:58:23 PM SIGNED MODE (USING SERVER) 4/2/2009 12:58:24 PM PLEASE ATTACH TURNED OFF PHONE NOW 4/2/2009 12:58:24 PM PRESS "POWER ON" BUTTON SHORTLY... 4/2/2009 12:58:35 PM 4/2/2009 12:58:35 PM EROM "R5A036" CID: 0001 4/2/2009 12:58:35 PM SOFTWARE CID: 0001 4/2/2009 12:58:35 PM SIMLOCK STATE: "1" 4/2/2009 12:58:48 PM LOADER VERSION: "R3A006" 4/2/2009 12:58:48 PM 4/2/2009 12:58:48 PM PHONE IMEI:35xxxxxxxxxxx 4/2/2009 12:58:48 PM MODEL (from GDFS): T280i 4/2/2009 12:58:48 PM FACTORY CXC: CXC1250616_R5A036 4/2/2009 12:58:48 PM CURRENT CXC: CXC1251088_R1CB002 4/2/2009 12:58:48 PM CURRENT CDA: CDA102934/80_R6A 4/2/2009 12:58:49 PM Elapsed: 25 secs. 4/2/2009 12:58:57 PM SIGNED MODE (USING SERVER) 4/2/2009 12:58:57 PM PLEASE ATTACH TURNED OFF PHONE NOW 4/2/2009 12:58:57 PM PRESS "POWER ON" BUTTON SHORTLY... 4/2/2009 12:59:15 PM 4/2/2009 12:59:15 PM EROM "R5A036" CID: 0001 4/2/2009 12:59:15 PM SOFTWARE CID: 0001 4/2/2009 12:59:15 PM SIMLOCK STATE: "1" 4/2/2009 12:59:27 PM LOADER VERSION: "R3A006" 4/2/2009 12:59:27 PM 4/2/2009 12:59:27 PM PHONE IMEI:353xxxxxxx 4/2/2009 12:59:27 PM USERLOCK RESET TO "0000" 4/2/2009 12:59:27 PM TOTAL CALL TIME RESET 4/2/2009 12:59:29 PM Elapsed: 31 secs. |
04-17-2009, 19:31 | #8 (permalink) |
No Life Poster Join Date: Feb 2009 Location: nicaragua
Member: 980307 Status: Offline Sonork: 100.1649165 Thanks Meter: 173 | t280 unlock ok by cruiser tested for me UNLOCK OK ------T280 code] 12:12:25 SE S1 Flasher & Unlocker v2.05 by Cruiser Team 12:12:25 Initializing... ! 12:12:25 1. Choose the phone model ! 12:12:25 2. For flashing, select flash files and additional options ! 12:12:25 3. Double-click on the appropriate device (serial cable) ! 12:12:25 - or connect the phone via USB while holding its C button 12:13:46 Connecting via Generic FTDI Cable (COM7)… 12:13:46 Device driver version: 2.0.0.0 12:13:46 Device driver date: 5-19-2006 ! 12:13:46 Connect the phone now 12:13:46 Connecting to the baseband CPU... 12:13:59 Reading TA… 12:14:11 Reading EROM… 12:14:17 IMEI: **************** 12:14:17 Unlocking… 12:14:33 The phone has been successfully unlocked. 12:14:33 Turning off the phone... 12:14:34 Done. ! 12:14:34 Please disconnect battery and cable from the phone! [/code] |
05-19-2009, 13:14 | #10 (permalink) |
Junior Member Join Date: Aug 2004
Member: 77812 Status: Offline Thanks Meter: 0 | CFG:000000000000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... ROM version: 0502 Locosto HS detected, booting... LOADER NOT RESPONDING ENABLE "SIGNED MODE" failed FAILED TO SETUP PHONE Elapsed: 16 secs. |
05-19-2009, 13:30 | #11 (permalink) |
Member: 77812 Status: Offline Thanks Meter: 0 | with ENABLE "SIGNED MODE" no connction with phone v0.915036/UNI CARD SERIAL: 00000672 Loaded 51 flash descriptors SIGNED MODE (USING SERVER) CFG:100000000000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... PROCEDURE WAS STOPPED BY USER supported phone was not detected FAILED TO SETUP PHONE Elapsed: 105 secs. |
05-19-2009, 17:27 | #12 (permalink) |
Junior Member Join Date: Dec 2008
Member: 921150 Status: Offline Thanks Meter: 1 | Connecting t280i Hi How did you connect the t280i was it via usb and what buttons did you hold down??? Cheers Matchu |
The Following User Says Thank You to matchu78 For This Useful Post: |
Problem unlocking W350 with SE Full Unlocker??? | Unlocker AL | Cruiser Suite | 8 | 04-24-2009 13:53 |
F305 unlock procedur , with se full unlocker | pitrichkou | Cruiser Suite | 2 | 03-05-2009 11:57 |
How to unlock t250i with SE S1 Flasher & Unlocker | Civija | Cruiser Suite | 0 | 01-26-2009 11:28 |
I can't unlock W200 with SE Ultimate Unlocker | cimarron42 | Cruiser Suite | 6 | 10-10-2008 14:26 |
Can we unlock z750a with se ultimate unlocker? | edong | Cruiser Suite | 3 | 10-03-2008 08:54 |
