10-13-2011, 08:00 | #1 (permalink) |
Insane Poster Join Date: Apr 2011
Member: 1566017 Status: Offline Sonork: rerer Thanks Meter: 1 | t650i cid51 Died after flashing I need Firmware cid51 Arabic Language This information after flashing CARD SERIAL 00144066 PLEASE UPGRADE USBFLASH DRIVER 02.02.00.00 SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110000000000 ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35796601836911 CERT:N/A FLASH CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID: 897E writing "D:\setool\فلاشات\T6 50\R7AA024_2562_GENERIC_SN.ssw" CURRENT FLASH FILE CID:52 SSW uses full hash, hash len is: 9200 HDR block not accepted,error: 19 Elapsed: 13 secs. CFG:000000000000 RECOVERY MODE STARTED ChipID:9900,EMP protocol:0301 Speed:921600 REC:070703 1229 NPA4_CXC1329130_DB2020_SEMC_RECOVERY_P3N can't open file "frec\marikabrowncid52.bin" Recovery failed. Phone dead. Elapsed: 10 secs. CFG:000000000000 RECOVERY MODE STARTED ChipID:9900,EMP protocol:0301 Speed:921600 REC:070703 1229 NPA4_CXC1329130_DB2020_SEMC_RECOVERY_P3N can't open file "frec\marikabrowncid52.bin" Recovery failed. Phone dead. Elapsed: 2 secs. CFG:000000000000 ChipID:9900,EMP protocol:0301 Speed:921600 FLASH ID: 897E OTP: LOCKED:1 CID:51 PAF:1 IMEI:35796601836911 CERT:N/A FLASH CID:49 COLOR:BROWN can't get packet start. no ack during gdfs_readvar ! SCRC READ FAILURE Elapsed: 32 secs Last edited by nokiammmmm; 10-13-2011 at 08:07. |
10-13-2011, 08:08 | #2 (permalink) |
Member: 1566017 Status: Offline Sonork: rerer Thanks Meter: 1 | This information after flashing RUNNING v 1.01/UNI CARD SERIAL 00144066 PLEASE UPGRADE USBFLASH DRIVER 02.02.00.00 SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110000000000 ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35796601836911 CERT:N/A FLASH CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID: 897E writing "D:\setool\فلاشات\T6 50\R7AA024_2562_GENERIC_SN.ssw" CURRENT FLASH FILE CID:52 SSW uses full hash, hash len is: 9200 HDR block not accepted,error: 19 Elapsed: 13 secs. CFG:000000000000 RECOVERY MODE STARTED ChipID:9900,EMP protocol:0301 Speed:921600 REC:070703 1229 NPA4_CXC1329130_DB2020_SEMC_RECOVERY_P3N can't open file "frec\marikabrowncid52.bin" Recovery failed. Phone dead. Elapsed: 10 secs. CFG:000000000000 RECOVERY MODE STARTED ChipID:9900,EMP protocol:0301 Speed:921600 REC:070703 1229 NPA4_CXC1329130_DB2020_SEMC_RECOVERY_P3N can't open file "frec\marikabrowncid52.bin" Recovery failed. Phone dead. Elapsed: 2 secs. CFG:000000000000 ChipID:9900,EMP protocol:0301 Speed:921600 FLASH ID: 897E OTP: LOCKED:1 CID:51 PAF:1 IMEI:35796601836911 CERT:N/A FLASH CID:49 COLOR:BROWN can't get packet start. no ack during gdfs_readvar ! SCRC READ FAILURE Elapsed: 32 secs. |
10-13-2011, 08:21 | #3 (permalink) |
No Life Poster Join Date: Feb 2008
Member: 696136 Status: Offline Thanks Meter: 210 | Perform reset procedure. CID 50,51,52,53 that is so-called reset procedure. 1. go to emptyboard tab 2. select proper model 3. on settings, check "signed mode" 4. press recovery 5. after succeful recovery 6. on settings uncheck all 7. add to firmware area proper gdfs in ssw format 8. add to firmware area proper EROM (EROM CID >= OTP CID) 9. press flash 10. if needed,reflash phone on usual semc tab with needed settings |
10-13-2011, 08:21 | #4 (permalink) |
Product Manager Join Date: Sep 2009 Location: Pakistan Age: 36
Member: 1118710 Status: Offline Sonork: 100.1604414 Thanks Meter: 4,970 | Use RESET Method to Solve ur Problem... 1. go to emptyboard tab 2. select proper model 3. on settings, check "signed mode" 4. press recovery 5. after successful recovery 6. on settings uncheck all 7. if gdfs totally damaged, add to firmware area proper gdfs in ssw format,otherwise skip that step 8. add to firmware area proper EROM (EROM CID >= OTP CID) 9. press flash 10. if needed,reflash phone on usual semc tab with needed settings. & Post result.. |
10-13-2011, 08:49 | #5 (permalink) |
Member: 1566017 Status: Offline Sonork: rerer Thanks Meter: 1 | 7. if gdfs totally damaged, add to firmware area proper gdfs in ssw format,otherwise skip that step Did you mean add a file gdf How do I add the file gdf Tervali Is it possible the file gdf |
10-13-2011, 09:05 | #6 (permalink) |
Member: 1566017 Status: Offline Sonork: rerer Thanks Meter: 1 | look info RUNNING v 1.01/UNI CARD SERIAL 00144066 PLEASE UPGRADE USBFLASH DRIVER 02.02.00.00 CFG:000000000000 ChipID:9900,EMP protocol:0301 Speed:921600 FLASH ID: 897E OTP: LOCKED:1 CID:51 PAF:1 IMEI:35796601836911 CERT:N/A FLASH CID:49 COLOR:BROWN no ack during gdfs_readvar ! SCRC READ FAILURE Elapsed: 70 secs. SIGNED MODE (USING SERVER) CFG:100000000000 No server found. CARD COUNTERS: FLASH 4, UNLOCK 11 Elapsed: 5 secs. SIGNED MODE (USING SERVER) CFG:100000000000 No server found. CARD COUNTERS: FLASH 4, UNLOCK 11 Elapsed: 3 secs. CFG:000000000000 RECOVERY MODE STARTED ChipID:9900,EMP protocol:0301 Speed:921600 REC:070703 1229 NPA4_CXC1329130_DB2020_SEMC_RECOVERY_P3N can't open file "frec\marikabrowncid16.bin" Recovery failed. Phone dead. Elapsed: 5 secs. |
10-13-2011, 10:20 | #8 (permalink) |
Member: 1566017 Status: Offline Sonork: rerer Thanks Meter: 1 | ihave file gdf but same prolome RUNNING v 1.01/UNI CARD SERIAL 00144066 PLEASE UPGRADE USBFLASH DRIVER 02.02.00.00 CFG:000000000000 ChipID:9900,EMP protocol:0301 Speed:921600 FLASH ID: 897E OTP: LOCKED:1 CID:51 PAF:1 IMEI:35796601836911 CERT:N/A FLASH CID:49 COLOR:BROWN no ack during gdfs_readvar ! SCRC READ FAILURE Elapsed: 70 secs. SIGNED MODE (USING SERVER) CFG:100000000000 No server found. CARD COUNTERS: FLASH 4, UNLOCK 11 Elapsed: 5 secs. SIGNED MODE (USING SERVER) CFG:100000000000 No server found. CARD COUNTERS: FLASH 4, UNLOCK 11 Elapsed: 3 secs. CFG:000000000000 RECOVERY MODE STARTED ChipID:9900,EMP protocol:0301 Speed:921600 REC:070703 1229 NPA4_CXC1329130_DB2020_SEMC_RECOVERY_P3N can't open file "frec\marikabrowncid16.bin" Recovery failed. Phone dead. Elapsed: 5 secs. SIGNED MODE (USING SERVER) CFG:100000000000 RESET MODE STARTED ChipID:9900,EMP protocol:0301 Speed:921600 RESET:070703 1106 NPACXC1250329_DB2020_CERTRESETLOADER_P3AA FLASH ID: 897E GOT SEED:40B2111423804E7615F052CC P96 AUTH PASSED OTP: LOCKED:1 CID:51 PAF:1 IMEI:35796601836911 CERT:N/A PHONE SUCCESSFULLY RESET TO DEVELOPER STATE Elapsed: 27 secs. SIGNED MODE (USING SERVER) CFG:100000000000 ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35796601836911 CERT:N/A FLASH CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID: 897E writing "D:\setool\فلاشات\T650\T650_gdfs_SSW.ssw" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 640 Will flash 32 blocks... writing "D:\setool\فلاشات\T650\R7AA024_FS_M_EAST_N_AFR_SN_ RED_CID52.ssw" CURRENT FLASH FILE CID:52 SSW uses full hash, hash len is: 3540 HDR block not accepted,error: 19 Elapsed: 51 secs. SIGNED MODE (USING SERVER) CFG:100000000000 No server found. CARD COUNTERS: FLASH 4, UNLOCK 11 Elapsed: 3 secs. CFG:000000000000 ChipID:9900,EMP protocol:0301 Speed:921600 FLASH ID: 897E OTP: LOCKED:1 CID:51 PAF:1 IMEI:35796601836911 CERT:N/A FLASH CID:49 COLOR:BROWN no ack during gdfs_readvar ! SCRC READ FAILURE Elapsed: 18 secs. SIGNED MODE (USING SERVER) CFG:100000000000 No server found. CARD COUNTERS: FLASH 4, UNLOCK 11 Elapsed: 3 secs. SIGNED MODE (USING SERVER) CFG:100000000000 ChipID:9900,EMP protocol:0301 Speed:921600 FLASH ID: 897E OTP: LOCKED:1 CID:51 PAF:1 IMEI:35796601836911 CERT:N/A FLASH CID:49 COLOR:BROWN can't get packet start. no ack during gdfs_readvar ! SCRC READ FAILURE Elapsed: 32 secs. SIGNED MODE (USING SERVER) CFG:100000000000 No server found. CARD COUNTERS: FLASH 4, UNLOCK 11 Elapsed: 3 secs. CFG:000000000000 RECOVERY MODE STARTED ChipID:9900,EMP protocol:0301 Speed:921600 REC:070703 1229 NPA4_CXC1329130_DB2020_SEMC_RECOVERY_P3N can't open file "frec\marikabrowncid16.bin" Recovery failed. Phone dead. Elapsed: 2 secs. SIGNED MODE (USING SERVER) CFG:100000000000 RESET MODE STARTED ChipID:9900,EMP protocol:0301 Speed:921600 RESET:070703 1106 NPACXC1250329_DB2020_CERTRESETLOADER_P3AA FLASH ID: 897E GOT SEED:C35FF17323804E7615F052CC P96 AUTH PASSED OTP: LOCKED:1 CID:51 PAF:1 IMEI:35796601836911 CERT:N/A PHONE SUCCESSFULLY RESET TO DEVELOPER STATE Elapsed: 6 secs. SIGNED MODE (USING SERVER) CFG:100000000000 ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35796601836911 CERT:N/A FLASH CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID: 897E writing "D:\setool\فلاشات\T650\T650_gdfs_SSW.ssw" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 640 Will flash 32 blocks... writing "D:\setool\فلاشات\T650\R7AA024_FS_M_EAST_N_AFR_SN_ RED_CID52.ssw" CURRENT FLASH FILE CID:52 SSW uses full hash, hash len is: 3540 HDR block not accepted,error: 19 Elapsed: 47 secs. SIGNED MODE (USING SERVER) CFG:100000000000 No server found. CARD COUNTERS: FLASH 4, UNLOCK 11 Elapsed: 2 secs. CFG:000000000000 ChipID:9900,EMP protocol:0301 Speed:921600 FLASH ID: 897E OTP: LOCKED:1 CID:51 PAF:1 IMEI:35796601836911 CERT:N/A FLASH CID:49 COLOR:BROWN PROCEDURE WAS STOPPED BY USER can't get packet start. no ack during gdfs_readvar ! SCRC READ FAILURE Elapsed: 57 secs. CFG:000000000000 ChipID:9900,EMP protocol:0301 Speed:921600 FLASH ID: 897E OTP: LOCKED:1 CID:51 PAF:1 IMEI:35796601836911 CERT:N/A FLASH CID:49 COLOR:BROWN can't get packet start. no ack during gdfs_readvar ! SCRC READ FAILURE Elapsed: 32 secs. SIGNED MODE (USING SERVER) CFG:100000000000 No server found. CARD COUNTERS: FLASH 4, UNLOCK 11 Elapsed: 2 secs. CFG:000000000000 RECOVERY MODE STARTED ChipID:9900,EMP protocol:0301 Speed:921600 REC:070703 1229 NPA4_CXC1329130_DB2020_SEMC_RECOVERY_P3N can't open file "frec\marikabrowncid16.bin" Recovery failed. Phone dead. Elapsed: 2 secs. SIGNED MODE (USING SERVER) CFG:100000000000 RESET MODE STARTED ChipID:9900,EMP protocol:0301 Speed:921600 RESET:070703 1106 NPACXC1250329_DB2020_CERTRESETLOADER_P3AA FLASH ID: 897E GOT SEED:57FFA26923804E7615F052CC P96 AUTH PASSED OTP: LOCKED:1 CID:51 PAF:1 IMEI:35796601836911 CERT:N/A PHONE SUCCESSFULLY RESET TO DEVELOPER STATE Elapsed: 5 secs. SIGNED MODE (USING SERVER) CFG:100000000000 ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35796601836911 CERT:N/A FLASH CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID: 897E writing "D:\setool\فلاشات\T650\T650_gdfs_SSW.ssw" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 640 Will flash 32 blocks... writing "D:\setool\فلاشات\T650\R7AA024_FS_M_EAST_N_AFR_SN_ RED_CID52.ssw" CURRENT FLASH FILE CID:52 SSW uses full hash, hash len is: 3540 HDR block not accepted,error: 19 Elapsed: 54 secs. SIGNED MODE (USING SERVER) CFG:100000000000 No server found. CARD COUNTERS: FLASH 4, UNLOCK 11 Elapsed: 2 secs. CFG:000000000000 ChipID:9900,EMP protocol:0301 Speed:921600 FLASH ID: 897E OTP: LOCKED:1 CID:51 PAF:1 IMEI:35796601836911 CERT:N/A FLASH CID:49 COLOR:BROWN can't get packet start. no ack during gdfs_readvar ! SCRC READ FAILURE Elapsed: 48 secs. SIGNED MODE (USING SERVER) CFG:100100000000 ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35796601836911 CERT:N/A FLASH CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID: 897E writing "D:\setool\فلاشات\T650\R7AA024_2562_GENERIC_SN.ssw " CURRENT FLASH FILE CID:52 SSW uses full hash, hash len is: 9200 HDR block not accepted,error: 19 Elapsed: 9 secs. SIGNED MODE (USING SERVER) CFG:100100000000 ChipID:9900,EMP protocol:0301 Speed:115200 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35796601836911 CERT:N/A FLASH CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID: 897E writing "D:\setool\فلاشات\T650\R7AA024_2562_GENERIC_SN.ssw " CURRENT FLASH FILE CID:52 SSW uses full hash, hash len is: 9200 HDR block not accepted,error: 19 Elapsed: 53 secs. SIGNED MODE (USING SERVER) CFG:100100000000 ChipID:9900,EMP protocol:0301 Speed:115200 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35796601836911 CERT:N/A FLASH CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID: 897E writing "D:\setool\فلاشات\T650\R7AA024_2562_GENERIC_SN.ssw " CURRENT FLASH FILE CID:52 SSW uses full hash, hash len is: 9200 HDR block not accepted,error: 19 Elapsed: 39 secs. SIGNED MODE (USING SERVER) CFG:100100000000 ChipID:9900,EMP protocol:0301 Speed:115200 FAILED TO SETUP PHONE Elapsed: 12 secs. SIGNED MODE (USING SERVER) CFG:100100000000 PROCEDURE WAS STOPPED BY USER FAILED TO SETUP PHONE Elapsed: 16 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110100000000 ChipID:9900,EMP protocol:0301 Speed:115200 FAILED TO SETUP PHONE Elapsed: 12 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110100000000 ChipID:9900,EMP protocol:0301 Speed:115200 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35796601836911 CERT:N/A FLASH CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID: 897E writing "D:\setool\فلاشات\T650\R7AA024_2562_GENERIC_SN.ssw " CURRENT FLASH FILE CID:52 SSW uses full hash, hash len is: 9200 HDR block not accepted,error: 19 Elapsed: 20 secs. |
10-13-2011, 10:28 | #9 (permalink) | |
No Life Poster Join Date: Dec 2007 Location: Pakistan
Member: 644616 Status: Offline Sonork: 100.1608012 Thanks Meter: 257 | Quote:
1. go to emptyboard tab 2. select proper model 3. on settings, check "signed mode" 4. press recovery 5. after successful recovery 6. on settings uncheck all 7. if gdfs totally damaged, add to firmware area proper gdfs in ssw format,otherwise skip that step 8. add to firmware area proper EROM (EROM CID >= OTP CID) 9. press flash | |
need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-16-2019 19:37 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
5110 5.24 locked all 4 locks after unlocking... | MCG | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 03-07-2000 22:24 |
