tm506 after unlock dead what went wrong. [QUOTE] 11/20/2008 5:37:29 PM v0.915019/UNI 11/20/2008 5:37:29 PM CARD SERIAL: 00045331 11/20/2008 5:37:29 PM Loaded 51 flash descriptors 11/20/2008 5:39:43 PM Can't load ID loader ! 11/20/2008 5:39:43 PM PROCEDURE WAS STOPPED BY USER 11/20/2008 5:39:43 PM Elapsed: 67 secs. 11/20/2008 5:44:16 PM Can't load ID loader ! 11/20/2008 5:44:16 PM PROCEDURE WAS STOPPED BY USER 11/20/2008 5:44:16 PM Elapsed: 269 secs. 11/20/2008 5:46:56 PM Can't load ID loader ! 11/20/2008 5:46:56 PM PROCEDURE WAS STOPPED BY USER 11/20/2008 5:46:56 PM Elapsed: 11 secs. 11/20/2008 5:47:27 PM ChipID:C900,EMP protocol:0401 11/20/2008 5:47:27 PM 11/20/2008 5:47:27 PM PHONE STATE: "RETAIL" 11/20/2008 5:47:27 PM FLASH CID: 0052 11/20/2008 5:47:29 PM OTP LOCKED:1 CID:52 PAF:1 IMEI:35507602286982 CERT:RED 11/20/2008 5:47:29 PM LDR:2008-07-23 12:03 CXC1250843_DB31XX_CS_LOADER_ACC_SDRAM_R2A065 11/20/2008 5:47:32 PM LDR:2008-07-23 12:03 CXC1250780_DB31XX_CS_LOADER_APP_SDRAM_R2A065 11/20/2008 5:47:32 PM 11/20/2008 5:47:32 PM Model:TM506 11/20/2008 5:47:32 PM MAPP CXC article: R3CA033 prg12033655_TMOUS_BL 11/20/2008 5:47:32 PM MAPP CXC version: R3CA033 11/20/2008 5:47:32 PM Language Package:TMO-US 11/20/2008 5:47:32 PM CDA article: 1207-2630 11/20/2008 5:47:32 PM CDA version: R28A 11/20/2008 5:47:32 PM Default article: 1203-3659 11/20/2008 5:47:32 PM Default version: R3CA033 11/20/2008 5:47:32 PM PROVIDER: 000-00 11/20/2008 5:47:32 PM Network LOCKED 11/20/2008 5:47:32 PM 11/20/2008 5:47:32 PM SECURITY UNITS BACKUP CREATED. 11/20/2008 5:47:33 PM Elapsed: 13 secs. 11/20/2008 5:47:58 PM SIGNED MODE (USING SERVER). 11/20/2008 5:47:58 PM ALTERNATIVE SECURITY BYPASS ENABLED. 11/20/2008 5:47:58 PM PRELOADER SECURITY BYPASS ENABLED. 11/20/2008 5:47:58 PM PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") 11/20/2008 5:48:09 PM ChipID:C900,EMP protocol:0401 11/20/2008 5:48:09 PM BOOTROM MODE DETECTED 11/20/2008 5:48:11 PM OTP LOCKED:1 CID:52 PAF:1 IMEI:35507602286982 CERT:RED 11/20/2008 5:48:13 PM LDR:2008-07-23 11:58 CXC1250778_DB31XX_PRODUCTION_LOADER_APP_SDRAM_R2A0 65 11/20/2008 5:48:13 PM DEVICE KEY:9B24778AB95912F05F07E0CCC839FA47 (1) 11/20/2008 5:48:14 PM LDR:2008-07-23 11:57 CXC1250781_DB31XX_RESET_LOADER_ACC_SDRAM_R2A065 11/20/2008 5:48:15 PM LDR:2008-07-23 11:57 CXC1250782_DB31XX_RESET_LOADER_APP_SDRAM_R2A065 11/20/2008 5:48:20 PM GOT SEED:6C1617C63480046B25601046 11/20/2008 5:48:20 PM P96 AUTH PASSED 11/20/2008 5:48:20 PM RESETTING SECURITY TO FACTORY STATE... 11/20/2008 5:48:21 PM RESTARTING... 11/20/2008 5:48:21 PM PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") 11/20/2008 5:48:24 PM ChipID:C900,EMP protocol:0401 11/20/2008 5:48:24 PM BOOTROM MODE DETECTED 11/20/2008 5:48:27 PM OTP LOCKED:1 CID:52 PAF:1 IMEI:35507602286982 CERT:BROWN 11/20/2008 5:48:27 PM LDR:2008-07-23 11:59 CXC1250777_DB31XX_PRODUCTION_LOADER_ACC_SDRAM_R2A0 65 11/20/2008 5:48:30 PM LDR:2008-07-23 11:58 CXC1250778_DB31XX_PRODUCTION_LOADER_APP_SDRAM_R2A0 65 11/20/2008 5:48:30 PM WRITING SEMCBOOT... 11/20/2008 5:48:47 PM can't send NET packet 11/20/2008 5:48:47 PM bad SIGN response from phone 11/20/2008 5:48:47 PM can't open file "" 11/20/2008 5:48:47 PM Elapsed: 48 secs. 11/20/2008 5:50:07 PM SIGNED MODE (USING SERVER). 11/20/2008 6:03:05 PM Can't load ID loader ! 11/20/2008 6:03:05 PM PROCEDURE WAS STOPPED BY USER 11/20/2008 6:03:06 PM Elapsed: 778 secs. 11/20/2008 6:03:11 PM SIGNED MODE (USING SERVER). 11/20/2008 6:03:46 PM Can't load ID loader ! 11/20/2008 6:03:46 PM PROCEDURE WAS STOPPED BY USER 11/20/2008 6:03:46 PM Elapsed: 35 secs. [/QUOT |
Set DOMAIN to RED .................OK |
triy this select z780 model and 2click 1.signed mode(server used for bypass/csca if needed 2. enable altrnative security bypass. use v0.915057. |
TM506 Dead/Black Screen after unlock tm506 unlock 100% ok, but phone does not turn on only black screen, tried everything on this thread. please help |
unlock process can't do that. most probably, you had done something other. unlock phone in altbypass mode, than reflash phone with latest firmware. if that will not help, check phone hardware. |
