Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (Non-Official Support) > SETool2
Old 11-20-2008, 11:34   #1 (permalink)
Member: 501740
tm506 after unlock dead
what went wrong.
[QUOTE]
11/20/2008 5:37:29 PM v0.915019/UNI
11/20/2008 5:37:29 PM CARD SERIAL: 00045331
11/20/2008 5:37:29 PM Loaded 51 flash descriptors
11/20/2008 5:39:43 PM Can't load ID loader !
11/20/2008 5:39:43 PM PROCEDURE WAS STOPPED BY USER
11/20/2008 5:39:43 PM Elapsed: 67 secs.
11/20/2008 5:44:16 PM Can't load ID loader !
11/20/2008 5:44:16 PM PROCEDURE WAS STOPPED BY USER
11/20/2008 5:44:16 PM Elapsed: 269 secs.
11/20/2008 5:46:56 PM Can't load ID loader !
11/20/2008 5:46:56 PM PROCEDURE WAS STOPPED BY USER
11/20/2008 5:46:56 PM Elapsed: 11 secs.
11/20/2008 5:47:27 PM ChipID:C900,EMP protocol:0401
11/20/2008 5:47:27 PM PHONE STATE: "RETAIL"
11/20/2008 5:47:27 PM FLASH CID: 0052
11/20/2008 5:47:29 PM OTP LOCKED:1 CID:52 PAF:1 IMEI:35507602286982 CERT:RED
11/20/2008 5:47:29 PM LDR:2008-07-23 12:03 CXC1250843_DB31XX_CS_LOADER_ACC_SDRAM_R2A065
11/20/2008 5:47:32 PM LDR:2008-07-23 12:03 CXC1250780_DB31XX_CS_LOADER_APP_SDRAM_R2A065
11/20/2008 5:47:32 PM Model:TM506
11/20/2008 5:47:32 PM MAPP CXC article: R3CA033 prg12033655_TMOUS_BL
11/20/2008 5:47:32 PM MAPP CXC version: R3CA033
11/20/2008 5:47:32 PM Language Package:TMO-US
11/20/2008 5:47:32 PM CDA article: 1207-2630
11/20/2008 5:47:32 PM CDA version: R28A
11/20/2008 5:47:32 PM Default article: 1203-3659
11/20/2008 5:47:32 PM Default version: R3CA033
11/20/2008 5:47:32 PM PROVIDER: 000-00
11/20/2008 5:47:32 PM Network LOCKED
11/20/2008 5:47:32 PM SECURITY UNITS BACKUP CREATED.
11/20/2008 5:47:33 PM Elapsed: 13 secs.
11/20/2008 5:47:58 PM SIGNED MODE (USING SERVER).
11/20/2008 5:47:58 PM ALTERNATIVE SECURITY BYPASS ENABLED.
11/20/2008 5:47:58 PM PRELOADER SECURITY BYPASS ENABLED.
11/20/2008 5:47:58 PM PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5")
11/20/2008 5:48:09 PM ChipID:C900,EMP protocol:0401
11/20/2008 5:48:09 PM BOOTROM MODE DETECTED
11/20/2008 5:48:11 PM OTP LOCKED:1 CID:52 PAF:1 IMEI:35507602286982 CERT:RED
11/20/2008 5:48:13 PM LDR:2008-07-23 11:58 CXC1250778_DB31XX_PRODUCTION_LOADER_APP_SDRAM_R2A0 65
11/20/2008 5:48:13 PM DEVICE KEY:9B24778AB95912F05F07E0CCC839FA47 (1)
11/20/2008 5:48:14 PM LDR:2008-07-23 11:57 CXC1250781_DB31XX_RESET_LOADER_ACC_SDRAM_R2A065
11/20/2008 5:48:15 PM LDR:2008-07-23 11:57 CXC1250782_DB31XX_RESET_LOADER_APP_SDRAM_R2A065
11/20/2008 5:48:20 PM GOT SEED:6C1617C63480046B25601046
11/20/2008 5:48:20 PM P96 AUTH PASSED
11/20/2008 5:48:20 PM RESETTING SECURITY TO FACTORY STATE...
11/20/2008 5:48:21 PM RESTARTING...
11/20/2008 5:48:21 PM PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5")
11/20/2008 5:48:24 PM ChipID:C900,EMP protocol:0401
11/20/2008 5:48:24 PM BOOTROM MODE DETECTED
11/20/2008 5:48:27 PM OTP LOCKED:1 CID:52 PAF:1 IMEI:35507602286982 CERT:BROWN
11/20/2008 5:48:27 PM LDR:2008-07-23 11:59 CXC1250777_DB31XX_PRODUCTION_LOADER_ACC_SDRAM_R2A0 65
11/20/2008 5:48:30 PM LDR:2008-07-23 11:58 CXC1250778_DB31XX_PRODUCTION_LOADER_APP_SDRAM_R2A0 65
11/20/2008 5:48:30 PM WRITING SEMCBOOT...
11/20/2008 5:48:47 PM can't send NET packet
11/20/2008 5:48:47 PM bad SIGN response from phone
11/20/2008 5:48:47 PM can't open file ""
11/20/2008 5:48:47 PM Elapsed: 48 secs.
11/20/2008 5:50:07 PM SIGNED MODE (USING SERVER).
11/20/2008 6:03:05 PM Can't load ID loader !
11/20/2008 6:03:05 PM PROCEDURE WAS STOPPED BY USER
11/20/2008 6:03:06 PM Elapsed: 778 secs.
11/20/2008 6:03:11 PM SIGNED MODE (USING SERVER).
11/20/2008 6:03:46 PM Can't load ID loader !
11/20/2008 6:03:46 PM PROCEDURE WAS STOPPED BY USER
11/20/2008 6:03:46 PM Elapsed: 35 secs. [/QUOT
Old 01-08-2010, 05:06   #2 (permalink)
halongmobile's Avatar
Member: 45580
Set DOMAIN to RED .................OK
Old 01-08-2010, 05:43   #3 (permalink)
jesuraja's Avatar
Member: 626092
See post date and replay here...
Old 01-08-2010, 05:57   #4 (permalink)
malektalha's Avatar
Member: 1062869
triy this
select z780 model and 2click 1.signed mode(server used for bypass/csca if needed 2. enable altrnative security bypass.
use v0.915057.
The Following User Says Thank You to malektalha For This Useful Post:
Old 02-05-2010, 21:28   #5 (permalink)
Member: 46474
TM506 Dead/Black Screen after unlock
tm506 unlock 100% ok, but phone does not turn on only black screen, tried everything on this thread. please help
Old 02-06-2010, 16:39   #6 (permalink)
Member: 9519
unlock process can't do that.
most probably, you had done something other.
unlock phone in altbypass mode, than reflash phone with latest firmware.
if that will not help, check phone hardware.
sonyericsson tm506 after unlock done vodafone sim mohit_kripalu01 SETool2 5 06-26-2010 08:07
tm506 after unlock dead naneurix SETool2 0 11-20-2008 11:12
gd30 after unlock dead rpbongp Panasonic 9 08-03-2005 18:38
v802 after unlocking dead........... lemor Sony Ericsson 0 03-10-2005 07:46
M35 version 20 After Unlock DEAD! JammerOne x1x to x45/x50 5 02-05-2002 21:45
Page generated in 0.27316 seconds with 11 queries
