02-24-2010, 01:24 | #1 (permalink) | |
No Life Poster Join Date: Feb 2006 Location: iraq
Member: 231662 Status: Offline Sonork: 1607488 Thanks Meter: 390 | u1i cant flashing any help Quote:
02-24-2010, 02:09 | #6 (permalink) |
No Life Poster Join Date: Oct 2002 Location: PARIS
Member: 16856 Status: Offline Sonork: 1582037 Thanks Meter: 441 | |
02-24-2010, 02:33 | #8 (permalink) |
Member: 16856 Status: Offline Sonork: 1582037 Thanks Meter: 441 | Gonna cost 1 + 2 credits Read Carefully BR Max_B Code: POSSIBLE PROBLEMS WITH S1 PHONES damaged trim area , imei could not be read, simlocks state "tampered" or "0" first, we need to restore trim area, for that 1. select correct model 2. on settings, check "signed mode","enable alternative security bypass" 3. add to firmware area if you have neptune-based phone - W302_TA.SSW if you have t280,t303,r306,r300,k330,w205,Tilde phone - R300_TA.SSW if you have t250 phone - t250_ta.ssw if you have Z250,z320,t270 phone - z320_ta.ssw if you hace j132 phone - j132_ta.ssw 4. press flash now trim area structure restored and phone should be signed with s1 signature server. it is recommended,though restore phone original imei first, for that: 1. create text file with contents: taread:000107D1 2. select proper model, check on settings only "signed mode", select created file in misc. field 3. press "write script", file will be created in form %imei%.txt 4. looks at file in notepad, you will see imei inside in very simple form, change imei to original and save file 5. select changed file in misc. field and again press write script 6. check with identify if you set correct imei, repeat 4,5 until success now you need unlock phone using signature server, consult corresponding faq post for that. phone simlock okay, not tampered, but phone stucked,slow,rebooting. flashing not help. most probably, internal fs gone to winds. you need write fullflash from working phone or write clean file system, then reflash phone check support area for that files. please note, that all neptune-based phones can be cured with w302_fullflash,etc (check trim area repair case) in most cases, alternative security bypass needed for writing fullflash. |
The Following User Says Thank You to Max_B For This Useful Post: |
02-24-2010, 03:59 | #12 (permalink) | |
Member: 231662 Status: Offline Sonork: 1607488 Thanks Meter: 390 | after press "write script", Quote:
03-01-2010, 13:41 | #15 (permalink) |
Junior Member Join Date: May 2009
Member: 1042320 Status: Offline Thanks Meter: 2 | SIGNED MODE (USING SERVER) CFG:100100000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "GREEN" BUTTON... EROM "R6A032" AID: 0001 SOFTWARE AID: FFFF SIMLOCK STATE: "TAMPERED" LOADER AID: 0002 FLASH ID: "00EC/0040" LOADER VERSION: "R4A012" PHONE IMEI:35681003182557 MINOR ERROR "MISC_ERROR (TA_Invalid_(0x0006))" IN "MISC_CLASS" Elapsed: 14 secs. Phone is showing red light. |
U1i not flashing helpppp | tatarabraham63 | SETool2 | 8 | 03-24-2010 18:13 |
c100 cant get in test mode and cant flash | tattoum | VLSI, Conexant, Skyworks and Old Models | 2 | 01-11-2006 23:58 |
6230i cant flash after mcu flash Write Error ?? | AnToS | Twisterflasher | 16 | 07-13-2005 20:22 |
V800, cant flash Vodafone firmware after Z800 flash | skearon | TOTAL MultiServer | 4 | 05-27-2005 02:00 |
