07-20-2010, 11:05 | #1 (permalink) |
Insane Poster Join Date: Oct 2007
Member: 602413 Status: Offline Thanks Meter: 11 | unlock J10i2 problem with"[a2_shutdown] can't send NET packet" server ip:srv01.dontexist.com user:xxx pass:xxx |
07-21-2010, 11:50 | #3 (permalink) |
Insane Poster Join Date: Apr 2008 Location: london
Member: 745365 Status: Offline Thanks Meter: 13 | j10i2 aka elm successfully done by se tool use the latest version of se tool select in a2 j10_elm in setting tab select signed mode perform full unlock instead of usercode reser disable flash mode activation for semc a2. now connect the phone by pressing button c after the ph will ask for drivers which are located in setool / drivers/modem drivers. finally after installing drivers, phone will get seed. eat your credit and process done.... RUNNING v 1.08/UNI CARD SERIAL 00078080 USBFLASH DRIVER VERSION 02.02.00.05 SIGNED MODE (USING SERVER) CFG:100011000000 ChipID:F100,EMP protocol:0401 PHONE STATE: "RETAIL" FLASH CID: 0080 OTP LOCKED:1 CID:80 PAF:1 IMEI:35987403187741 CERT:RED LDR:2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH SIGNATURE AUTH LDR:2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock. Checking for signature... Waiting for calculation process... RESPONSE: "SUCCESS" [1038] Backup security data... Erasing locks... DISCONNECT PHONE NOW REMOVE SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM29 PHONE READY TO PROCEED. GOT SEED:0037BB96 ACTIVATION COMPLETED. USERCODE RESET TO "0000" Elapsed: 187 secs. SIGNED MODE (USING SERVER) CFG:100011000000 SERVER CREDITS LEFT/USED: 25/5 CARD COUNTERS: FLASH 423, UNLOCK 585 Elapsed: 2 secs. |
The Following User Says Thank You to fairyland For This Useful Post: |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
