Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (Non-Official Support) > SETool2
Old 06-20-2012, 08:09   #1 (permalink)
Member: 1536983
Unlock LT18i failed, maybe is new security? How can I unlock it?
Hello,
I try unclok LT18i, I select (SIGNED MODE, ENABLE ALTERNATIVE SECURITY BYPASS, PERFORM "UNLOCK" INSTEAD OF "USERCODE RESET", USE TESTPOINT ("GND" TYPE).
But it doesnīt work. This is the log:
RUNNING v 1.1287/01.15/UNI
CARD SERIAL 00196098
USBFLASH DRIVER VERSION 02.02.00.05
SIGNED MODE (USING SERVER)
ALTERNATIVE SECURITY BYPASS ENABLED
CFG:110010000010
DETACH USB CABLE FROM PHONE
REMOVE BATTERY FROM PHONE
ATTACH TESTPOINT
PRESS "READY", THEN ATTACH USB CABLE TO PHONE
PROCESSING ...
REMOVE TESTPOINT NOW, THEN PRESS "READY"
qcReceivePacket: can't get packet start.
FAILED TO SETUP PHONE
Unlock FAILED
Elapsed: 50 secs.
Is my phone new security? I canīt unlock with SETOOL? How can I unlock it?
I wait for your help.
Thanks.
Old 06-20-2012, 08:30   #2 (permalink)
xxxman's Avatar
Member: 59185
Sonork: 100.1593175
Setool New Update Released...[s1 signature server working]
The Following User Says Thank You to xxxman For This Useful Post:
Old 06-20-2012, 08:30   #3 (permalink)
Member: 1536983
PLEASE ATTACH TURNED OFF PHONE NOW
PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ...
RUNNING S1_EROM VER "R9B031"
EROM_AID : 0001
LOADER_AID : 0001
SW_AID : 0001
CUST_AID : 0001
SIM_LOCK_AID : 0001
DEVICE ID: DE3BC9D02ECAFC9C8B7654FEA37794CA-------
FLASH ID: "002C/00B3"
LOADER VERSION: "R4A069"
PHONE IMEI : 3526000XXXXXX
MODEL (from GDFS): LT18i
SOFTWARE VERSION: 1253-8238_4.0.2.A.0.62
CUSTOM VERSION: 1255-2667_R8D
FILESYSTEM VERSION: WORLD-i_4.0.2.A.0.62
SERIAL NO: BX902ZGGWX
Elapsed: 76 secs.
Old 06-20-2012, 08:39   #4 (permalink)
Member: 1536983
Sorry, I donīt understand.
Two week ago I spend 20 creditcs for Xperia activation, and now I must to buy a new activation? Or I must to pay for unlock?.
My cardīs log:
CFG:100000000000
short credits consumption list :
S1 v1    06 credits
S1 v2    10 credits
S1 OPEN    03 credits
S1 OPEN AID 004    09 credits
A1 phones    03 credits
A2 phones, CSCA way    03 credits
CID81 A2 phones, FLASHMODE activation way    06 credits
S1 v2 alternative bypass unlock/repair    01 credits
S1 v2 alternative bypass standalone activation  20 credits
W100,W150 codes    01 credits
S1 servers online from 08:00am till 08:00pm (GMT+8)
You  CAN NOT unlock next phones without S1 servers:
u1/u5/u8 aid 004,
F305,J132,K330,R300,R306,S302,S312,T250,T280,T303,W205,W302,
W395,Z250,Z320 phones with damaged security zone,
W395,Z250,Z320 aid 004,
w100,w150 full unlock,
ck13,ck15,lt26,wt13,
lt26,
lt22,st25,mt27.
current updater version: 0.95
current setool2 version: 1.1288
SERVER CREDITS LEFT/USED: 10/20
CARD COUNTERS: FLASH 9, UNLOCK 11
Elapsed: 2 secs.
Old 06-20-2012, 15:16   #5 (permalink)
Member: 589304
only check test point of the phone and repeat the operation
Old 06-20-2012, 15:56   #6 (permalink)
Member: 1536983
Test point is well done. Already my pc detects new hard and I installed the first time Zeus driver.
Thanks.
Old 06-20-2012, 16:09   #7 (permalink)
Member: 589304
i have the same problem Please make sure there is no contact in test point when program
say REMOVE TESTPOINT NOW, THEN PRESS "READY
just check it
Old 06-20-2012, 16:41   #8 (permalink)
Member: 1536983
just check it
I follow perfectly all steps but it doesnīt work.
Wheh it says remove test point, I removed all test point and then I press ready.
This is the error with second Phone
FATAL ERROR [ SECURITY_CLASS, SIN_header_verification_failed ]
error while uploading HDR block
LOADER NOT STARTED
And this is the error with first phone:
Unlock FAILED
Elapsed: 103 secs.
When I remove test point and press ready, then I must insert the battery and pressing hold back or volume down, then it charing
"RUNNING S1_EROM VER "R9B031"
EROM_AID : 0001
LOADER_AID : 0001
SW_AID : 0001
CUST_AID : 0001
SIM_LOCK_AID : 0001
and then it says
LOADER NOT STARTED
Unlock FAILED
Elapsed: 86 secs.
Old 06-20-2012, 17:06   #9 (permalink)
Member: 1536983
Please, can you show me a photo of cable that I need?
Iīm using the original data cable of phone, usb to micro-usb and select port usb on setool.
When I do identify,it shows the correct info.
Thanks.
Old 06-20-2012, 17:18   #10 (permalink)
Member: 589304
from the beginning don't use battery only cable usb and test point
When program say remove test point and press ready
remove test point
and press ready
The Following User Says Thank You to imadzid For This Useful Post:
Old 06-20-2012, 17:38   #11 (permalink)
Member: 1536983
I got it with 12w11, but phone with 12w21 says
Unlock FAILED
Elapsed: 36 secs.
Thanks.
Old 06-20-2012, 19:20   #12 (permalink)
yarra's Avatar
Member: 493205
Sonork: 100.1581647
Originally Posted by javsp1 View Post
i got it with 12w11, but phone with 12w21 says
qcreceivepacket: Can't get packet start.
Failed to setup phone
unlock failed
elapsed: 36 secs.
thanks.
yes its new security .
Old 11-11-2012, 12:20   #13 (permalink)
Member: 1421995
Sonork: TARIK GSM
Old 11-12-2012, 21:13   #14 (permalink)
Member: 1704846
Sonork: 1617108
If you properly connect testpoint it you phone new security and need buy NCK code to unlock.
Old 11-23-2012, 19:19   #15 (permalink)
Member: 171634
Lt18 i with correct test point . 0001 loader cost only 1 credit
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 8 05-21-2013 19:20
New Nokia Software!!!!!!! Jefferson Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 73 05-15-2013 13:07
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 28 08-30-2012 03:40
Page generated in 0.37764 seconds with 11 queries
