Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SETool2
Old 03-30-2010, 01:24   #1 (permalink)
beneto's Avatar
Member: 148833
Thanks Meter: 25
Thumbs up I uesd to use Cruiser..Hi SETOOL-Team:How to unlock k550im cid52 ? step by step
I'm new with SETOOL, I used to use CRUISER..! I wanna unlock k550im cid 52,step by step,please !
The Following User Says Thank You to beneto For This Useful Post:
Old 03-30-2010, 01:52   #2 (permalink)
-=Meltech09=-'s Avatar
Member: 1084363
Thanks Meter: 109
@beneto,
you are almost 5 years here in GSm City..
but you dont even know how to unlock that kind of phone..
and one more thing please try to make a little bit more clear
you are new in Setool but you are asking support for cruiser..????
Old 03-30-2010, 08:13   #3 (permalink)
Registered User
Member: 437195
Thanks Meter: 1,734
Some mistake with him....
Old 03-30-2010, 08:49   #4 (permalink)
NawabN Sahoo's Avatar
Member: 687312
Thanks Meter: 290
Mate here is complete Vedio Tutorial of SEtool you can learn all from this Tutorial .
4shared.com - online file sharing and storage - download VIDIO TUTORIAL SE TOOL SOLUTION ALL IN ONE exe.rar
WBR
The Following User Says Thank You to NawabN Sahoo For This Useful Post:
Old 03-30-2010, 19:34   #5 (permalink)
beneto's Avatar
Member: 148833
Thanks Meter: 25
Where is the problem with 5years ??? I should know eveything & every box on GSM.Hosting ?!?Please,if you have something to share,you will be thanked if not you'll be thanked as well.Till now no one has given an exact answer to my question ?
Old 03-30-2010, 20:06   #6 (permalink)
Member: 687312
Thanks Meter: 290
Mate you could do easily according video tutorial anyway follow these steps:
1_ Choose your model and select usb as interface
2_Go to setting tab and tick mark on Sign mode and Full unlock instead of usercode
3_ Come back SonyEricsson tab press Unlock\Repair button and press C button of phone and inser usb cable
4-Now software will ask you to remove cable and insert a test sim or its original simcard and turn on phone in normal mode and inserst cable
5_ PC will asl driver and you must install driver from your models sign mode drivers folder(you can download it from support)
6_when drivers installed after some process software will ask you again to removethe cable and attach turn off phone by pressing C.
It was step by step unlocking process.
WBR
Old 03-30-2010, 21:19   #7 (permalink)
mscomp's Avatar
Member: 266158
Sonork: 131654654654
Thanks Meter: 198
very easy flash it with k550 only not im and unlock with patch
because k550im not suported unlock with patch
Old 03-30-2010, 23:50   #8 (permalink)
beneto's Avatar
Member: 148833
Thanks Meter: 25
Manner of how to unlock a handset on Video tutorial are very old they belongs to 0.914013 versionas the settings are very different from that of 1.01 !?!?..Mr.NawabN has well explained the procedure and ought to be thanked for that but this procedure is not correct for k550im !? I do so and now my handset has no network !?!?!?
Old 03-31-2010, 00:50   #9 (permalink)
Max_B's Avatar
Member: 16856
Sonork: 1582037
Thanks Meter: 441
Man why so many talk ?
Use Setool2 V1.xx version
Don't add your login details !
Go to Empty fill tab set model "K550"
Go to settings and tick Signed Mode
Go to Empty fill tab press Recovery
Connect phone to USB Hold 2+5 keys
Click ADD and set a K550 GDFS.SSW from SETOOL\GDFS folder
Press Flash
Click Remove and repeat the operation with Erom (DB2020 CID53)
Press Flash
Phone is Full Unlocked for Free and working again !
100% Tested & Working, this is not cruiser section
Max_B
Old 05-08-2010, 13:08   #10 (permalink)
Member: 1039966
Thanks Meter: 148
Phone say sim card not correct
Press Flash
Press Flash
Max_B
In the info after make all the operation you said gives me lock : not detected
but then i put the sim card and dont accepted one diferent sim card and the origibnal too
now dont acepted any sim card, wht i do?
Guide: How to Activate SETOOL Step by Step shahzaadbutt SETool2 66 06-15-2023 11:12
How to unlock k550im cid52 ? beneto Cruiser Suite 2 03-31-2010 09:14
how to use cruiser with SE A1 Java Unlocker plz help amanhalwara Cruiser Suite 3 05-07-2009 02:30
Step by Step how to Unlock BB5 Phone Using BB5BOX By Raskal Ron2pet BB5BOX 12 09-21-2007 09:54
step by step method to unlock swith setool with credit a2b2t Sony Ericsson 6 07-25-2007 05:51
Page generated in 0.24236 seconds with 9 queries
