Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: May 2008
Member: 783315 Status: Offline Sonork: 100.1588917 Thanks: 13
| urgent help needed dead w350 after unlock hi i got a new w350i it was locked to vodafone with the new setool v0.915032, i unlocked it directly went dead ,so i flashed it fine ,but after the battery went down, i charged it the battery has power but the phone its dead its urgent pls help thanx in advance nikki |
| | #4 (permalink) | |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2008 Location: INSIDE OCLHASHCAT
Member: 751235 Status: Offline Sonork: 100.1623281 Thanks: 35
| easy solution ![]() Quote:
open your setool programe... select fone ,,go to settings.. tick 1 Enable Altenative security Bypass 2 enable Preloader Bypass then click on unlock and repair.. problem solve...if not post your logs here | |
| | #5 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Sep 2007
Member: 593491 Status: Offline Thanks: 217
| i have solved it dear i have solved that same problem,,need u full flash with same version without unlock ur phone will be on then u can do unlock again. |
| | #6 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2008 Location: RVIII
Member: 890926 Status: Offline Thanks: 95
| Before any Unlock procedure you must Check if Rest file & Bypass Package is available by clicking Identify & also to Backup Security Values. |
| | #9 (permalink) |
| Insane Poster ![]() ![]() ![]() Join Date: Jul 2005 Location: SCOTLAND
Member: 164780 Status: Offline Thanks: 50
| Completly dead I have had this problem a few times before and its fixed with a simple flash but i now have one that is completely dead, cant flash as it wont even attach at all? Sorry dont have log any more, but i had no rest file but bypass package avalible, had signed mode, enable alternative security, complete after flash, unlock during flash and, format gdfs when writing, as allways. ran trough ok as normal, picked up at com ports and when it asked me to disconnect, press ready and re-attach, it would not attach and was dead. anyone any ideas on this one? I know how to fix it once its on se but my problem is with getting it attached in the first place. Thanks in advance |
| The Following User Says Thank You to somden For This Useful Post: |
| | #10 (permalink) |
| Just to let you's know, got it sorted, if anyone else has this problem, i managed to attach and flash it with the rj45 cable from setool box. Signed mode, complete after flash and format gdfs ticked ![]() PHONE STATE: "RETAIL" FLASH CID: 0053 skipping empty loader... OTP: LOCKED:1 CID:52 PAF:1 IMEI:35438802059632 CERT:RED Model (from GDFS):W350i Brand:Orange MAPP CXC article: R10BA015 prg1205-7400_ORANGE_JH MAPP CXC version: R10BA015 Language Package: ORANGE_GEN CDA article: 1209-0649 CDA version: R3A Default article: 1204-3119 Default version: R10BA015 PROVIDER: 234-33 Network LOCKED RESTORATION FILE NOT PRESENT "R10BA015_1205-7400_ORANGE_JH" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE SECURITY UNITS BACKUP CREATED. Elapsed: 11 secs. SIGNED MODE (USING SERVER) CFG:100010000010000 ChipID 000,EMP protocol:0301PHONE STATE: "RETAIL" FLASH CID: 0053 Speed:921600 OTP: LOCKED:1 CID:52 PAF:1 IMEI:35438802059632 CERT:RED LDR:071213 1552 PERCXC1720441_R2A022_PNX5230_FLASHLOADER Flash ID check:897E Flash props sent ok writing "C:\Documents and Settings\Desktop\Unlocking\setoolflash\W350i red53\r10ba015_app_sw_1204_3117_generic_jh_red_cid 53_pnx5230.software" CURRENT FLASH FILE CID:53 SSW uses full hash, hash len is: 9600 Will flash 480 blocks... SSW loading returns:0 writing "C:\Documents and Settings\Desktop\Unlocking\setoolflash\W350i red53\r10ba015_fs_cent_europe_jh_red_cid53.softwar e" CURRENT FLASH FILE CID:53 SSW uses full hash, hash len is: 2740 Will flash 137 blocks... SSW loading returns:0 LDR:070904 1356 AN2CXC1250610_R3A016_PNX5230_CSLOADER loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed using GENERIC phone customization tpa/preset/custom/C3_PCA_G3v2.cer tpa/preset/custom/CONTENT_DOWNLOAD_HOOK_2.itm tpa/preset/custom/customize.xml tpa/preset/custom/DESKTOP_HOOK_2.itm tpa/preset/custom/Entrust.net Root Certificate.cer tpa/preset/custom/Entrust.net_WTLS_Root_Certificate.wcrt tpa/preset/custom/FM_PICTURES_HOOK_3.itm tpa/preset/custom/FM_SOUNDS_HOOK_3.itm tpa/preset/custom/FM_THEMES_HOOK_3.itm tpa/preset/custom/FM_VIDEOS_HOOK_3.itm tpa/preset/custom/GAMES_HOOK_3.itm tpa/preset/custom/GTE_CyberTrust_Root.cer tpa/preset/custom/GTE_Cybe_Trust_Root_WTLS.wcrt tpa/preset/custom/Root.cer tpa/preset/custom/SEMC_E2E_Root_CA.crt tpa/preset/custom/SETT_RINGTONE_HOOK_3.itm tpa/preset/custom/ThawtePremium.der tpa/preset/custom/ThawteServerCA.cer tpa/preset/custom/Utiroot.cer tpa/preset/custom/VeriSignClass3Root.cer tpa/preset/custom/Verisign_Class_3_CA_WTLS.wcrt Phone detached Elapsed: 746 secs. SIGNED MODE (USING SERVER) CFG:100010000010000 PROCEDURE WAS STOPPED BY USER Can't load ID loader ! Elapsed: 212 secs. SIGNED MODE (USING SERVER) CFG:100010000010000 PROCEDURE WAS STOPPED BY USER Can't load ID loader ! Elapsed: 108 secs. |
| The Following 2 Users Say Thank You to somden For This Useful Post: |
| | #11 (permalink) |
| Hi, problem sovled Hi guys i deleted the executor after that the phone was not dead tried 100% thanx for your help b.r. Nikki |
| | #12 (permalink) | |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Apr 2008 Location: Dublin
Member: 746630 Status: Offline Thanks: 76
| Quote:
| | #13 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Sep 2005 Age: 39
Member: 178616 Status: Offline Thanks: 125
| ANY BODY HELP ME I WANT TO FLASH MY PHONE BUT GIVE THIS ERROR erom_readvar: can't read all data erom_readvar: error reading unit 1/851 error while reading SIMLOCK SIGNATURE unit phone was tampered with other software SECURITY UNITS CAN'T BE READ ! DAMAGED FIRMWARE,GDFS OR EMPTY PHONE CONTINUE ON YOUR OWN RISK PHONE STATE: "RETAIL" FLASH CID: 0053 Speed:921600 HERE IS PRE LOGS INFO WHEN PHONE WAS OK Model (from GDFS):W350a Brand:ATT MAPP CXC article: R11BA004 prg1205-7398_CINGULAR_JH MAPP CXC version: R11BA004 Language Package: CINGULAR CDA article: 1209-2727 CDA version: R14A Default article: 1204-3119 Default version: R11BA004 PROVIDER: MULTIPLE Network LOCKED RESTORATION FILE NOT PRESENT "R11BA004_1205-7398_CINGULAR_JH" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Need Urgent help about dead MP4 | danishrehmanzai | Game Consoles & Mp3/4 , HD players | 1 | 08-06-2009 06:38 |
| w350 after unlock phone dead, help me | jahfartv | Sony Ericsson | 1 | 07-29-2009 03:46 |
| w910i dead with A2 1 key unlocker==Urgent help needed | leomaxuk | Seking Server | 2 | 11-22-2008 13:35 |
| Urgent HELP needed..!!! about DB2020 after change FLASH IC | spinegy | Sony Ericsson Hardware Repair Area | 0 | 08-14-2008 06:48 |
| d500 DEAD- URGENT help needed | .:GSM International:. | TST Dongle | 10 | 08-12-2005 02:31 |
