12-22-2008, 06:53 | #1 (permalink) |
No Life Poster Join Date: Nov 2008 Location: pakistan
Member: 898041 Status: Offline Sonork: 100.1593459 Thanks Meter: 549 | urgent seetool hdr block not accepted,error a9 CARD SERIAL: 00036593 Loaded 51 flash descriptors PROCEDURE WAS STOPPED BY USER Can't load ID loader ! Elapsed: 1 secs. Connecting to UFS... Found 1 FTDI device(s). UFS #75056 READY ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 Flash ID check:890D Flash props sent ok OTP: LOCKED:1 CID:49 PAF:1 IMEI:xxxxxxxxxxxxxx CERT:RED FLASH CID:49 COLOR:RED Model:K750ix Brand:Generic MAPP CXC article: R1DB001 prgCXC125955_HONG_KONG_CL MAPP CXC version: R1DB001 Language Package:EMEA_1 CDA article: CDA102295/1 CDA version: R2A Default article: cxc125953 Default version: R1DB001 PROVIDER: 000-00 SIMLOCKS NOT DETECTED USERCODE:0000 RESTORATION FILE PRESENT FOR DETECTED FIRMWARE Elapsed: 12 secs. ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 OTP: LOCKED:1 CID:49 PAF:1 IMEI:xxxxxxxxx CERT:RED REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS "READY" Trying to launch embedded bootloader... INT LDR:COMPACT_ID_LOADER_CRIPPLED_SETOOL2_R2 LDR:041214 0816 LLECXC1326743_COMPACTPRODUCTION R2AB Flash ID check:890D Flash props sent ok FOUND VERSION "R1DB001_CXC125955_HONG_KONG_CL" HDR block not accepted,error: A9 how slove this problem any body help me. |
The Following User Says Thank You to shamshad quresh For This Useful Post: |
12-22-2008, 08:50 | #5 (permalink) | |
No Life Poster Join Date: Nov 2005 Location: .:GSM WORLD:.
Member: 203158 Status: Offline Sonork: 100.1592032 Thanks Meter: 358 | Quote:
Bro the only thing u need to do is Locate this "R1DB001_CXC125955_HONG_KONG_CL" rest file and replace it with Good one .. ur problem will be solve........ | |
12-22-2008, 09:25 | #6 (permalink) | |
No Life Poster Join Date: Nov 2003 Location: srilanka Age: 51
Member: 44229 Status: Offline Sonork: 1592530 Thanks Meter: 366 | Quote:
br. | |
The Following User Says Thank You to gsmbac For This Useful Post: |
12-23-2008, 15:23 | #8 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Rawalpindi, Pakistan
Member: 421117 Status: Offline Sonork: +92 346 5544377 (PHONE) Thanks Meter: 2,522 | HDR block not accepted,error: A9 this error always occur with bad rest file even though set fully flashed and powered on. |
HDR block not accepted,error: 19 | mobilezclinic | SETool2 | 6 | 07-28-2012 09:19 |
K750i...HDR block not accepted,error:A9 | kamransohail786 | SETool2 | 7 | 12-09-2011 12:08 |
W700 HDR block not accepted,error: A9 | kiran | SETool2 | 2 | 03-27-2010 15:18 |
w550 flashing error HDR block not accepted,error: 0E | neeraj1st | SETool2 | 4 | 01-23-2010 07:44 |
help W850 after DGFS Repair HDR block not accepted,error: 19 | sniper007 | SETool2 | 2 | 03-11-2009 18:56 |
