Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SETool2
Old 02-14-2010, 05:46   #16 (permalink)
saif@cellplus's Avatar
Member: 26488
Sonork: 100.1581233
Thanks Meter: 151
Originally Posted by Rashky View Post
what is this
RUNNING v0.915060/UNI
CARD SERIAL 000xxxxx
PLEASE UPGRADE USBFLASH DRIVER 00.00.00.00
i've already install the driver ggsetup-2.2.0.6
just identify any phone through USB, it will ok..
BR,
Saif.
Old 02-14-2010, 12:45   #17 (permalink)
atiq022's Avatar
Member: 587405
Sonork: 100.1681610
Thanks Meter: 151
what is the difference between cable dcu 60 and dcu 65 plzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz explain
Old 02-14-2010, 16:29   #18 (permalink)
Member: 879095
Thanks Meter: 2
Mr. Laser what about this update!
When i Connect phone with C or 2+5 My pc detect "flash device" and HANG!
I try to instal: ggsetup-2.2.0.6.exe and before ggsetup-2.2.0.5.exe- but it didn`t help me!
Firstly when i want to open SETool i had seen error with missing in ddl file, but i download from 3 other links- now i CAN START this program, i`m using KIS 9- I`m add Exception exclusion from Scan in KIS but it didnt work for me.
I do everything what you wrote in this post:
http://forum.gsmhosting.com/vbb/show...98&postcount=4
In this moment i can connect any SE phone- PC come to hang and SETool won`t start (*60 version, older *59 working fine)
Please help me
Best Regards
Adrian
Old 02-15-2010, 01:13   #19 (permalink)
Member: 1071056
Thanks Meter: 897
Here all included just install and run,,,,,,
V0.915060 all included
http://www.4shared.com/file/22079910...OL0915060.html
The Following 3 Users Say Thank You to bestin For This Useful Post:
Old 02-15-2010, 03:24   #20 (permalink)
Member: 585061
Thanks Meter: 10
what is this
ive got the same error too........even i connect phone to pC,it can identify but still gives this message" PLEASE UPGRADE USBFLASH DRIVER 00.00.00.00"
i restarted my pc but when i connect phone to my Pc and identify it, it gives that error....
Old 02-15-2010, 05:05   #21 (permalink)
ROEZT's Avatar
Member: 508048
Thanks Meter: 123
sir my pc blue screen what happenned....
Old 02-15-2010, 06:37   #22 (permalink)
Member: 1116719
Thanks Meter: 542
Originally Posted by Amir-SkillZ View Post
Hello,
Starting from GUI V60 of Setool ... User Needed to remove Old Setup of Drivers From PC In Order to Avoaid USB Driver Upgrade Error
When New Setup from Below Link will be launched Old Drivers will be checked and Asked for Removal Kindly Do So in Order to Proceed
Install New Gordon Gate Drivers From Your DIST Arhcive
v0.915060\drivers\USBFlash_driver\ggsetup-2.2.0.6.exe
Now connect any Phone to PC holding C Drivers will be Reasked and Got Upgraded Now Reopen SEtool u will see new Driver version Installed Ready.
if setool2 software complains for missing .dll file, please either reload version from support area or rapidshare link or extract attached file into setool2g.exe directory.
Thankx for Your Time ..
sir i install ggsetup-2.2.0.6 but . see this error PLEASE UPGRADE USBFLASH DRIVER 01.01.00.0C
The Following User Says Thank You to >>.123.<< For This Useful Post:
Old 02-15-2010, 07:09   #23 (permalink)
Member: 1116719
Thanks Meter: 542
i install not work PLEASE UPGRADE USBFLASH DRIVER 01.01.00.0C
Old 02-15-2010, 07:50   #24 (permalink)
lahdache's Avatar
Member: 820444
Sonork: 100.1680641
Thanks Meter: 466
thank's .
like this :
CARD SERIAL : lahdache
USBFLASH DRIVER VERSION 02.02.00.05
CFG:000000000000
ChipID000,EMP protocol:0301.
lahdache
Old 02-15-2010, 07:55   #25 (permalink)
Member: 1116719
Thanks Meter: 542
Originally Posted by lahdache View Post
thank's .
like this :
CFG:000000000000
lahdache
yes
yes
Old 02-15-2010, 08:58   #26 (permalink)
vmin81's Avatar
Member: 304251
Thanks Meter: 789
i have same errorrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr
CARD SERIAL 0000xxxx
Old 02-15-2010, 09:14   #27 (permalink)
lahdache's Avatar
Member: 820444
Sonork: 100.1680641
Thanks Meter: 466
100/100
1- extract V0.915060 in setool folder
2- go to /
c:/ program file \setool / drivers\USBFlash_driver\ggsetup-2.2.0.6.exe
and Install Drivers.
3- open soft
4- connect any phone to and enjoy.
lahdache
The Following 6 Users Say Thank You to lahdache For This Useful Post:
Old 02-15-2010, 09:20   #28 (permalink)
vmin81's Avatar
Member: 304251
Thanks Meter: 789
100/100
2- go to /
3- open soft
lahdache
i do it bro but the still the message found
Old 02-15-2010, 10:09   #29 (permalink)
Member: 1116719
Thanks Meter: 542
just past / system32
http://forum.gsmhosting.com/vbb/atta...8&d=1266057741
its ok i test 100% ok
The Following 3 Users Say Thank You to >>.123.<< For This Useful Post:
Old 02-16-2010, 14:14   #30 (permalink)
Member: 7248
Thanks Meter: 10
i have sam problem
i uninstall old driver and install new but sam
CARD SERIAL 0012xxx
...:::All Sharp USB Driver Here...::: BURHANLAHERI Sharp 4 04-22-2011 17:07
...::: P2K Easy Tool v5.3 - full flash read/write :::... zulea Motorola P2K (USB-Smart) 19 07-17-2006 22:31
Page generated in 0.22564 seconds with 11 queries
