01-06-2009, 16:19 | #1 (permalink) |
Freak Poster Join Date: Nov 2008 Location: pakistan Age: 37
Member: 896397 Status: Offline Sonork: 100.1603751 Thanks Meter: 91 | V630 successfully unlocked here is the log 1/3/2009 8:32:07 AM PHONE STATE: "RETAIL" 1/3/2009 8:32:07 AM FLASH CID: 0052 1/3/2009 8:32:07 AM Speed:921600 1/3/2009 8:32:07 AM Flash ID check:897E 1/3/2009 8:32:07 AM Flash props sent ok 1/3/2009 8:32:07 AM OTP: LOCKED:1 CID:51 PAF:1 IMEI:35463901245186 CERT:RED 1/3/2009 8:32:07 AM FLASH CID:52 COLOR:RED 1/3/2009 8:32:09 AM 1/3/2009 8:32:09 AM Model:V630i 1/3/2009 8:32:09 AM Brand:Vodafone 1/3/2009 8:32:09 AM MAPP CXC article: R1JC002 prgCXC1250556_VODAFONE_MW 1/3/2009 8:32:09 AM MAPP CXC version: R1JC002 1/3/2009 8:32:09 AM Language Package:VFE_LIVE_2 1/3/2009 8:32:09 AM CDA article: CDA102514/23 1/3/2009 8:32:09 AM CDA version: R7A 1/3/2009 8:32:09 AM Default article: cxc1250557 1/3/2009 8:32:09 AM Default version: R1JC002 1/3/2009 8:32:09 AM PROVIDER: 234-15 1/3/2009 8:32:09 AM Network LOCKED 1/3/2009 8:32:09 AM 1/3/2009 8:32:09 AM RESTORATION FILE PRESENT FOR DETECTED FIRMWARE 1/3/2009 8:32:09 AM 1/3/2009 8:32:09 AM BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE 1/3/2009 8:32:09 AM 1/3/2009 8:32:09 AM SECURITY UNITS BACKUP CREATED. 1/3/2009 8:32:09 AM Elapsed: 9 secs. 1/3/2009 8:32:27 AM SIGNED MODE (USING SERVER) 1/3/2009 8:32:27 AM ALTERNATIVE SECURITY BYPASS ENABLED. 1/3/2009 8:32:27 AM PRELOADER SECURITY BYPASS ENABLED. 1/3/2009 8:32:33 AM ChipID:9900,EMP protocol:0301 1/3/2009 8:32:33 AM 1/3/2009 8:32:33 AM PHONE STATE: "RETAIL" 1/3/2009 8:32:33 AM FLASH CID: 0052 1/3/2009 8:32:33 AM Speed:921600 1/3/2009 8:32:33 AM OTP: LOCKED:1 CID:51 PAF:1 IMEI:35463901245186 CERT:RED 1/3/2009 8:32:33 AM FLASH CID:52 COLOR:RED 1/3/2009 8:32:34 AM PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 1/3/2009 8:32:35 AM LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 1/3/2009 8:32:35 AM Flash ID check:897E 1/3/2009 8:32:35 AM Flash props sent ok 1/3/2009 8:32:38 AM LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 1/3/2009 8:32:38 AM loader startup: executed 1/3/2009 8:32:51 AM loader GDFS startup: executed 1/3/2009 8:32:57 AM loader filesystem startup: executed 1/3/2009 8:32:57 AM loader unlock: executed 1/3/2009 8:33:03 AM 1/3/2009 8:33:03 AM DISCONNECT PHONE NOW 1/3/2009 8:33:03 AM INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN 1/3/2009 8:33:03 AM INSTALL PHONE MODEM DRIVERS IF NEEDED 1/3/2009 8:33:03 AM 1/3/2009 8:33:03 AM SEARCHING FOR PHONE, "STOP" TO ABORT 1/3/2009 8:38:25 AM PHONE FOUND AT COM28 1/3/2009 8:38:32 AM PHONE READY TO PROCEED 1/3/2009 8:38:47 AM EXECUTOR STARTED 1/3/2009 8:38:47 AM 1/3/2009 8:38:47 AM REMOVE CABLE FROM PHONE 1/3/2009 8:38:47 AM REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK 1/3/2009 8:38:47 AM THEN PRESS "READY" 1/3/2009 8:38:54 AM 1/3/2009 8:39:01 AM ChipID:9900,EMP protocol:0301 1/3/2009 8:39:02 AM 1/3/2009 8:39:02 AM PHONE STATE: "RETAIL" 1/3/2009 8:39:02 AM FLASH CID: 0052 1/3/2009 8:39:02 AM Speed:921600 1/3/2009 8:39:02 AM Trying to launch embedded bootloader... 1/3/2009 8:39:03 AM INT LDRB2020_PRELOADER_FOR_SETOOL2 1/3/2009 8:39:04 AM LDRB2020 LOADER FOR SETOOL2 1/3/2009 8:39:04 AM Flash ID check:897E 1/3/2009 8:39:04 AM Flash props sent ok 1/3/2009 8:39:15 AM FOUND VERSION "R1JC002_CXC1250556_VODAFONE_MW" 1/3/2009 8:39:25 AM USERCODE RESET TO "0000" 1/3/2009 8:39:25 AM Searching... 1/3/2009 8:39:27 AM Firmware SIMLOCK check determined. 1/3/2009 8:39:37 AM Unlock DONE 1/3/2009 8:39:37 AM Elapsed: 429 secs. |
E75 Success Unlock!!! | jr astigin | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 03-29-2010 11:19 |
Post Here Successfully unlocked using SE A1 Fast Java unlocker | bhart | Cruiser Suite | 90 | 01-27-2009 22:07 |
..:::Post here unlock UST-PRO2 Successfully Unlock with Screenshot & Instructions::.. | SANGURAN_BOX | UST Pro II | 1 | 07-19-2008 07:57 |
v630 cant unlock in cruiser | ramesh_931 | Cruiser Suite | 4 | 07-17-2007 07:50 |
