06-12-2009, 09:05 | #1 (permalink) |
Freak Poster Join Date: Sep 2006
Member: 356169 Status: Offline Thanks Meter: 34 | w880i unlock CARD SERIAL: Loaded 51 flash descriptors Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 Flash ID check:2019 Flash props sent ok OTP LOCKED:1 CID:51 PAF:1 IMEI:....9602304943 CERT:N/A FLASH CID:52 COLOR:RED Model:W880i Brand:Generic Trade MAPP CXC article: R8BC004 prgCXC1250640_GENERIC_AI MAPP CXC version: R8BC004 Language Package:EUROPE_4 CDA article: CDA102568/13 CDA version: R4A Default article: cxc1250651 Default version: R8BC004 PROVIDER: 234-15 Network LOCKED RESTORATION FILE NOT PRESENT "R8BC004_CXC1250640_GENERIC_AI" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE Elapsed: 9 secs. SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. PRELOADER SECURITY BYPASS ENABLED. Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:35159....943 CERT:N/A FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:2019 Flash props sent ok ALTERNATIVE SECURITY BYPASS ONLY SUPPORTED ON DCU60 ! Elapsed: 11 secs. SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. PRELOADER SECURITY BYPASS ENABLED. Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 Flash ID check:2019 Flash props sent ok OTP LOCKED:1 CID:51 PAF:1 IMEI:35159602304943 CERT:N/A FLASH CID:52 COLOR:RED Model:W880i Brand:Generic Trade MAPP CXC article: R8BC004 prgCXC1250640_GENERIC_AI MAPP CXC version: R8BC004 Language Package:EUROPE_4 CDA article: CDA102568/13 CDA version: R4A Default article: cxc1250651 Default version: R8BC004 PROVIDER: 234-15 Network LOCKED SEARCH:\R8BC004_1250640_GENERIC_AI\R8BC004_12506 40_GENERIC_AI.ssw "R8BC004_CXC1250640_GENERIC_AI" CREATED BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE Elapsed: 87 secs. SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. PRELOADER SECURITY BYPASS ENABLED. Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:35159602304943 CERT:N/A FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:2019 Flash props sent ok ALTERNATIVE SECURITY BYPASS ONLY SUPPORTED ON DCU60 ! Elapsed: 15 secs. SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. PRELOADER SECURITY BYPASS ENABLED. Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:35159602304943 CERT:N/A FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:2019 Flash props sent ok ALTERNATIVE SECURITY BYPASS ONLY SUPPORTED ON DCU60 ! Elapsed: 21 secs. pls help |
06-12-2009, 10:21 | #5 (permalink) | |
No Life Poster Join Date: Mar 2008 Location: London
Member: 722656 Status: Offline Sonork: 100.1584918 Thanks Meter: 294 | Quote:
so just use a usb cable and ur problem will be solved. | |
The Following 2 Users Say Thank You to sniper007 For This Useful Post: |
06-12-2009, 16:54 | #7 (permalink) |
Member: 356169 Status: Offline Thanks Meter: 34 | v0.914034/UNI CARD SERIAL: 0000000000000000000 Loaded 51 flash descriptors SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. PRELOADER SECURITY BYPASS ENABLED. ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:52 Speed:921600 Flash ID check:2019 Flash props sent ok OTP LOCKED:1 CID:51 PAF:1 IMEI:35159602304943 CERT:RED FLASH CID:52 COLOR:RED Model:W880i Brand:Generic Trade MAPP CXC article: R8BC004 prgCXC1250640_GENERIC_AI MAPP CXC version: R8BC004 Language Package:EUROPE_4 CDA article: CDA102568/13 CDA version: R4A Default article: cxc1250651 Default version: R8BC004 PROVIDER: 234-15 Network LOCKED RESTORATION FILE PRESENT FOR DETECTED FIRMWARE BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE SECURITY UNITS BACKUP CREATED. Elapsed: 18 secs. SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. PRELOADER SECURITY BYPASS ENABLED. ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:52 Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:35159602304943 CERT:RED FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:2019 Flash props sent ok LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed DISCONNECT PHONE NOW INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN BE SURE THAT YOU SET PHONE IN "PHONE MODE" IF ASKED, INSTALL PHONE DRIVERS SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM7 SIM CARD NOT PRESENT IN PHONE OR PIN NOT ENTERED. Elapsed: 622 secs. pls help |
06-12-2009, 17:32 | #8 (permalink) |
Member: 722656 Status: Offline Sonork: 100.1584918 Thanks Meter: 294 | which network the phone is lock to and do u have the sim from that network or test sim. you have to have one of these two when it says "DISCONNECT PHONE NOW INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN BE SURE THAT YOU SET PHONE IN "PHONE MODE" IF ASKED, INSTALL PHONE DRIVERS" just disconnect the phone remove battery insert the sim to which the phone is locked or the test sim turn on the phone completely then insert the usb cable and select phone mode. know if you r unlocking this model for the first time on ur computer it will ask for the drivers so u need to install the driver which u can get from setool support website and then just read the instruction from the software it will tell you what to do next just read and follow. BR |
06-12-2009, 18:09 | #10 (permalink) |
Member: 722656 Status: Offline Sonork: 100.1584918 Thanks Meter: 294 | when u plag in the cable it will give u 2 options to select and the second one is phone mode, just select the 2nd option. if you have the phone now add me to msn and i will help u from there. [email protected] |
06-13-2009, 02:10 | #13 (permalink) | |
Freak Poster Join Date: Oct 2008 Location: antipolo philippines Age: 41
Member: 882142 Status: Offline Thanks Meter: 380 | Quote:
just follow the instruction sir, you need test sim or the accepted sim.... then after that, don't forget to delete the executor in games folder of the phone.... | |
The Following User Says Thank You to echizenjohn For This Useful Post: |
W880i Unlocking ? | mp3hot | SETool2 | 11 | 09-20-2007 08:19 |
k800,w850i,w880i unlocker?????????? | moneyg1 | Sony Ericsson | 3 | 08-15-2007 19:26 |
Need w880i unlocked via IMEI anyone reccomend | gazt | Sony Ericsson | 0 | 04-15-2007 22:37 |
w880i unlock sim lock ??? HOW please explain | platinumLA | Universalbox | 2 | 03-30-2007 14:11 |
