09-06-2010, 10:45 | #1 (permalink) |
Product Supporter Join Date: Sep 2006 Location: Kerala-India Age: 46
Member: 351924 Status: Offline Thanks Meter: 12,469 | Very strange problem k310 cid50 I CHECK MANNULY LOCK SYSTEM SHOW 5 LOCKS ARE ENABLED I TRY TO UNLOCK VIA SETOOL BUT SHOW THIS ERROR TEST CARD USING PHONE SHOW SAME INSERT CORRECT ERROR Code: RUNNING v1.0/UNI CARD SERIAL 00042062 USBFLASH DRIVER VERSION 02.02.00.05 SIGNED MODE (USING SERVER) CFG:100100000000 NEW SECURITY (RESPIN) PHONE ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0050 Speed:921600 FLASH ID: 897E OTP: LOCKED:1 CID:50 PAF:1 IMEI:35727501692287 CERT:RED FLASH CID:50 COLOR:RED Model (from GDFS):K310i Brand:Sony Ericsson MAPP CXC article: R4EA031 prgCXC1250466_GENERIC_DO MAPP CXC version: R4EA031 Language Package: RUSSIA CDA article: CDA102576/1 CDA version: R5A Default article: cxc1250474 Default version: R4EA031 PROVIDER: 000-00 SIMLOCKS NOT DETECTED USERCODE:0000 RESTORATION FILE PRESENT FOR DETECTED FIRMWARE Elapsed: 107 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110000000000 NEW SECURITY (RESPIN) PHONE ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0050 Speed:921600 OTP: LOCKED:1 CID:50 PAF:1 IMEI:35727501692287 CERT:RED LDR:060712 1520 HAN_DB2012_FLASHLOADER_R1A002_CXC1250695 FLASH ID: 897E LDR:070410 1405 HANCXC1327364_COMPACT_SEMC_CS_LOADER_1_R3B009 loader GDFS startup executed loader FILESYSTEM startup executed DISCONNECT PHONE NOW INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM117 SIM CARD NOT PRESENT IN PHONE OR PIN NOT ENTERED. Elapsed: 117 secs. |
09-06-2010, 10:59 | #2 (permalink) | |
No Life Poster Join Date: Sep 2007 Location: Gsm_World
Member: 583353 Status: Offline Thanks Meter: 259 | follow this procedure, no need testcard,tested by me... note: use setool v1.01 Quote:
br, | |
09-08-2010, 11:08 | #6 (permalink) |
Member: 351924 Status: Offline Thanks Meter: 12,469 | Code: SIGNED MODE (USING SERVER) CFG:100000000000 NEW SECURITY (RESPIN) PHONE ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0050 Speed:921600 FLASH ID: 897E OTP LOCKED:1 CID:50 PAF:1 IMEI:35727501692287 CERT:RED ACTIVE CID:50 COLOR:RED Model (from GDFS):K310i Brand:Sony Ericsson MAPP CXC article: R4EA031 prgCXC1250466_GENERIC_DO MAPP CXC version: R4EA031 Language Package: RUSSIA CDA article: CDA102576/1 CDA version: R5A Default article: cxc1250474 Default version: R4EA031 PROVIDER: 000-00 SIMLOCKS NOT DETECTED USERCODE:0000 RESTORATION FILE PRESENT FOR DETECTED FIRMWARE Code: SIGNED MODE (USING SERVER) CFG:100000000000 RESET MODE STARTED NEW SECURITY (RESPIN) PHONE ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0050 Speed:921600 RESET:070703 1100 NPACXC125870_DB2010_CERTRESETLOADER_P5F FLASH ID: 897E GOT SEED:4E693DFA22809B7315F003A9 P96 AUTH PASSED OTP LOCKED:1 CID:50 PAF:1 IMEI:35727501692287 CERT:RED PHONE SUCCESSFULLY RESET TO DEVELOPER STATE Elapsed: 16 secs. CFG:000000000000 NEW SECURITY (RESPIN) PHONE ChipID:8040,EMP protocol:0301 Code: PHONE STATE: "DEVELOPER" FLASH CID: 0051 Speed:921600 OTP LOCKED:1 CID:50 PAF:1 IMEI:35727501692287 CERT:BROWN LDR:DB2010_RESPIN_PRODLOADER_SETOOL2 FLASH ID: 897E writing "D:\SETOOL3\v1.085\gdfs_in_ssw_format\db2010\k310_gdfs_in_ssw_format.ssw" CURRENT FLASH FILE CID:UNIVERSAL SSW uses dynamic hash, dynamic hash len is: 32 Will flash 32 blocks... writing "D:\SETOOL3\v1.085\eroms\db2010\db2012_erom_cid50.ssw" CURRENT FLASH FILE CID:36 Converting firmware... SSW uses dynamic hash, dynamic hash len is: 2 Will flash 2 blocks... Setting up GDFS... OTP WRITE NOT EXECUTED WRITING CLEAR SIMLOCK UNITS... SIMLOCK CODES SET TO "50020042" SIGNING... Elapsed: 55 secs. CFG:000000000000 NEW SECURITY (RESPIN) PHONE ChipID:8040,EMP protocol:0301 Code: PHONE STATE: "RETAIL" FLASH CID: 0050 Speed:921600 FLASH ID: 897E OTP LOCKED:1 CID:50 PAF:1 IMEI:35727501692287 CERT:RED ACTIVE CID:50 COLOR:RED Model (from GDFS):K310i MAPP CXC article: R4DA044 prgCXC1250125_GTAllInOneDO MAPP CXC version: R4DA044 Language Package: World CDA article: CDA100000/8 CDA version: R1A Default article: cxc1250474 Default version: R4DA044 PROVIDER: 000-00 SIMLOCKS NOT DETECTED USERCODE:0000 RESTORATION FILE NOT PRESENT "R4DA044_CXC1250125_GTAllInOneDO" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED |
The Following User Says Thank You to SHIJILFONOTLY For This Useful Post: |
6150 Lock Problem | Zeljko | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 10-16-2013 08:16 |
GId1 problem | old_man | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-18-2006 15:21 |
6110 5.47 sw unlock problem | gsms | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-21-1999 19:43 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
