02-23-2009, 17:23 | #1 (permalink) |
Freak Poster Join Date: May 2008
Member: 769105 Status: Offline Sonork: 072623812 Thanks Meter: 9 | W200 (roggers) Insert correct simcard phone identify as follows. v0.915032/UNI CARD SERIAL: 00046829 Loaded 51 flash descriptors Open COM port OK ChipID:8040,EMP protocol:0301 NEW SECURITY (MARITA RESPIN) PHONE PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 Flash ID check:897E Flash props sent ok OTP: LOCKED:1 CID:51 PAF:1 IMEI:35427001253942 CERT:RED FLASH CID:52 COLOR:RED Model:W200a Brand:Rogers MAPP CXC article: R4HA014 prgCXC1250719_GENERIC_ME MAPP CXC version: R4HA014 Language Package:ROGERS CDA article: CDA102738/303 CDA version: R18A Default article: cxc1250728 Default version: R4HA014 PROVIDER: 302-72 Network LOCKED USERCODE:0000 RESTORATION FILE NOT PRESENT "R4HA014_CXC1250719_GENERIC_ME" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE Elapsed: 3 secs. |
02-24-2009, 00:29 | #3 (permalink) | |
No Life Poster Join Date: Nov 2007
Member: 627228 Status: Offline Sonork: 100.1577983 Thanks Meter: 155 | Quote:
Just Full flash you Phone to alive and after flas be sure you haw "RESTORATION FILE" and "BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE" after falsh Phone unlcok you Phone............ BR, | |
The Following User Says Thank You to vali23_mm For This Useful Post: |
02-24-2009, 23:42 | #5 (permalink) |
Registered User Join Date: Apr 2007 Location: ==**Syria**== Age: 44
Member: 493205 Status: Offline Sonork: 100.1581647 Thanks Meter: 526 | you can unlock it with setool box but you need to (test sim) just flash phone and select thiis option in setting tap Good Luck |
02-25-2009, 00:02 | #6 (permalink) | |
So many options you don't need this......... 1.Farst select SIGNED MODE(USE SERVER FOR BYPASS/CSCA) and ENABLE ALTERNATIVE SECURITY BYPASS and pres Unlock/repair ven asc to select conect Phone => Pres Stop Button 2. Disconect Phone new and insert aloved card or test card do to Game and run Executor new in settings geast select ENABLE PRELOADER SECURITY BYPASS and pres Unlock/repair Button wait proce to be done. BR, | |
02-26-2010, 17:01 | #9 (permalink) |
No Life Poster Join Date: Feb 2004 Age: 49
Member: 52828 Status: Offline Sonork: KHADIM100 Thanks Meter: 1,212 | correct & shot unlock method tested many times by me http://forum.gsmhosting.com/vbb/showthread.php?t=548754 |
w200 london mobile insert correct simcard | ka jagan | Sony Ericsson Hardware Repair | 7 | 03-05-2011 13:10 |
w550 insert correct simcard | jmustufa | Sony Ericsson Hardware Repair | 5 | 01-24-2008 17:17 |
w850i insert correct simcard (not simlock) | rado_elektrado | Sony Ericsson | 8 | 01-18-2007 12:22 |
insert correct simcard | akhil_bbsr | Sony Ericsson Hardware Repair | 4 | 06-26-2006 14:17 |
R600 insert correct simcard | jerrel | Sony Ericsson | 19 | 03-04-2005 15:15 |
