Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: May 2008 Location: The Time Has Come....
Member: 765331 Status: Offline Thanks: 1,885
| Hi Friend..... Need Help Flashing W200i, Got This Error... RUNNING v 1.01/UNI CARD SERIAL 00086XXX USBFLASH DRIVER VERSION 02.02.00.05 SIGNED MODE (USING SERVER) CFG:100000000000 RESET MODE STARTED NEW SECURITY (RESPIN) PHONE ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0053 Speed:115200 RESET:070703 1100 NPACXC125870_DB2010_CERTRESETLOADER_P5F FLASH ID: 2019 GOT SEED:1A2A55FE2380DD67153040DE P96 AUTH PASSED OTP: LOCKED:1 CID:51 PAF:1 IMEI:354269019XXXXX CERT:RED PHONE SUCCESSFULLY RESET TO DEVELOPER STATE Elapsed: 11 secs. CFG:000000000000 NEW SECURITY (RESPIN) PHONE ChipID:8040,EMP protocol:0301 PHONE STATE: "DEVELOPER" FLASH CID: 0051 Speed:115200 OTP: LOCKED:1 CID:51 PAF:1 IMEI:354269019XXXXX CERT:BROWN LDR B2010_RESPIN_PRODLOADER_SETOOL2FLASH ID: 2019 writing "I:\SonyEricsson\GDFS BACKUP\w200_gdfs_in_ssw_format\w200_gdfs_in_ssw_fo rmat.ssw" CURRENT FLASH FILE CID:254 SSW uses dynamic hash, dynamic hash len is: 32 Will flash 32 blocks... Setting up GDFS... OTP WRITE NOT EXECUTED WRITING CLEAR SIMLOCK UNITS... ALL UNLOCK/LOCK CODES SET TO "76580603" SIGNING... Elapsed: 221 secs. CFG:000000000000 NEW SECURITY (RESPIN) PHONE ChipID:8040,EMP protocol:0301 PHONE STATE: "DEVELOPER" FLASH CID: 0051 Speed:115200 OTP: LOCKED:1 CID:51 PAF:1 IMEI:354269019XXXXX CERT:BROWN LDR B2010_RESPIN_PRODLOADER_SETOOL2FLASH ID: 2019 writing "I:\SonyEricsson\SE Flash Files\eeprom\db2020eroms099version\DB2020EROM_CNV_ RED52_BROWN_CID49_DB2020.ssw" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 40 Will flash 2 blocks... Setting up GDFS... OTP WRITE NOT EXECUTED WRITING CLEAR SIMLOCK UNITS... ALL UNLOCK/LOCK CODES SET TO "55232582" SIGNING... Elapsed: 35 secs. CFG:000000000000 NEW SECURITY (RESPIN) PHONE ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:115200 FLASH ID: 2019 OTP: LOCKED:1 CID:51 PAF:1 IMEI:354269019XXXXX CERT:RED FLASH CID:52 COLOR:RED Model (from GDFS):W200i Brand:Sony Ericsson MAPP CXC article: R4GB001 prgCXC1250719_GENERIC_ME MAPP CXC version: R4GB001 Language Package: M_EAST_N_AFR CDA article: CDA102737/109 CDA version: R1A Default article: cxc1250728 Default version: R4GB001 PROVIDER: 000-00 SIMLOCKS NOT DETECTED USERCODE:0000 RESTORATION FILE NOT PRESENT "R4GB001_CXC1250719_GENERIC_ME" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED Elapsed: 8 secs. SIGNED MODE (USING SERVER) CFG:100111000000 NEW SECURITY (RESPIN) PHONE ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:115200 err: 32 (9) loader header not accepted FAILED TO SETUP PHONE Elapsed: 1 secs. Thanks In Any Advance..... |
| | #7 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Apr 2008 Location: facebook
Member: 760175 Status: Offline Thanks: 54
| Flash again mate in setting singedmode costumize after flash........... |
| The Following User Says Thank You to N93i For This Useful Post: |
| | #9 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2007 Location: MX-Key and me ...The Best
Member: 617692 Status: Offline Thanks: 120
| If you are using RJ45 cable then try with USB with higher version. Download some other files from support area connect supply instead of battery |
| The Following User Says Thank You to farihabest For This Useful Post: |
| | #10 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2007 Location: ==**Syria @ Swaida**== Age: 33
Member: 493205 Status: Offline Sonork: 100.1581647 Thanks: 242
| yes try with usb cable and change speed to high.......try and post result |
| The Following User Says Thank You to yarra For This Useful Post: |
| | #12 (permalink) |
| Brother flash with CID 52 or change the files of CID51 |
| | #13 (permalink) | |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2008
Member: 893209 Status: Offline Thanks: 816
| Quote:
Try AGAIN RESET and WRITE EROMS CID53.. FLASH MAIN@FS(CID53) Hope it HELPS.. Br,. Rhyan777 | |
| The Following User Says Thank You to Rhyan777 For This Useful Post: |
| | #14 (permalink) | |
| Quote:
RUNNING v 1.01/UNI CARD SERIAL 00086XXX USBFLASH DRIVER VERSION 02.02.00.05 SIGNED MODE (USING SERVER) CFG:100000000000 NEW SECURITY (RESPIN) PHONE ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:230400 FLASH ID: 2019 OTP: LOCKED:1 CID:51 PAF:1 IMEI:354269019XXXXX CERT:RED FLASH CID:52 COLOR:RED Model (from GDFS):W200i Brand:Sony Ericsson MAPP CXC article: R4GB001 prgCXC1250719_GENERIC_ME MAPP CXC version: R4GB001 Language Package: M_EAST_N_AFR CDA article: CDA102737/109 CDA version: R1A Default article: cxc1250728 Default version: R4GB001 PROVIDER: 000-00 SIMLOCKS NOT DETECTED USERCODE:0000 RESTORATION FILE PRESENT FOR DETECTED FIRMWARE Elapsed: 7 secs. SIGNED MODE (USING SERVER) CFG:100000000000 RESET MODE STARTED NEW SECURITY (RESPIN) PHONE ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:230400 RESET:070703 1100 NPACXC125870_DB2010_CERTRESETLOADER_P5F FLASH ID: 2019 GOT SEED:798395692380DD67153040DE P96 AUTH PASSED OTP: LOCKED:1 CID:51 PAF:1 IMEI:354269019XXXXX CERT:RED PHONE SUCCESSFULLY RESET TO DEVELOPER STATE Elapsed: 36 secs. CFG:000000000000 NEW SECURITY (RESPIN) PHONE ChipID:8040,EMP protocol:0301 PHONE STATE: "DEVELOPER" FLASH CID: 0051 Speed:230400 OTP: LOCKED:1 CID:51 PAF:1 IMEI:354269019XXXXX CERT:BROWN LDR B2010_RESPIN_PRODLOADER_SETOOL2FLASH ID: 2019 writing "I:\SonyEricsson\GDFS BACKUP\w200_gdfs_in_ssw_format\w200_gdfs_in_ssw_fo rmat.ssw" CURRENT FLASH FILE CID:254 SSW uses dynamic hash, dynamic hash len is: 32 Will flash 32 blocks... Setting up GDFS... OTP WRITE NOT EXECUTED WRITING CLEAR SIMLOCK UNITS... ALL UNLOCK/LOCK CODES SET TO "16670273" SIGNING... Elapsed: 122 secs. CFG:000000000000 NEW SECURITY (RESPIN) PHONE ChipID:8040,EMP protocol:0301 PHONE STATE: "DEVELOPER" FLASH CID: 0051 Speed:230400 OTP: LOCKED:1 CID:51 PAF:1 IMEI:354269019XXXXX CERT:BROWN LDR B2010_RESPIN_PRODLOADER_SETOOL2FLASH ID: 2019 Setting up GDFS... OTP WRITE NOT EXECUTED WRITING CLEAR SIMLOCK UNITS... ALL UNLOCK/LOCK CODES SET TO "76138551" SIGNING... Unlock FINISHED Elapsed: 11 secs. CFG:000000000000 NEW SECURITY (RESPIN) PHONE ChipID:8040,EMP protocol:0301 PHONE STATE: "DEVELOPER" FLASH CID: 0051 Speed:230400 OTP: LOCKED:1 CID:51 PAF:1 IMEI:354269019XXXXX CERT:BROWN LDR B2010_RESPIN_PRODLOADER_SETOOL2FLASH ID: 2019 writing "I:\SonyEricsson\SE Flash Files\eeprom\db2020eroms099version\DB2020EROM_CNV_ RED53_BROWN_CID49_DB2020.ssw" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 40 Will flash 2 blocks... Setting up GDFS... OTP WRITE NOT EXECUTED WRITING CLEAR SIMLOCK UNITS... ALL UNLOCK/LOCK CODES SET TO "13333065" SIGNING... Elapsed: 24 secs. SIGNED MODE (USING SERVER) CFG:100111000000 NEW SECURITY (RESPIN) PHONE ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0053 Speed:230400 FLASH ID: 2019 OTP: LOCKED:1 CID:51 PAF:1 IMEI:354269019XXXXX CERT:RED FLASH CID:53 COLOR:RED Model (from GDFS):W200i Brand:Sony Ericsson MAPP CXC article: R4GB001 prgCXC1250719_GENERIC_ME MAPP CXC version: R4GB001 Language Package: M_EAST_N_AFR CDA article: CDA102737/109 CDA version: R1A Default article: cxc1250728 Default version: R4GB001 PROVIDER: 000-00 SIMLOCKS NOT DETECTED USERCODE:0000 RESTORATION FILE PRESENT FOR DETECTED FIRMWARE Elapsed: 5 secs. SIGNED MODE (USING SERVER) CFG:100111000000 NEW SECURITY (RESPIN) PHONE ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0053 Speed:230400 err: 32 (9) loader header not accepted FAILED TO SETUP PHONE Elapsed: 1 secs. SIGNED MODE (USING SERVER) CFG:100111000000 NEW SECURITY (RESPIN) PHONE ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0053 Speed:230400 FLASH ID: 2019 OTP: LOCKED:1 CID:51 PAF:1 IMEI:354269019XXXXX CERT:RED FLASH CID:53 COLOR:RED Model (from GDFS):W200i Brand:Sony Ericsson MAPP CXC article: R4GB001 prgCXC1250719_GENERIC_ME MAPP CXC version: R4GB001 Language Package: M_EAST_N_AFR CDA article: CDA102737/109 CDA version: R1A Default article: cxc1250728 Default version: R4GB001 PROVIDER: 000-00 SIMLOCKS NOT DETECTED USERCODE:0000 RESTORATION FILE PRESENT FOR DETECTED FIRMWARE Elapsed: 7 secs. SIGNED MODE (USING SERVER) CFG:100111000000 NEW SECURITY (RESPIN) PHONE ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0053 Speed:230400 err: 32 (9) loader header not accepted FAILED TO SETUP PHONE Elapsed: 1 secs. | |
| | #15 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Sep 2007 Location: algeria
Member: 591880 Status: Offline Thanks: 363
| Code: SonyEricsson\SE Flash Files\eeprom\db2020eroms099version\DB2020EROM_CNV_ RED53_BROWN_CID49_DB2020.ssw |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| 6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 5 | 04-10-2013 02:07 |
| 5110&6110 Eeprom header... | O'Malley | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 1 | 10-15-2009 21:41 |
| winlock wintesla m2bus do not work | Bigbrothers2000 | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 1 | 01-26-2000 13:31 |
| I have unlcoker for 51/61/32 for all new version for exchange Motorola 3*88 unlocker! | MC | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 0 | 11-14-1999 12:02 |
| "Deskey Device driver not found" ?? Please help | DivAdonis | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 0 | 06-28-1999 14:56 |
