w20i 3 credit lost but still locked SIGNED MODE (USING SERVER) CFG:100010000000 ChipID: F100, EMP protocol: 0401 PHONE DOMAIN: "RETAIL" PHONE CID: 0081 OTP LOCKED: 1 CID: 81 PAF: 1 IMEI: 01238200487996 CERT: RED LDR: 2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS: SYSTEM FLASH SIGNATURE AUTH LDR: 2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS: SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock. Checking for signature ... signature found, skipping calculation server error:remote dongle not available Unlock FAILED Elapsed: 9 secs. |
CID 80,81 server-based full signature unlock 1. select proper model 2. on settings, check "signed mode","do full unlock instead usercode reset",fill login details 3. back to semc a2 tab, press unlock that method can not fix SCRC. if s1 signature server offline, you can not use quick (without modem drivers) unlock. instead, you should : 1. select proper model 2. on settings, check "signed mode", "do full unlock instead usercode reset", "disable flash mode activation for semc a2 phones", fill login details 3. back to semc a2 tab, press unlock 4. when prompted, install phone modem drivers (they can be found in drivers\Modem_Drivers or will be automatically installed if you install semc pc suite) 5. when you will get message "unlock done" - do not remove cable or battery, wait until phone automatically power on, otherwise you will get 5 locks and need to repeat procedure. you can not unlock last SEMC A2 phone ( j108 ) with CSCA method, use special bypass mode. you MUST flash r7cXXX firmware version to be able unlock w20 phone with CSCA method. http://support.setool.net/showthread...2-BASED-PHONES double read highlighted items tick 1+5+6 press unlock |
