Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (Non-Official Support) > SETool2
Old 07-31-2012, 14:34   #1 (permalink)
mobitechnepal's Avatar
Member: 1139381
Sonork: 1593399
Arrow w20i 3 credit lost but still locked
SIGNED MODE (USING SERVER)
CFG:100010000000
ChipID: F100, EMP protocol: 0401
PHONE DOMAIN: "RETAIL"
PHONE CID: 0081
OTP LOCKED: 1 CID: 81 PAF: 1 IMEI: 01238200487996 CERT: RED
LDR: 2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096
LDR CAPS: SYSTEM FLASH SIGNATURE AUTH
LDR: 2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096
LDR CAPS: SYSTEM FLASH GDFS FILESYSTEM TA
Executing CSCA-based unlock.
Checking for signature ...
signature found, skipping calculation
server error:remote dongle not available
Unlock FAILED
Elapsed: 9 secs.
Old 07-31-2012, 14:53   #2 (permalink)
:Aishur:'s Avatar
Member: 1315677
CID 80,81
server-based full signature unlock
1. select proper model
2. on settings, check "signed mode","do full unlock instead usercode reset",fill login details
3. back to semc a2 tab, press unlock
that method can not fix SCRC.
if s1 signature server offline, you can not use quick (without modem drivers) unlock.
instead, you should :
1.
select proper model
2.
on settings, check
"signed mode",
"disable flash mode activation for semc a2 phones",
fill login details
3.
4.
when prompted, install phone modem drivers
(they can be found in drivers\Modem_Drivers or will be automatically installed if you install semc pc suite)
5.
when you will get message "unlock done" - do not remove cable or battery,
wait until phone automatically power on, otherwise you will get 5 locks and need to repeat procedure.
you can not unlock last SEMC A2 phone ( j108 ) with CSCA method, use special bypass mode.
you MUST flash r7cXXX firmware version to be able unlock w20 phone with CSCA method.
http://support.setool.net/showthread...2-BASED-PHONES
double read highlighted items
tick 1+5+6 press unlock
The Following 2 Users Say Thank You to :Aishur: For This Useful Post:
Help: Forgot my 6110 user lock code!! GByte9 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 5 05-10-2012 14:14
my 8810 is phone locked ,can somebody please help duyphuc Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 16 02-01-2012 05:18
Eeprom dump lost, help needed. CAMILO Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 11-29-2010 18:04
SP Lock 1&4 dw Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 11 06-26-1999 06:22
Need info for unliocking 2 lock (with pic microprocesors) Tomas Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 06-26-1999 01:00
Page generated in 0.21315 seconds with 11 queries
