10-17-2011, 15:52 | #1 (permalink) |
No Life Poster Join Date: May 2006
Member: 273834 Status: Offline Thanks Meter: 68 | W20i insert correct sim after unlocking FLASH CID: 0081 OTP LOCKED:1 CID:81 PAF:1 IMEI:01238200481248 CERT:RED LDR:2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH SIGNATURE AUTH LDR:2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock. Checking for signature ... signature found, skipping calculation Backup security data ... Erasing locks ... DISCONNECT PHONE NOW REMOVE SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM43 PHONE READY TO PROCEED. GOT SEED:00FA1C87 ACTIVATION COMPLETED. USERCODE RESET TO "0000" Unlock DONE Elapsed: 119 secs. |
10-17-2011, 15:57 | #2 (permalink) |
Product Manager Join Date: Sep 2009 Location: Pakistan Age: 36
Member: 1118710 Status: Offline Sonork: 100.1604414 Thanks Meter: 4,970 | Try this Method to Unlock Ur Set.. you MUST flash r7cXXX firmware version to be able unlock w20 phone with CSCA method. 1. select proper model 2. on settings, check "signed mode", "do full unlock instead usercode reset", "disable flash mode activation for semc a2 phones", fill login details 3. back to semc a2 tab, press unlock 4. when prompted, install phone modem drivers (they can be found in drivers\Modem_Drivers or will be automatically installed if you install semc pc suite) 5. when you will get message "unlock done" - do not remove cable or battery, wait until phone automatically power on, otherwise you will get 5 locks and need to repeat procedure. Try & Post result... |
The Following User Says Thank You to Danish Shafiq For This Useful Post: |
10-17-2011, 16:06 | #3 (permalink) |
No Life Poster Join Date: Mar 2004 Location: jamshedpur Age: 38
Member: 59185 Status: Offline Sonork: 100.1593175 Thanks Meter: 4,911 | if s1 signature server offline, you can not use quick (without modem drivers) unlock. instead, you should : 1. select proper model 2. on settings, check "signed mode", "do full unlock instead usercode reset", "disable flash mode activation for semc a2 phones", fill login details 3. back to semc a2 tab, press unlock 4. when prompted, install phone modem drivers (they can be found in drivers\Modem_Drivers or will be automatically installed if you install semc pc suite) 5. when you will get message "unlock done" - do not remove cable or battery, wait until phone automatically power on, otherwise you will get 5 locks and need to repeat procedure. |
12-12-2011, 22:36 | #4 (permalink) |
No Life Poster Join Date: Aug 2010 Location: PAKISTAN
Member: 1383464 Status: Offline Sonork: 100.1669490 Thanks Meter: 100 | dnt worry about the credits it will not deducted on the same one you can try it again to unlock and use the 1st 5th and 6th setting and connect your phone by pressings 2+5 instead of c then it will b asked you to attached power on phone do it and your phone will b unlocked without any more credit .. if your got the message no response from the phone 1st downgrade your phone with any R7CA061 firmware then all will b fine |
SIM restriction pending -- what does it mean? | Ryu | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 7 | 07-17-2011 10:05 |
