08-11-2011, 14:09 | #1 (permalink) |
Registered User Join Date: Apr 2005 Location: niamey niger Age: 53
Member: 137207 Status: Offline Thanks Meter: 27 | W20i not unlock but lost 5 CREDITS PLEASE HELP TO UNLOCK W20i I TRIED BUT UNLOCK UNSUCCEFUL BUT I LOST 5 CREDITS SEE LOG SIGNED MODE (USING SERVER) CFG:100010000000 SERVER CREDITS LEFT/USED: 10/20 CARD COUNTERS: FLASH 749, UNLOCK 324 credits consumption for full signature unlock: S1 v1 5 credits ( OFFLINE ) S1 v2 10 credits ( OFFLINE ) S1 OPEN 5 credits ( AID 004 OFFLINE ) A1 phones 5 credits A2 phones 5 credits ( DO NOT USE FOR J108 ) S1 v2 alternative bypass 5 credits W100,W150 codes 5 credits current setool2 version: 1.1101 Elapsed: 6 secs. SIGNED MODE (USING SERVER) CFG:100010000000 ChipID:F100,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,81,1,01253000769305] OTP LOCKED:1 CID:81 PAF:1 IMEI:012530XXXXXXXXX CERT:RED LDR:2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH SIGNATURE AUTH LDR:2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock. Checking for signature... Waiting for calculation process... RESPONSE: "SUCCESS" [1038] server error:remote dongle not available Unlock FAILED Elapsed: 36 secs. AFTER UNLOCK SIGNED MODE (USING SERVER) CFG:100010000000 SERVER CREDITS LEFT/USED: 5/25 CARD COUNTERS: FLASH 749, UNLOCK 324 Elapsed: 2 secs. SIGNED MODE (USING SERVER) CFG:100010000000 SERVER CREDITS LEFT/USED: 5/25 CARD COUNTERS: FLASH 749, UNLOCK 324 Elapsed: 4 secs. THANK TO HELP |
08-11-2011, 14:21 | #2 (permalink) |
No Life Poster Join Date: Sep 2005 Location: Havana, CUBA
Member: 181633 Status: Offline Thanks Meter: 730 | use this method: Code: Procedure Step By Step (except spiro & yendo) :- 1. select proper model(from SEMC A2) 2. on settings, check "signed mode", "do full unlock instead usercode reset", "disable flash mode activation for semc a2 phones", fill login details 3. back to semc a2 tab, press unlock 4. when prompted, install phone modem drivers (they can be found in drivers\Modem_Drivers or will be automatically installed if you install semc pc suite) 5. when you will get message "unlock done" - do not remove cable or battery, wait until phone automatically power on, otherwise you will get 5 locks and need to repeat procedure. |
08-11-2011, 14:32 | #3 (permalink) | |
Member: 137207 Status: Offline Thanks Meter: 27 | Quote:
i tried but fone is lock SERVER CREDITS LEFT/USED: 5/25 CARD COUNTERS: FLASH 749, UNLOCK 324 Elapsed: 4 secs. SIGNED MODE (USING SERVER) CFG:100011000000 ChipID:F100,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,81,1,01253000769305] OTP LOCKED:1 CID:81 PAF:1 IMEI:01253000769305 CERT:RED LDR:2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH SIGNATURE AUTH LDR:2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock. Checking for signature... signature found, skipping calculation Backup security data... Erasing locks... DISCONNECT PHONE NOW REMOVE SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM7 Phone not responds to AT #1, retry 1 Phone not responds to AT #1, retry 2 Phone not responds to AT #1, retry 3 Phone not responds to AT #1, retry 4 Phone not responds to AT #1, retry 5 CSCA UNLOCK FAILED Unlock FAILED Elapsed: 147 secs. | |
08-11-2011, 14:39 | #4 (permalink) |
No Life Poster Join Date: May 2011 Location: ***DUBAI*** Age: 38
Member: 1579234 Status: Offline Sonork: Not user Thanks Meter: 342 | S1 v1 5 credits ( OFFLINE ) S1 v2 10 credits ( OFFLINE ) S1 OPEN 5 credits ( AID 004 OFFLINE ) A1 phones 5 credits A2 phones 5 credits ( DO NOT USE FOR J108 ) S1 v2 alternative bypass 5 credits W100,W150 codes 5 credits Helo bro SERVER OFFLINE |
08-11-2011, 15:03 | #8 (permalink) |
Freak Poster Join Date: Feb 2011 Location: moon Age: 37
Member: 1523083 Status: Offline Sonork: 100.1609029 Thanks Meter: 141 | 1. make sure you have firmware with android 2.x, NOT 1.6. firmware 2.3 is NOT supported, downgrade to 2.1. flash required firmware, if needed. 2. power on phone without sim card, go to menu->settings->applications->development, enable "usb debugging" connect phone to PC, install drivers from setool2 distr ( drivers\ADB_Drivers) hint: i suggest to import DisableADBNumbering.reg, however that is not required. 3. select proper phone model. on settings check signed mode, use alternative security bypass, do full unlock instead usercode reset press unlock when prompted, detach phone, turn it on fully, connect it again. ( or you can leave phone on cable, then power it on manually ) when program tells "warming up...", manually power on phone fully, cause it will automatically enter charging mode. after you see "GETTING ROOT ACCESS ..." DO NOT TOUCH PHONE until procedure complete. DO NOT DETACH PHONE FROM CABLE AFTER PROCEDURE STARTED, YOU CAN KILL YOUR PHONE, ONLY RIFF JTAG WILL HELP DO NOT REMOVE BATTERY FROM PHONE AFTER PROCEDURE STARTED, YOU CAN KILL YOUR PHONE, ONLY RIFF JTAG WILL HELP |
08-11-2011, 15:26 | #9 (permalink) | |
SORRY THIS FONE IS W20i NOT PDA OR ANDROID FONE NOT POSSIBLE TO GET MENU WITHOUT SIM CARD SEARCH W20 i thank | |
08-11-2011, 15:30 | #11 (permalink) |
No Life Poster Join Date: Sep 2010 Location: In trouble Age: 49
Member: 1388004 Status: Offline Sonork: 100.1637034 Thanks Meter: 444 | Didn't you read my post over ? Use right settings : signed mode, full unlock, disable flash And your phone will be unlocked and no more credits consumed. |
08-11-2011, 17:01 | #13 (permalink) |
Member: 137207 Status: Offline Thanks Meter: 27 | thank but can you give me firmware can work to unlock this fone ? Because i trie this r7da062 r7da062.app_sw_1232_9903_generic_to_redbrownblue_c id81_80_53_52_49_db3350.software r7da062.fs_m_east_n_afr_to_redbrownblue_cid81_80_5 3_52_49.software but not unlock |
08-11-2011, 18:13 | #14 (permalink) |
Member: 1388004 Status: Offline Sonork: 100.1637034 Thanks Meter: 444 | I succeeded with r7caxxx, then re-upgrade to original firmware. When you tried with r7daxxx, what is still same issue with "phone does not responds...." ? |
08-11-2011, 18:17 | #15 (permalink) |
Member: 1388004 Status: Offline Sonork: 100.1637034 Thanks Meter: 444 | check that : http://forum.gsmhosting.com/vbb/f473...8/#post7469194 You can read full thread anyway, all information are in I guess. |
"Deskey Device driver not found" ?? Please help | DivAdonis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-08-2017 13:21 |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
