02-05-2014, 13:18 | #1 (permalink) |
Freak Poster Join Date: Aug 2009 Location: nobody is perfect and i'm 1
Member: 1105427 Status: Offline Sonork: I don't use sonork Thanks Meter: 57 | W20i_ZYLO unlocking problem SIGNED MODE (USING SERVER) CFG:100011000000 ChipID: F100, EMP protocol: 0401 PHONE DOMAIN: "RETAIL" PHONE CID: 0081 OTP: LOCKED:1 CID:81 PAF:1 IMEI:01253000786728 CERT:RED LDR: 2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR: 2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 Model (from GDFS): W20i MAPP CXC article: R7DA062 prg1232-9903_GENERIC_TO MAPP CXC version: R7DA062 Language Package: NORDIC CDA article: 1238-6974 CDA version: R9A Default article: 1232-9909 Default version: R7DA062 SIMLOCKS NOT DETECTED PROVIDER: 000-000 SECURITY UNITS BACKUP CREATED. Elapsed: 10secs. when i unlock too with stings 1-5-6 ticked i get this error and already 3 credits deducted current updater version: 0.95 current setool2 version: 1.1405 SERVER CREDITS LEFT/USED: 22/38 CARD COUNTERS: FLASH 249, UNLOCK 139 Elapsed: 5 secs. SIGNED MODE (USING SERVER) CFG:100011000000 ChipID: F100, EMP protocol: 0401 PHONE DOMAIN: "RETAIL" PHONE CID: 0081 OTP: LOCKED:1 CID:81 PAF:1 IMEI:01253000786728 CERT:RED LDR: 2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS: SYSTEM FLASH SIGNATURE AUTH LDR: 2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS: SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock. Checking for signature ... Waiting for calculation process ... RESPONSE: "SUCCESS" [1038] Backup security data ... Erasing locks ... DISCONNECT PHONE NOW REMOVE SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM38 Phone not responds to AT #1, retry 1 Phone not responds to AT #1, retry 2 Phone not responds to AT #1, retry 3 Phone not responds to AT #1, retry 4 Phone not responds to AT #1, retry 5 CSCA UNLOCK FAILED Unlock FAILED Elapsed: 188 secs. |
02-05-2014, 16:45 | #4 (permalink) | |
Member: 1105427 Status: Offline Sonork: I don't use sonork Thanks Meter: 57 | Quote:
and as i checked all the 5 padlocks are closed HOW TO WORK WITH A2-BASED PHONES You MUST flash r7cXXX firmware version to be able unlock w20 phone with CSCA method. 1. select proper model 2. on settings, check "signed mode", "do full unlock instead usercode reset", "disable flash mode activation for semc a2 phones", fill login details 3. back to semc a2 tab, press unlock 4. when prompted, install phone modem drivers (they can be found in drivers\Modem_Drivers or will be automatically installed if you install semc pc suite) 5. when you will get message "unlock done" - do not remove cable or battery, wait until phone automatically power on, otherwise you will get 5 locks and need to repeat procedure. | |
02-07-2014, 12:18 | #5 (permalink) | |
02-07-2014, 15:30 | #6 (permalink) |
No Life Poster Join Date: Dec 2011 Location: Poland
Member: 1704846 Status: Offline Sonork: 1617108 Thanks Meter: 117 | Solution on 5 lock: when you will get message "unlock done" - do not remove cable or battery, wait until phone automatically power on Credit will not be downland again. |
02-07-2014, 16:33 | #7 (permalink) |
Member: 1105427 Status: Offline Sonork: I don't use sonork Thanks Meter: 57 | i perfectly understand u bro when i get the message unlock done ..but read my case very well job always failed |
02-07-2014, 16:54 | #8 (permalink) |
Freak Poster Join Date: Sep 2007
Member: 592531 Status: Offline Sonork: 100.1641625 Thanks Meter: 17 | W20i_ZYLO unlocking done with 3logs current updater version: 0.95 current setool2 version: 1.1405 SERVER CREDITS LEFT/USED: 25/5 CARD COUNTERS: FLASH 633, UNLOCK 487 Elapsed: 5 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") CFG:110010000000 ChipID: F100, EMP protocol: 0401 BOOTROM MODE DETECTED OTP DBG: [1,81,1,01253000081322] OTP: LOCKED:1 CID:81 PAF:1 IMEI:01253000081322 CERT:RED ALTERNATIVE SECURITY BYPASS NOT SUPPORTED FOR THIS PHONE Unlock FAILED Elapsed: 19 secs. SIGNED MODE (USING SERVER) CFG:100011000000 ChipID: F100, EMP protocol: 0401 PHONE DOMAIN: "RETAIL" PHONE CID: 0081 OTP: LOCKED:1 CID:81 PAF:1 IMEI:01253000081322 CERT:RED LDR: 2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS: SYSTEM FLASH SIGNATURE AUTH LDR: 2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS: SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock. Checking for signature ... signature found, skipping calculation Backup security data ... Erasing locks ... DISCONNECT PHONE NOW REMOVE SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM94 PHONE READY TO PROCEED. GOT SEED: 00BC8571 ACTIVATION COMPLETED. USERCODE RESET TO "0000" DO NOT DISCONNECT PHONE FROM CABLE UNTIL PHONE TURNS ON BY ITSELF Unlock DONE Elapsed: 704 secs. SIGNED MODE (USING SERVER) |
03-10-2014, 16:06 | #9 (permalink) |
Insane Poster Join Date: Jan 2012
Member: 1712559 Status: Offline Thanks Meter: 3 | hello i want to unlock w20i with setool but when i conect the phone witj 2+5 my computer freeze what can i do please ? everything is blocked i can not do anything i muste to restart computer someone can help me ? |
