12-03-2008, 11:40 | #1 (permalink) |
Insane Poster Join Date: Sep 2007
Member: 579111 Status: Offline Thanks Meter: 9 | W350 Unlock Help PHONE STATE: "RETAIL" FLASH CID: 0053 skipping empty loader... OTP: LOCKED:1 CID:52 PAF:1 IMEI: CERT:RED Model:W350i Brand:Orange MAPP CXC article: R10BA015 prg1205-7400_ORANGE_JH MAPP CXC version: R10BA015 Language Package:ORANGE_GEN CDA article: 1209-0649 CDA version: R3A Default article: 1204-3119 Default version: R10BA015 PROVIDER: 234-33 Network LOCKED RESTORATION FILE PRESENT FOR DETECTED FIRMWARE BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE SECURITY UNITS BACKUP CREATED. Elapsed: 9 secs. SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. PRELOADER SECURITY BYPASS ENABLED. ChipID000,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0053 Speed:921600 OTP: LOCKED:1 CID:52 PAF:1 IMEI:35774402373511 CERT:RED LDR:071213 1552 PERCXC1720441_R2A022_PNX5230_FLASHLOADER Flash ID check:2019 Flash props sent ok LDR:070904 1356 AN2CXC1250610_R3A016_PNX5230_CSLOADER loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed DISCONNECT PHONE NOW INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT Can't find attached phone with IMEI PROCEDURE WAS STOPPED BY USER Elapsed: 329 secs. |
The Following 2 Users Say Thank You to Soulja88 For This Useful Post: |
12-03-2008, 12:00 | #2 (permalink) |
Junior Member Join Date: Jul 2007
Member: 545183 Status: Offline Thanks Meter: 0 | bro you need to install w350 signed drivers for your phone and make sure you have the correct sim card. You will need to press phone mode and your will display a java window and will restart. |
12-03-2008, 12:03 | #3 (permalink) | |
No Life Poster Join Date: Jun 2006 Location: sangam music Punjab India Age: 38
Member: 296651 Status: Offline Sonork: 100.1581376 Thanks Meter: 386 | Quote:
12-03-2008, 15:06 | #5 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Bulgaria Asenovgrad Age: 42
Member: 239176 Status: Offline Sonork: 100.1602815 Thanks Meter: 851 | hier usb driver http://rapidshare.com/files/16984313...ivers.rar.html |
The Following User Says Thank You to delchoni For This Useful Post: |
12-03-2008, 15:11 | #6 (permalink) |
Member: 239176 Status: Offline Sonork: 100.1602815 Thanks Meter: 851 | v0.915021/UNI CARD SERIAL: *******8 Loaded 51 flash descriptors SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. Open COM port OK ChipID000,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0053 Speed:921600 OTP: LOCKED:1 CID:52 PAF:1 IMEI:35438902610480 CERT:RED LDR:071213 1552 PERCXC1720441_R2A022_PNX5230_FLASHLOADER Flash ID check:897E Flash props sent ok USB CONNECTION REQUIRED. Elapsed: 16 secs. Connecting to UFS... Found 1 FTDI device(s). Can't detect any UFS boxes. SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. ChipID000,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0053 Speed:921600 OTP: LOCKED:1 CID:52 PAF:1 IMEI:35438902610480 CERT:RED LDR:071213 1552 PERCXC1720441_R2A022_PNX5230_FLASHLOADER Flash ID check:897E Flash props sent ok LDR:070904 1356 AN2CXC1250610_R3A016_PNX5230_CSLOADER loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed DISCONNECT PHONE NOW INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM21 PHONE READY TO PROCEED EXECUTOR STARTED REMOVE CABLE FROM PHONE REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS "READY" ChipID000,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0053 Speed:921600 Trying to launch embedded bootloader... INT LDR:PNX5230_PRELOADER_FOR_SETOOL2 LDR:PNX5230_PRODUCTION_LOADER_FOR_SETOOL2 Flash ID check:897E Flash props sent ok FOUND VERSION "R11CA002_1204-3117_GENERIC_JH" can't open file "C:\Documents and Settings\MobileDoctor`s\Desktop\v0.915021\rest\R11 CA002_1204-3117_GENERIC_JH" writing C:\Documents and Settings\MobileDoctor`s\Desktop\w350bg\w.software CURRENT FLASH FILE CID:53 SSW uses full hash, hash len is:9600 Will flash 480 blocks... SSW loading returns:0 writing C:\Documents and Settings\MobileDoctor`s\Desktop\w350bg\R11CA002_FS _MEDITERR_JH_RED_CID53.software CURRENT FLASH FILE CID:53 SSW uses full hash, hash len is:2740 HDR block not accepted,error: BA Elapsed: 1167 secs. SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. ChipID000,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0053 Speed:921600 OTP: LOCKED:1 CID:52 PAF:1 IMEI:35438902610480 CERT:RED LDR:071213 1552 PERCXC1720441_R2A022_PNX5230_FLASHLOADER Flash ID check:897E Flash props sent ok LDR:070904 1356 AN2CXC1250610_R3A016_PNX5230_CSLOADER loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed DISCONNECT PHONE NOW INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM21 PHONE READY TO PROCEED EXECUTOR STARTED REMOVE CABLE FROM PHONE REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS "READY" ChipID000,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0053 Speed:921600 Trying to launch embedded bootloader... INT LDR:PNX5230_PRELOADER_FOR_SETOOL2 LDR:PNX5230_PRODUCTION_LOADER_FOR_SETOOL2 Flash ID check:897E Flash props sent ok FOUND VERSION "R11CA002_1204-3117_GENERIC_JH" can't open file "C:\Documents and Settings\MobileDoctor`s\Desktop\v0.915021\rest\R11 CA002_1204-3117_GENERIC_JH" writing C:\Documents and Settings\MobileDoctor`s\Desktop\w350bg\w.software CURRENT FLASH FILE CID:53 SSW uses full hash, hash len is:9600 Will flash 480 blocks... SSW loading returns:0 writing C:\Documents and Settings\MobileDoctor`s\Desktop\w350bg\R11CA002_FS _MEDITERR_JH_RED_CID53.software CURRENT FLASH FILE CID:53 SSW uses full hash, hash len is:2740 Will flash 137 blocks... SSW loading returns:0 full sig complete. USERCODE RESET TO "0000" Searching... Firmware SIMLOCK check determined. LDR:PNX5230_FILESYSTEMLOADER_FOR_SETOOL2 loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed writing "tpa/preset/custom/C3_PCA_G3v2.cer" writing "tpa/preset/custom/CONTENT_DOWNLOAD_HOOK_2.itm" writing "tpa/preset/custom/customize.xml" writing "tpa/preset/custom/DESKTOP_HOOK_2.itm" writing "tpa/preset/custom/Entrust.net Root Certificate.cer" writing "tpa/preset/custom/Entrust.net_WTLS_Root_Certificate.wcrt" writing "tpa/preset/custom/FM_PICTURES_HOOK_3.itm" writing "tpa/preset/custom/FM_SOUNDS_HOOK_3.itm" writing "tpa/preset/custom/FM_THEMES_HOOK_3.itm" writing "tpa/preset/custom/FM_VIDEOS_HOOK_3.itm" writing "tpa/preset/custom/GAMES_HOOK_3.itm" writing "tpa/preset/custom/GTE_CyberTrust_Root.cer" writing "tpa/preset/custom/GTE_Cybe_Trust_Root_WTLS.wcrt" writing "tpa/preset/custom/Root.cer" writing "tpa/preset/custom/SEMC_E2E_Root_CA.crt" writing "tpa/preset/custom/SETT_RINGTONE_HOOK_3.itm" writing "tpa/preset/custom/ThawtePremium.der" writing "tpa/preset/custom/ThawteServerCA.cer" writing "tpa/preset/custom/Utiroot.cer" writing "tpa/preset/custom/VeriSignClass3Root.cer" writing "tpa/preset/custom/Verisign_Class_3_CA_WTLS.wcrt" Phone detached Elapsed: 497 secs. Last edited by delchoni; 12-03-2008 at 15:17. |
12-03-2008, 19:50 | #10 (permalink) |
Member: 579111 Status: Offline Thanks Meter: 9 | I got this message when trying to unlock, I got a similar message when trying to read GDFS and it wouldnt allow me to flash it with the following file "r10ba015_app_sw_1204_3117_generic_jh_red_cid53_pn x5230". Please help what Can I do now?? PHONE STATE: "RETAIL" FLASH CID: 0053 Speed:921600 OTP: LOCKED:1 CID:52 PAF:1 IMEI:****** CERT:RED LDR:071213 1552 PERCXC1720441_R2A022_PNX5230_FLASHLOADER Flash ID check:2019 Flash props sent ok LDR:070904 1356 AN2CXC1250610_R3A016_PNX5230_CSLOADER loader startup: executed loader GDFS startup: executed FS startup failed (1) loader fs startup failed, that is fatal Elapsed: 17 secs. |
12-04-2008, 19:54 | #13 (permalink) |
Freak Poster Join Date: Dec 2008
Member: 914747 Status: Offline Thanks Meter: 22 | Salact model nd go to the setting nd tick only preloader bypass tab nd just press unlock repair button nd connect fone by prassing music play button after ol the fone will ok nd for unlock in setting tick first 3 highlighted tabs nd press unlockrepair nd follow the software 100% tested ages ago ay29! 4 lyf br |
12-04-2008, 23:42 | #14 (permalink) |
Member: 579111 Status: Offline Thanks Meter: 9 | v0.915017/UNI CARD SERIAL: *********** Loaded 51 flash descriptors ChipID000,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0053 skipping empty loader... OTP: LOCKED:1 CID:52 PAF:1 IMEI:*********** CERT:RED Model:W350i Brand:Orange MAPP CXC article: R10BA015 prg1205-7400_ORANGE_JH MAPP CXC version: R10BA015 Language Package:ORANGE_GEN CDA article: 1209-0649 CDA version: R3A Default article: 1204-3119 Default version: R10BA015 PROVIDER: 234-33 Network LOCKED RESTORATION FILE PRESENT FOR DETECTED FIRMWARE BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE SECURITY UNITS BACKUP CREATED. Elapsed: 15 secs. |
12-04-2008, 23:43 | #15 (permalink) | |
Member: 579111 Status: Offline Thanks Meter: 9 | Quote:
PRELOADER SECURITY BYPASS ENABLED. ChipID000,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0053 Speed:921600 Trying to launch embedded bootloader... embedded flashloader not responds ! Elapsed: 50 secs. What can I do?? Thank You | |
w350 unlock cıd 53 | seyit | SETool2 | 11 | 05-01-2011 18:14 |
w350 unlock please help | abhilashkarat | Universalbox | 1 | 08-24-2009 21:53 |
w350 unlock | seyit | Universalbox | 5 | 07-26-2009 10:33 |
w350 unlock ok | nguyenhuu | Cruiser Suite | 2 | 12-06-2008 06:32 |
w350 unlocking problem | software zone | SETool2 | 8 | 11-26-2008 14:41 |
