04-02-2010, 16:24 | #1 (permalink) |
No Life Poster Join Date: Feb 2005 Location: Ireland
Member: 117145 Status: Offline Sonork: 1617520 Thanks Meter: 382 | w350i dead after unlock Here log: Code: 01/04/2010 14:38:58 RUNNING v 1.01/UNI 01/04/2010 14:38:58 CARD SERIAL 00888888 01/04/2010 14:38:58 USBFLASH DRIVER VERSION 02.02.00.05 01/04/2010 14:39:15 SIGNED MODE (USING SERVER) 01/04/2010 14:39:15 CFG:100000000000 01/04/2010 14:39:16 No server found. 01/04/2010 14:39:18 CARD COUNTERS: FLASH 65, UNLOCK 11 01/04/2010 14:39:18 Elapsed: 3 secs. 01/04/2010 14:39:41 SIGNED MODE (USING SERVER) 01/04/2010 14:39:41 CFG:100000000000 01/04/2010 14:39:42 No server found. 01/04/2010 14:39:44 CARD COUNTERS: FLASH 65, UNLOCK 11 01/04/2010 14:39:44 Elapsed: 2 secs. 01/04/2010 14:39:57 SIGNED MODE (USING SERVER) 01/04/2010 14:39:57 ALTERNATIVE SECURITY BYPASS ENABLED 01/04/2010 14:39:57 PRELOADER SECURITY BYPASS ENABLED 01/04/2010 14:39:57 CFG:111000000000 01/04/2010 14:39:57 llbug: COM6 open error: "Access is denied" 01/04/2010 14:39:57 FAILED TO SETUP PHONE 01/04/2010 14:39:57 Elapsed: 0 secs. 01/04/2010 14:40:06 SIGNED MODE (USING SERVER) 01/04/2010 14:40:06 ALTERNATIVE SECURITY BYPASS ENABLED 01/04/2010 14:40:06 PRELOADER SECURITY BYPASS ENABLED 01/04/2010 14:40:06 CFG:111000000000 01/04/2010 14:40:55 ChipID:D000,EMP protocol:0301 01/04/2010 14:40:56 01/04/2010 14:40:56 PHONE STATE: "RETAIL" 01/04/2010 14:40:56 FLASH CID: 0053 01/04/2010 14:40:56 Speed:115200 01/04/2010 14:40:56 OTP: LOCKED:1 CID:52 PAF:1 IMEI:35872602****** CERT:RED 01/04/2010 14:40:57 LDR:071213 1552 PERCXC1720441_R2A022_PNX5230_FLASHLOADER 01/04/2010 14:40:57 FLASH ID: 897E 01/04/2010 14:41:03 LDR:070904 1356 AN2CXC1250610_R3A016_PNX5230_CSLOADER 01/04/2010 14:41:06 loader GDFS startup executed 01/04/2010 14:41:07 loader FILESYSTEM startup executed 01/04/2010 14:41:12 01/04/2010 14:41:12 DISCONNECT PHONE NOW 01/04/2010 14:41:12 INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN 01/04/2010 14:41:12 INSTALL PHONE MODEM DRIVERS IF NEEDED 01/04/2010 14:41:12 01/04/2010 14:41:12 SEARCHING FOR PHONE, "STOP" TO ABORT 01/04/2010 14:43:32 PROCEDURE WAS STOPPED BY USER 01/04/2010 14:43:32 Can't find attached phone with IMEI 35872602****** 01/04/2010 14:43:32 Elapsed: 205 secs. 01/04/2010 14:45:02 SIGNED MODE (USING SERVER) 01/04/2010 14:45:02 ALTERNATIVE SECURITY BYPASS ENABLED 01/04/2010 14:45:02 PRELOADER SECURITY BYPASS ENABLED 01/04/2010 14:45:02 CFG:111000000000 |
04-03-2010, 03:17 | #5 (permalink) | |
No Life Poster Join Date: Jun 2007 Location: Talk to *** and He Will Listen
Member: 532761 Status: Offline Sonork: 100-1592994 Thanks Meter: 1,104 | Quote:
W350i Completely Dead after Unlock, Help... | Top_Banana | SETool2 | 22 | 12-25-2014 16:48 |
w350i dead after unlock | jijeesh | SETool2 | 1 | 12-30-2009 18:50 |
***k608i dead cid 37 dead after unlock*** | zaccoyne | SonyEricsson (USB-Smart) | 4 | 04-21-2006 12:21 |
GD93 Dead, after unlock ON but after some time again Dead... | DrMobile | Panasonic | 1 | 02-14-2002 10:16 |
3310 Dead after Unlock then Alive after Upgrade | ed2k_7 | Nokia Hardware & Hardware Repair | 5 | 11-08-2001 21:21 |
