03-15-2009, 22:01 | #1 (permalink) |
Junior Member Join Date: Dec 2005
Member: 204682 Status: Offline Thanks Meter: 0 | W380a Unlock Problem Urgent Please help customer waiting!! FLASH CID: 0053 Speed:921600 OTP: LOCKED:1 CID:52 PAF:1 IMEI:35306202598946 CERT:RED LDR:071213 1552 PERCXC1720441_R2A022_PNX5230_FLASHLOADER Flash ID check:897E Flash props sent ok phone CID not supported in that mode Elapsed: 13 secs. |
03-15-2009, 22:11 | #2 (permalink) |
Member: 204682 Status: Offline Thanks Meter: 0 | I tried using the SIGNED MODE.... PHONE STATE: "RETAIL" FLASH CID: 0053 Speed:921600 OTP: LOCKED:1 CID:52 PAF:1 IMEI:35306202598946 CERT:RED LDR:071213 1552 PERCXC1720441_R2A022_PNX5230_FLASHLOADER Flash ID check:897E Flash props sent ok LDR:070904 1356 AN2CXC1250610_R3A016_PNX5230_CSLOADER loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed USERCODE RESET TO "0000" Elapsed: 15 secs. |
03-16-2009, 00:54 | #5 (permalink) |
No Life Poster Join Date: Oct 2002 Location: PARIS
Member: 16856 Status: Offline Sonork: 1582037 Thanks Meter: 441 | It seems like you never used SETOOL DB2020 ALTBYPASS Please ReadCarefully and Use Brain for a While : Insert accepted sim card to fully charged phone Go to SEMC tab and select W380a press identify connect phone with "C" and make sure you have REST FILE and BYPASS PACKAGE available. now go to SETTINGS Tab and tick "SIGNED MODE" + "ALT BYPASS" Back to SEMC Tab press UNLOCK/REPAIR connect phone with "C" key once Setool has finished disconnect the phone and turn it fully on POWER ON AND LET THE MENU APPEARING connect to the cable set "PHONE MODE" install the csca drivers (download w380 drivers from setool support) let Setool detect it and execute it once Software warns to disconnect and pressing READY disconnect phone , remove the battery and put it back press READY and connect phone with "C" let SETOOL working to finish it ... Now you're dun BR Max_B Last edited by Max_B; 03-16-2009 at 00:59. |
03-16-2009, 01:40 | #7 (permalink) | |
No Life Poster Join Date: Dec 2008 Location: SWEDEN-China-Thailand-Singapor
Member: 917893 Status: Offline Sonork: 100.1584763 Thanks Meter: 3,156 | Quote:
.... and if REST FILE and BYPASS PACKAGE available. NOT "PRESENT" then select in setting *signed mode *enable alternative bypass security *unlock after flash *complete phone after flash then put your cid 53 files in flash area an put generic file in your restore file area then press flash br | |
HOW TO unlock SE v600i ??please help | xiongfuchen | SETool2 | 15 | 05-21-2013 08:10 |
@ URGENT @ Please help : "Samsung Z500v" problem | shicnus | Hardware Repair by brands | 0 | 11-29-2006 20:30 |
@ URGENT @ Please help : "Samsung Z500v" problem | shicnus | Samsung Hardware Repair | 0 | 11-29-2006 20:25 |
big problem urgent please help | emso | Motorola P2K (USB-Smart) | 2 | 04-27-2006 08:54 |
