05-28-2010, 14:08 | #1 (permalink) |
No Life Poster Join Date: Apr 2009
Member: 1012165 Status: Offline Thanks Meter: 116 | w380i cid 53 unlock help enable alternative security bypass enable preloader security bypass here is log v0.915057/UNI CARD SERIAL: 00042035 Loaded 51 flash descriptors CFG:000000000000 ChipID000,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0053 skipping empty loader... OTP: LOCKED:1 CID:52 PAF:1 IMEI:35983902462152 CERT:RED Model (from GDFS):W380a Brand:Generic MAPP CXC article: R10CA001 prg1201-4421_GENERIC_LE MAPP CXC version: R10CA001 Language Package: AMERICA_1 CDA article: 1205-0510 CDA version: R2A Default article: 1201-4439 Default version: R10CA001 PROVIDER: MULTIPLE Network LOCKED RESTORATION FILE NOT PRESENT "R10CA001_1201-4421_GENERIC_LE" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE SECURITY UNITS BACKUP CREATED. Elapsed: 1 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110000000000 ChipID000,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0053 Speed:921600 OTP: LOCKED:1 CID:52 PAF:1 IMEI:35983902462152 CERT:RED LDR:071213 1552 PERCXC1720441_R2A022_PNX5230_FLASHLOADER FLASH ID:897E LDR:070904 1356 AN2CXC1250610_R3A016_PNX5230_CSLOADER loadr startup: executed loadeQr GDFS startup: executed loader filesystem startup: executed loader unlock: executed DISCONNECT PHONE NOW INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM39 PHONE READY TO PROCEED EXECUTOR STARTED REMOVE CABLE FROM PHONE REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK FINALLY PRESS "READY" ChipID000,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0053 Speed:921600 Starting embedded bootloader... INT LDR:PNX5230_PRELOADER_FOR_SETOOL2 LDR:PNX5230_PRODUCTION_LOADER_FOR_SETOOL2 FLASH ID:897E FOUND VERSION "R10CA001_1201-4421_GENERIC_LE" can't open file "C:\Documents and Settings\TONY\Desktop\setool\rest\R10CA001_1201-4421_GENERIC_LE" USERCODE RESET TO "0000" Searching... Firmware SIMLOCK check determined. Unlock FINISHED here is log after unlock phone dies then i clicked just sign mode and customize phone now on but not unlocked pls help me the customer is not willing to leave the phone behind |
05-28-2010, 18:46 | #2 (permalink) |
No Life Poster Join Date: Sep 2007 Location: algeria
Member: 591880 Status: Offline Thanks Meter: 561 | Code: clicked signed mode enable alternative security bypass enable preloader security bypass Code: CFG:110000000000 Code: can't open file "C:\Documents and Settings\TONY\Desktop\setool\rest\R10CA001_1201-4421_GENERIC_LE" |
The Following User Says Thank You to algerienbox For This Useful Post: |
