12-22-2008, 13:07 | #1 (permalink) |
No Life Poster Join Date: Mar 2007 Location: SL3;HTC DesireHD DIRECT UNLOCk Age: 44
Member: 476287 Status: Offline Sonork: 100.1587961 Thanks Meter: 834 | w380i not unlok CARD SERIAL: 00051719 Loaded 51 flash descriptors SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. PRELOADER SECURITY BYPASS ENABLED. ChipID000,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:53 skipping empty loader... OTP LOCKED:1 CID:52 PAF:1 IMEI:35565202608279 CERT:RED Model:W380i Brand:ORANGE F MAPP CXC article: R10CA001 prg1201-4833_ORANGE_LE MAPP CXC version: R10CA001 Language Package:ORANGE_GEN CDA article: 1205-1882 CDA version: R10A Default article: 1201-4439 Default version: R10CA001 PROVIDER: 208-01 Network LOCKED RESTORATION FILE PRESENT FOR DETECTED FIRMWARE BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE SECURITY UNITS BACKUP CREATED. Elapsed: 13 secs. SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. PRELOADER SECURITY BYPASS ENABLED. ChipID000,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:53 Speed:921600 OTP LOCKED:1 CID:52 PAF:1 IMEI:35565202608279 CERT:RED LDR:071213 1552 PERCXC1720441_R2A022_PNX5230_FLASHLOADER Flash ID check:2019 Flash props sent ok LDR:070904 1356 AN2CXC1250610_R3A016_PNX5230_CSLOADER loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed DISCONNECT PHONE NOW INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN BE SURE THAT YOU SET PHONE IN "PHONE MODE" IF ASKED, INSTALL PHONE DRIVERS SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM12 PHONE READY TO PROCEED EXECUTOR STARTED REMOVE CABLE FROM PHONE REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS "READY" ChipID000,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:53 Speed:921600 Trying to launch embedded bootloader... embedded flashloader not responds ! Elapsed: 187 secs. |
12-22-2008, 16:21 | #2 (permalink) |
No Life Poster Join Date: Jan 2005 Location: IN YOUR HEART
Member: 109163 Status: Offline Thanks Meter: 75 | you have 4 choices what do: 1. terminate process (press stop) and retry from beginning. 2. as phone powered on now, go to menu->games and run program called "executor". phone should "turn off",sometimes with white screen,sometimes not. Continue procedure then ; Disconnect phone, remove battery, insert battery, press "READY", then connect phone while holding corresponding button ('C' ). In 99% cases phone will reboot and connects automatically 3. if you run "executor",but pressed stop - go to settings, check ONLY "enable preloader security bypass" - now you can do any operation with phone, like unlock/etc. 4. reflash phone in "signed mode" and start unlock again. thanks to laser |
w380i not conacting se tool help me any one | mobiletuch | Sony Ericsson Hardware Repair | 4 | 12-24-2009 09:59 |
cu920 not unloked in eu but unloked in other tool | peter002 | Easy-Unlocker | 0 | 11-16-2009 18:01 |
W380i not supported | computs | KULANKENDI Server | 1 | 09-30-2008 11:49 |
E370 not unloked by Polar2 | dipu | PolarBox 3 | 4 | 12-01-2006 13:34 |
sharp 703 SH not unloking | alunecosu_hd | SonyEricsson (USB-Smart) | 3 | 02-17-2006 21:13 |
