02-23-2010, 02:26 | #1 (permalink) |
Freak Poster Join Date: Mar 2004 Location: Slovakia VT
Member: 59529 Status: Offline Thanks Meter: 115 | w395 problem flashing where is problem ? I can't flashing phone RUNNING v0.915060/UNI CARD SERIAL 000****** USBFLASH DRIVER VERSION 02.02.00.05 SIGNED MODE (USING SERVER) CFG:100000000000 PLEASE ATTACH TURNED OFF PHONE NOW EROM "R7A024" AID: 0001 SOFTWARE AID: 0001 SIMLOCK STATE: "NOT_TAMPERED" LOADER AID: 0004 phone AID not supported (0004) FAILED TO SETUP PHONE Elapsed: 14 secs. Thanks |
03-23-2010, 21:57 | #5 (permalink) |
Registered User Join Date: Apr 2007 Location: ==**Syria**== Age: 44
Member: 493205 Status: Offline Sonork: 100.1581647 Thanks Meter: 526 | ....... on settings, check "signed mode", "use alternative security bypass" it will be ok.. Last edited by yarra; 03-23-2010 at 22:04. |
06-09-2010, 13:02 | #8 (permalink) |
No Life Poster Join Date: Jun 2006 Location: {JUST@PRAY@FOR@ME} Age: 39
Member: 288504 Status: Offline Sonork: .:100.1587032:. Thanks Meter: 2,266 | FLASHING OF SEMC S1-BASED ODM PHONES 1. select correct model 2. use com/ufs/usb as interface 3. check "signed mode" 3. add to firmware area needed firmware files 4. press flash notes: some old locosto s1 phones does not support usb as interface if you want flash brown firmware or readout, step 3 will be: 3. check "signed mode","alternative security bypass" |
E52 RM-469 Flashing problem.Flash ID not supported for this loader (RAPUv11_algo_xsr1 | rafik2533 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 04-04-2010 20:38 |
w395 problem after flashing hang on welcome Note | aljolas | SETool2 | 1 | 02-14-2010 08:46 |
setool w395 problem | shak360 | SETool2 | 1 | 12-28-2009 17:59 |
w395 problem | blueteamgsm | Cruiser Suite | 2 | 08-05-2009 19:20 |
N3210 flash problem. flash id:FFFFFFF | pali | Nokia Hardware & Hardware Repair | 7 | 05-26-2002 22:48 |
