Unlock Server
Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (Non-Official Support) > SETool2
Old 02-16-2010, 10:03   #1 (permalink)
Misbahullah's Avatar
Member: 938983
Sonork: 100.1585802
W550 insert correct sim
i have flashed w550 but when i on it shows insert correct sim when i get info it shows not locked
v0.915057/UNI
CARD SERIAL: 00050695
Loaded 51 flash descriptors
CFG:000000000000
ChipID:8040,EMP protocol:0301
OBSOLETE EROM,FORCING "RETAIL" PHONE STATE
OBSOLETE EROM,FORCING "CID49"
PHONE STATE: "RETAIL"
FLASH CID: 0049
Speed:921600
FLASH ID:200D
OTP: LOCKED:1 CID:49 PAF:1 IMEI:35744300525051 CERT:RED
FLASH CID:49 COLOR:RED
Model (from GDFS):W550c
MAPP CXC article: R4BA041 prgCXC1250088_TAIWAN_EL
MAPP CXC version: R4BA041
Language Package: CHINESE
CDA article:
CDA version:
Default article: cxc1250032
Default version: R4BA041
PROVIDER: 000-00
SIMLOCKS NOT DETECTED
USERCODE:0000
RESTORATION FILE NOT PRESENT
"R4BA041_CXC1250088_TAIWAN_EL"
YOU MUST PERFORM FULL FLASHING
WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED
Elapsed: 9 secs.
i have flashed it with different version
Old 02-16-2010, 10:05   #2 (permalink)
Member: 644210
add restoration file and do unlock repair....
Old 02-16-2010, 10:06   #3 (permalink)
Umair Rashid's Avatar
Member: 421117
Sonork: Hidden
Flash the phone and Unlock (although it shows no lock)
If not helps u need to do RESTORE method.
Br,
Umair
Old 02-16-2010, 10:08   #4 (permalink)
venuno's Avatar
Member: 532761
Sonork: 100-1592994
just download that rest file to support and paste
into rest file folder.
for unlocking besure rest file and security bypass are present
in settings tab
check
1
2
3
tick unlock repair
prepared original sim or testcard
Old 02-16-2010, 10:24   #5 (permalink)
Member: 938983
Sonork: 100.1585802
in settings tab
check
1
2
3
tick unlock repair
when i put test sim or original sim it also shows insert correct sim
Old 02-16-2010, 10:27   #6 (permalink)
xerraco's Avatar
Member: 890926
WRONG! Phone is DD2010
in settings tab
check
1
2
3
tick unlock repair
Add Main the Identify, then Clear Identify again be sure REST File is Present then Unlock/Repair.
Dowload REST File. Nothing is Check Just Click Unlock/Repair
v0.915057/UNI
CFG:000000000000
FLASH CID: 0049
Speed:921600
FLASH ID:200D
CDA article:
CDA version:
PROVIDER: 000-00
USERCODE:0000
Elapsed: 9 secs.
Old 02-16-2010, 10:29   #7 (permalink)
xerraco's Avatar
Member: 890926
No need SIM Mate, just REST File.
Old 02-16-2010, 10:32   #8 (permalink)
Maiwand khan's Avatar
Member: 295886
Sonork: 100.1583369
phone is 5 locks closed
Old 02-16-2010, 10:45   #9 (permalink)
R@jusat's Avatar
Member: 745721
Sonork: 100.1605292
yes i agrry with you its 5 locks closed phone
Old 02-16-2010, 10:48   #10 (permalink)
Member: 938983
Sonork: 100.1585802
how to solve this problem
this is the log when i unlock the set and restoration file is present when i identify set for second time
FLASH CID: 0049
Speed:921600
LDR:051207 0928 NPACXC1250165_1_SEMC_COMPACTFLASHLOADER R2B
FLASH ID:200D
LDR:070524 1030 AN2CXC1327364_COMPACT_SEMC_CS_LOADER__R3A010
Executing CSCA-based unlock.
Backup security data...
loader startup: executed
loader GDFS startup: executed
loader unlock: executed
Erasing locks...
DISCONNECT PHONE NOW
REMOVE SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN
INSTALL PHONE MODEM DRIVERS IF NEEDED
SEARCHING FOR PHONE, "STOP" TO ABORT
PHONE FOUND AT COM22
PHONE READY TO PROCEED.
server step1 error:No server found.
CSCA UNLOCK FAILED
Elapsed: 103 secs.
Old 02-16-2010, 10:54   #11 (permalink)
Member: 295886
Sonork: 100.1583369
FLASH CID: 0049
Speed:921600
FLASH ID:200D
Erasing locks...
CSCA UNLOCK FAILED
Elapsed: 103 secs.
plz dont be sooo lazy
search for 5 locks closed
Old 02-16-2010, 11:29   #12 (permalink)
NawabN Sahoo's Avatar
Member: 687312
v0.915057/UNI
CFG:000000000000
FLASH CID: 0049
Speed:921600
FLASH ID:200D
CDA article:
CDA version:
PROVIDER: 000-00
USERCODE:0000
Elapsed: 9 secs.
Bro If you have Identified before unlocking, Write your backup file from misc tab and your backup is stored in backup folder of Setool according your phone IMEI, Just slect your backup file from misc tab and tick on sign mode and press write script.
WBR
Old 02-17-2010, 02:59   #13 (permalink)
xerraco's Avatar
Member: 890926
Settings:Unlock after Flash then Customize Phone. thenFlash.
The Following User Says Thank You to xerraco For This Useful Post:
Old 02-17-2010, 04:46   #14 (permalink)
Member: 938983
Sonork: 100.1585802
@ XERRACO thanks brother for your sugesstion it has done sucessfully you are more experienced then other forum members who answered to this post thanks for all who answered to this thread
i tick marked
4: Customize phone after flash
5: unlock during flash procedure
6: perform full unlock instead of USER CODE RESET
and this is full log
FLASH CID: 0049
Speed:921600
FLASH ID:200D
CDA article:
CDA version:
PROVIDER: 000-00
USERCODE:0000
RESTORATION FILE PRESENT FOR DETECTED FIRMWARE
Elapsed: 38 secs.
CFG:000111000000
FLASH CID: 0049
Speed:921600
FLASH ID:200D
REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK
THEN PRESS "READY"
Starting embedded bootloader...
INT LDR:COMPACT_ID_LOADER_CRIPPLED_SETOOL2_R2
LDR:041214 0816 LLECXC1326743_COMPACTPRODUCTION R2AB
FLASH ID:200D
FOUND VERSION "R4BA041_CXC1250088_TAIWAN_EL"
Setting up GDFS...
WRITING CLEAR SIMLOCK UNITS...
SIGNING...
LDR:COMPACT_SEMC_FS_LOADER_SETOOL2_V26
loader filesystem startup: executed
using GENERIC phone customization
tpa/preset/custom/C3_PCA_G3v2.cer
tpa/preset/custom/CONTENT_DOWNLOAD_HOOK_2.itm
tpa/preset/custom/customize.xml
tpa/preset/custom/DESKTOP_HOOK_2.itm
tpa/preset/custom/Entrust.net Root Certificate.cer
tpa/preset/custom/Entrust.net_WTLS_Root_Certificate.wcrt
tpa/preset/custom/FM_PICTURES_HOOK_3.itm
tpa/preset/custom/FM_SOUNDS_HOOK_3.itm
tpa/preset/custom/FM_THEMES_HOOK_3.itm
tpa/preset/custom/FM_VIDEOS_HOOK_3.itm
tpa/preset/custom/GAMES_HOOK_3.itm
tpa/preset/custom/GTE_CyberTrust_Root.cer
tpa/preset/custom/GTE_Cybe_Trust_Root_WTLS.wcrt
tpa/preset/custom/Root.cer
tpa/preset/custom/SEMC_E2E_Root_CA.crt
tpa/preset/custom/SETT_RINGTONE_HOOK_3.itm
tpa/preset/custom/ThawtePremium.der
tpa/preset/custom/ThawteServerCA.cer
tpa/preset/custom/Utiroot.cer
tpa/preset/custom/VeriSignClass3Root.cer
tpa/preset/custom/Verisign_Class_3_CA_WTLS.wcrt
Phone detached
Elapsed: 99 secs.
NOTE: I didn't select files for flashing
Old 02-17-2010, 08:37   #15 (permalink)
roney_nexus's Avatar
Member: 288504
Sonork: .:100.1587032:.
Arrow
v0.915057/UNI
CFG:000000000000
FLASH CID: 0049
Speed:921600
FLASH ID:200D
CDA article:
CDA version:
PROVIDER: 000-00
USERCODE:0000
Elapsed: 9 secs.
bro chk for this thread how to unlock w550i
Tell me any kind of se problem,i will tery to solve it only in 3 hour........
thx 4 adv....
Z310a, whwn I put test sim card it shows insert correct sim card. manistar SETool2 6 01-21-2009 19:11
w550 insert correct simcard jmustufa Sony Ericsson Hardware Repair Area 5 01-24-2008 16:17
NEC DB500 after 'unlock' insert correct sim !? brussl Various 1 03-05-2002 05:48
Alcatel Easy DB no network, insert correct sim!!! HHHEEELLLLPPPP! OncleOh Alcatel & TCL Old Models 5 09-26-2001 12:46
T28s, Insert correct SIM Larsson Old Ericsson Phones & Sony Phones 3 09-25-2001 14:33
Page generated in 0.68069 seconds with 11 queries
