11-05-2011, 16:15 | #1 (permalink) |
Major Poster Join Date: Feb 2004 Location: moroco Age: 45
Member: 53647 Status: Offline Thanks Meter: 5 | W580 unlock probleme RUNNING v 1.1201/01.13/UNI CARD SERIAL 00082684 USBFLASH DRIVER VERSION 02.02.00.05 SIGNED MODE (USING SERVER) CFG:100010000000 llbug:read error: "Le périphérique ne reconnaît pas la commande" FAILED TO SETUP PHONE Unlock FAILED Elapsed: 25 secs. SIGNED MODE (USING SERVER) CFG:100010000000 ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 LDR:071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M OTP LOCKED:1 CID:51 PAF:1 IMEI:35164903420517 CERT:RED ACTIVE CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID: 897E LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 Executing CSCA-based unlock. Checking for signature ... Waiting for calculation process ... RESPONSE: "SUCCESS" [1038] Backup security data ... loader startup failed, that is fatal Unlock FAILED Elapsed: 16 secs. |
11-05-2011, 16:27 | #2 (permalink) |
No Life Poster Join Date: Feb 2008
Member: 696136 Status: Offline Thanks Meter: 210 | YOur phone does not require credits to unlock, it's free, you wasted your credits and you didn't read faq that's why it happens, anyway forget it and if you want to unlock best way is reset procedure as follows. CID 50,51,52,53 that is so-called reset procedure. 1. go to emptyboard tab 2. select proper model 3. on settings, check "signed mode" 4. press recovery 5. after succeful recovery 6. on settings uncheck all 7. add to firmware area proper EROM (EROM CID >= OTP CID) 8. press flash Do exact procedure as described your phone will be unlocked. And spend some time here F.A.Q. |
11-06-2011, 02:00 | #3 (permalink) | |
Member: 53647 Status: Offline Thanks Meter: 5 | Quote:
i know how to unlock phone with patch but customer need phone full unlocked because unlock by patch after flashing or uptating need always re unlock | |
11-06-2011, 12:58 | #6 (permalink) |
No Life Poster Join Date: Apr 2010 Location: NICE MOBILES Age: 35
Member: 1293519 Status: Offline Sonork: 100.1596500 Thanks Meter: 169 | [B]YOur phone does not require credits to unlock, it's free, you wasted your credits and you didn't read faq that's why it happens, anyway forget it and if you want to unlock best way is reset procedure as follows. CID 50,51,52,53 that is so-called reset procedure. 1. go to emptyboard tab 2. select proper model 3. on settings, check "signed mode" 4. press recovery 5. after succeful recovery 6. on settings uncheck all 7. add to firmware area proper EROM (EROM CID >= OTP CID) 8. press flash Do exact procedure as described your phone will be unlocked. And spend some time here F.A.Q. nice info................[/B] |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
