09-28-2008, 15:04 | #1 (permalink) |
No Life Poster Join Date: Jul 2007 Location: Dhaka, Bangladesh.
Member: 552244 Status: Offline Sonork: 100.1578827 Thanks Meter: 180 | W580 Unlocking problem. After I triyed script Wright to cid change, than show No suitable Fsloader found. All log attached bellow:- Here is Identify Log:- SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. PRELOADER SECURITY BYPASS ENABLED. ChipID:9900,EMP protocol:0301 PHONE IS BROWN FLASH CID detected:49 Speed:921600 Flash ID check:897E Flash props sent ok OTP LOCKED:1 CID:51 PAF:1 IMEI:35243002378856 CERT:BROWN 9/28/2008 7:48:15 PM FLASH CID:49 COLOR:BROWN Model:MODEL Brand:OPERATOR MAPP CXC article: R6BC002 prgCXC1123362_GENERIC_LA MAPP CXC version: R6BC002 Language Package:MEDITERR CDA article: CDA_NUMBER CDA version: CDA_REVISION Default article: cxc1123364 Default version: R6BC002 PROVIDER: 000-00 SIMLOCKS NOT DETECTED RESTORATION FILE PRESENT FOR DETECTED FIRMWARE BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE SECURITY UNITS BACKUP CREATED. Elapsed: 7 secs. Here is unlocking log:- SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. PRELOADER SECURITY BYPASS ENABLED. ChipID:9900,EMP protocol:0301 PHONE IS BROWN FLASH CID detected:49 Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:35243002378856 CERT:BROWN FLASH CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER Flash ID check:897E Flash props sent ok Setting up GDFS... Writing simlocks... ull sig complete. Unlock DONE Elapsed: 10 secs. Here is write script log:- SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. PRELOADER SECURITY BYPASS ENABLED. Processing script "C:\Documents and Settings\AKTER.D-2598BFA83DC94\Desktop\v0.914041\script\071219_DB20 20_CROD_CID_49___51_to_CID52_Red.gdfs"... ChipID:9900,EMP protocol:0301 PHONE IS BROWN FLASH CID detected:49 Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:35243002378856 CERT:BROWN FLASH CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER Flash ID check:897E Flash props sent ok No situable fsloader found, exiting Elapsed: 11 secs. Anyone can give me information for unlock this phone ? |
09-28-2008, 15:58 | #3 (permalink) |
No Life Poster Join Date: Aug 2007 Location: England
Member: 575900 Status: Offline Thanks Meter: 3,177 | just only write erom, signing will be done automaticaly. and write erom in repair tab |
The Following User Says Thank You to NADEEM GONDAL For This Useful Post: |
09-29-2008, 15:50 | #4 (permalink) | |
Member: 552244 Status: Offline Sonork: 100.1578827 Thanks Meter: 180 | Quote:
If i triyed erom write on Empty fill,than show No suitable fsloader found Last edited by .::MD_AKTER::.; 09-29-2008 at 15:55. | |
09-29-2008, 16:43 | #5 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Bulgaria/China Age: 58
Member: 391664 Status: Offline Sonork: Python Thanks Meter: 1,063 | bro use this erom file k610_erom_cnv_BROWN49_BROWN_CID49_DB2020.ssw than complete flash it and post identify log BR MapleGsm(umer) |
w580 CID52 unlock problems FURIOUSTEAM pls advice | PTR999 | FuriousGold | 14 | 05-21-2010 15:11 |
W580 Unlock PRoblem | srini.unique | Sony Ericsson | 2 | 03-10-2009 00:59 |
W580 unlock problem | usernome | Universalbox | 0 | 11-05-2008 16:13 |
W580 Camera Problem | mtech6928 | Sony Ericsson Hardware Repair | 0 | 07-08-2008 09:07 |
W580 flash problem | foreman77 | SETool2 | 0 | 11-15-2007 18:02 |
