11-22-2008, 15:11 | #3 (permalink) |
No Life Poster Join Date: Jul 2004 Location: KOLHAPUR, MAHARASTRA,INDIA
Member: 71502 Status: Offline Sonork: 100.1650667 Thanks Meter: 587 | v0.915020/UNI CARD SERIAL: 0000xxxx Loaded 51 flash descriptors Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35297302298225 CERT:N/A FLASH CID:52 COLOR:RED phone CID not supported in that mode Elapsed: 1 secs. cid 52 R8BE001_1123362_GENERIC_LA.ssw flash file select any test point for flashing |
11-22-2008, 15:35 | #4 (permalink) |
Member: 71502 Status: Offline Sonork: 100.1650667 Thanks Meter: 587 | v0.915020/UNI CARD SERIAL: 0000xxxx Loaded 51 flash descriptors SIGNED MODE (USING SERVER). Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35297302298225 CERT:N/A FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:897E Flash props sent ok writing C:\Documents and Settings\OM\Desktop\R8BE001_1123362_GENERIC_LA.ssw CURRENT FLASH FILE CID:52 SSW uses full hash, hash len is:9200 Will flash 460 blocks... SSW loading returns:0 LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed writing "tpa/preset/custom/C3_PCA_G3v2.cer" writing "tpa/preset/custom/CONTENT_DOWNLOAD_HOOK_2.itm" writing "tpa/preset/custom/customize.xml" writing "tpa/preset/custom/DESKTOP_HOOK_2.itm" writing "tpa/preset/custom/Entrust.net Root Certificate.cer" writing "tpa/preset/custom/Entrust.net_WTLS_Root_Certificate.wcrt" writing "tpa/preset/custom/FM_PICTURES_HOOK_3.itm" writing "tpa/preset/custom/FM_SOUNDS_HOOK_3.itm" writing "tpa/preset/custom/FM_THEMES_HOOK_3.itm" writing "tpa/preset/custom/FM_VIDEOS_HOOK_3.itm" writing "tpa/preset/custom/GAMES_HOOK_3.itm" writing "tpa/preset/custom/GTE_CyberTrust_Root.cer" writing "tpa/preset/custom/GTE_Cybe_Trust_Root_WTLS.wcrt" writing "tpa/preset/custom/Root.cer" writing "tpa/preset/custom/SEMC_E2E_Root_CA.crt" writing "tpa/preset/custom/SETT_RINGTONE_HOOK_3.itm" writing "tpa/preset/custom/ThawtePremium.der" writing "tpa/preset/custom/ThawteServerCA.cer" writing "tpa/preset/custom/Utiroot.cer" writing "tpa/preset/custom/VeriSignClass3Root.cer" writing "tpa/preset/custom/Verisign_Class_3_CA_WTLS.wcrt" Phone detached Elapsed: 567 secs. but same problem.i think this is the h/w problem in menu opp. bluethoot is always on no on/off opp. show Last edited by omkarvitekar; 11-22-2008 at 15:41. |
11-22-2008, 18:23 | #7 (permalink) |
Member: 71502 Status: Offline Sonork: 100.1650667 Thanks Meter: 587 | heat d1000 bluetooth ic same problem fresh board on the board d1000 bluetooth ic i heat normally & clean BT antenna but same problem |
w580i display problem | electrosoft | Sony Ericsson Hardware Repair | 3 | 06-03-2010 06:52 |
where is w580i bluetooth ic | ravin j tejura | Sony Ericsson Hardware Repair | 3 | 03-26-2010 09:35 |
w580i bluetooth not work | sr8787 | Sony Ericsson Hardware Repair | 4 | 02-17-2010 00:28 |
w580i unlock problem plz help hackr3k2k | ..:::Gsm india:::.. | FuriousGold | 1 | 03-09-2008 08:14 |
w580i language problem | akbarbaba | MT-BOX | 7 | 11-21-2007 20:23 |
