01-06-2008, 12:58 | #1 (permalink) |
Junior Member Join Date: Dec 2005
Member: 206895 Status: Offline Thanks Meter: 1 | w580i dead after unlock need help v0.914020/UNI CARD SERIAL: 00051137 Loaded 51 flash descriptors Open COM port OK ChipID:9900,EMP protocol:0301 Speed:460800 OTP LOCKED:1 CID:51 PAF:1 IMEI:35683401394381 CERT:N/A FLASH CID:52 COLOR:RED phone CID not supported in that mode Elapsed:3 secs. SERVER SUPPORT ENABLED. ALTERNATIVE SECURITY BYPASS ENABLED. Open COM port OK ChipID:9900,EMP protocol:0301 Speed:460800 Flash ID check:897E Flash props sent ok OTP LOCKED:1 CID:51 PAF:1 IMEI:35683401394381 CERT:N/A FLASH CID:52 COLOR:RED Model:K700 MAPP CXC article: R1JC002 prgCXC1250202_ORANGE_CY MAPP CXC version: R1JC002 Language Package:ROGERS CDA article: CDA102774/87 CDA version: R10A Default article: cxc1123364 Default version: R6BE001 Network LOCKED Operator: 302-72 RESTORATION FILE PRESENT FOR DETECTED FIRMWARE Elapsed:14 secs. SERVER SUPPORT ENABLED. ALTERNATIVE SECURITY BYPASS ENABLED. Open COM port OK ChipID:9900,EMP protocol:0301 Speed:460800 OTP LOCKED:1 CID:51 PAF:1 IMEI:35683401394381 CERT:N/A FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:897E Flash props sent ok CID52 BYPASS PROCEDURE STARTED Processing part1... Processing part2... Processing part3.... Open COM port OK OTP LOCKED:1 CID:51 PAF:1 IMEI:35683401394381 CERT:N/A FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:897E Flash props sent ok RESTARTING PHONE,IF PHONE NOT RESTARTS,THEN REMOVE BATTERY FROM PHONE AND INSERT IT BACK Open COM port OK CID52 BYPASS PROCEDURE FINISHED bypassing security... Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 Trying to launch embedded bootloader... Embedded flashloader: DB2020_PRELOADER_FOR_SETOOL2 Flash ID check:897E Flash props sent ok writing C:\Documents and Settings\Administrator\Desktop\setool 3\flash file\w580i52\R8BA024_1123476_CHINA_LA.ssw CURRENT FLASH FILE CID:52 SSW uses complete hash, hash len is:9200 Will flash 460 blocks... SSW loading returns:0 writing C:\Documents and Settings\Administrator\Desktop\setool 3\flash file\w580i52\R8BA024_FS_CHINA_LA_RED_CID52.ssw CURRENT FLASH FILE CID:52 SSW uses complete hash, hash len is:4340 Will flash 217 blocks... SSW loading returns:0 full sig complete. USERCODE RESET TO "0000" Searching... Firmware lock check determined. LDR:060426 1726 HANCXC1329133_DB2020_FILESYSTEMLOADER_P5G loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed writing tpa/preset/custom/C3_PCA_G3v2.cer writing tpa/preset/custom/CONTENT_DOWNLOAD_HOOK_2.itm writing tpa/preset/custom/customize.xml writing tpa/preset/custom/DESKTOP_HOOK_2.itm writing tpa/preset/custom/Entrust.net Root Certificate.cer writing tpa/preset/custom/Entrust.net_WTLS_Root_Certificate.wcrt writing tpa/preset/custom/FM_PICTURES_HOOK_3.itm writing tpa/preset/custom/FM_SOUNDS_HOOK_3.itm writing tpa/preset/custom/FM_THEMES_HOOK_3.itm writing tpa/preset/custom/FM_VIDEOS_HOOK_3.itm writing tpa/preset/custom/GAMES_HOOK_3.itm writing tpa/preset/custom/GTE_CyberTrust_Root.cer writing tpa/preset/custom/GTE_Cybe_Trust_Root_WTLS.wcrt writing tpa/preset/custom/Root.cer writing tpa/preset/custom/SEMC_E2E_Root_CA.crt writing tpa/preset/custom/SETT_RINGTONE_HOOK_3.itm writing tpa/preset/custom/ThawtePremium.der writing tpa/preset/custom/ThawteServerCA.cer writing tpa/preset/custom/Utiroot.cer writing tpa/preset/custom/VeriSignClass3Root.cer writing tpa/preset/custom/Verisign_Class_3_CA_WTLS.wcrt Phone detached Elapsed:1639 secs. SERVER SUPPORT ENABLED. SERVER CREDITS LEFT/USED: 10/20 CARD COUNTERS: FLASH 66, UNLOCK 66 Elapsed:3 secs. ALTERNATIVE SECURITY BYPASS DISABLED ! CHECK EITHER "USE CARD" OR "USE SERVER" ! Open COM port OK ChipID:9900,EMP protocol:0301 Speed:460800 OTP LOCKED:1 CID:51 PAF:1 IMEI:35683401394381 CERT:N/A FLASH CID:52 COLOR:RED phone CID not supported in that mode Elapsed:12 secs. ALTERNATIVE SECURITY BYPASS DISABLED ! CHECK EITHER "USE CARD" OR "USE SERVER" ! Open COM port OK Abort all operations. phone pre-boot failed,possible RECOVERY needed. Elapsed:32 secs. ALTERNATIVE SECURITY BYPASS DISABLED ! CHECK EITHER "USE CARD" OR "USE SERVER" ! RECOVERY MODE STARTED DB2020 EROM UPGRADE STARTED OTP LOCKED:1 CID:51 PAF:1 IMEI:35683401394381 CERT:RED FLASH CID:52 COLOR:RED Flash ID check:897E Flash props sent ok phone CID not supported in that mode Elapsed:3 secs. ALTERNATIVE SECURITY BYPASS DISABLED ! CHECK EITHER "USE CARD" OR "USE SERVER" ! ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:52 Speed:460800 OTP LOCKED:1 CID:51 PAF:1 IMEI:35683401394381 CERT:RED FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:897E Flash props sent ok phone CID not supported in that mode Elapsed:7 secs. SERVER SUPPORT ENABLED. RECOVERY MODE STARTED DB2020 EROM UPGRADE STARTED OTP LOCKED:1 CID:51 PAF:1 IMEI:35683401394381 CERT:RED FLASH CID:52 COLOR:RED Flash ID check:897E Flash props sent ok EROM UPGRADE CAN'T FIND QUALIFIED PART Elapsed:8 secs. SERVER SUPPORT ENABLED. ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:52 Speed:460800 OTP LOCKED:1 CID:51 PAF:1 IMEI:35683401394381 CERT:RED FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:897E Flash props sent ok writing C:\Documents and Settings\Administrator\Desktop\setool 3\flash file\w580i52\R6BC002_1123362_GENERIC_LA.ssw CURRENT FLASH FILE CID:52 SSW uses complete hash, hash len is:9200 Will flash 460 blocks... SSW loading returns:0 writing C:\Documents and Settings\Administrator\Desktop\setool 3\flash file\w580i52\R6BC002_FS_EUROPE_1_LA_RED_CID52.ssw CURRENT FLASH FILE CID:52 SSW uses complete hash, hash len is:4260 Will flash 213 blocks... SSW loading returns:0 LDR:070410 1557 HANCXC1250562_DB2020_CSLOADER_R3A009 loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed writing tpa/preset/custom/C3_PCA_G3v2.cer writing tpa/preset/custom/CONTENT_DOWNLOAD_HOOK_2.itm writing tpa/preset/custom/customize.xml writing tpa/preset/custom/DESKTOP_HOOK_2.itm writing tpa/preset/custom/Entrust.net Root Certificate.cer writing tpa/preset/custom/Entrust.net_WTLS_Root_Certificate.wcrt writing tpa/preset/custom/FM_PICTURES_HOOK_3.itm writing tpa/preset/custom/FM_SOUNDS_HOOK_3.itm writing tpa/preset/custom/FM_THEMES_HOOK_3.itm writing tpa/preset/custom/FM_VIDEOS_HOOK_3.itm writing tpa/preset/custom/GAMES_HOOK_3.itm writing tpa/preset/custom/GTE_CyberTrust_Root.cer writing tpa/preset/custom/GTE_Cybe_Trust_Root_WTLS.wcrt writing tpa/preset/custom/Root.cer writing tpa/preset/custom/SEMC_E2E_Root_CA.crt writing tpa/preset/custom/SETT_RINGTONE_HOOK_3.itm writing tpa/preset/custom/ThawtePremium.der writing tpa/preset/custom/ThawteServerCA.cer writing tpa/preset/custom/Utiroot.cer writing tpa/preset/custom/VeriSignClass3Root.cer writing tpa/preset/custom/Verisign_Class_3_CA_WTLS.wcrt Phone detached Elapsed:414 secs. SERVER SUPPORT ENABLED. ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:52 Speed:460800 Flash ID check:897E Flash props sent ok OTP LOCKED:1 CID:51 PAF:1 IMEI:35683401394381 CERT:RED FLASH CID:52 COLOR:RED Model:K700 MAPP CXC article: R1JC002 prgCXC1250202_ORANGE_CY MAPP CXC version: R1JC002 Language Package:ROGERS CDA article: CDA102774/87 CDA version: R10A Default article: cxc1123364 Default version: R6BE001 Network LOCKED Operator: 302-72 RESTORATION FILE PRESENT FOR DETECTED FIRMWARE SECURITY UNITS BACKUP CREATED. Elapsed:20 secs. |
01-12-2008, 14:12 | #2 (permalink) |
No Life Poster Join Date: May 2005 Location: Denmark Age: 42
Member: 146369 Status: Offline Thanks Meter: 119 | Here is the problem: Model:K700 The phone has most likely been flashed with W850 firmware... So GDFS is screwed... Try rebuilding it and post results |
01-12-2008, 14:17 | #3 (permalink) |
Product Supporter Join Date: Oct 2007 Age: 39
Member: 609952 Status: Offline Sonork: 100.1574492 Thanks Meter: 154 | your mobile is k700 and you flash with w850 file reflash the mobile from k700 file than try it,s work www.stan1comm.com |
01-12-2008, 14:39 | #4 (permalink) |
Insane Poster Join Date: Oct 2007
Member: 600824 Status: Offline Thanks Meter: 23 | This mobile is not a K700, this phone is a 2020 based cid 52 model, which K700 is far from. the problem is showing up a lot with w580, i suggest you have a look on setool forum. |
Coral 400FM.. Dead after unlock!! Need Help... | parengBok | Infinity-Box | 0 | 02-25-2010 04:44 |
SE W580i dead after wrong flash HELP! | rayboss | Cruiser Suite | 12 | 08-23-2008 13:35 |
Sony Ericsson Z200 dead after unlock need help please | tle2 | Sony Ericsson | 28 | 01-03-2007 17:15 |
A650 dead after unlock!!! need help please! | Tan Thanh | Motorola Hardware Repair | 0 | 10-24-2006 23:32 |
sharp tm150 dead after unlocking.. need help! | ryumahon | Sharp | 3 | 09-29-2005 13:26 |
