10-16-2009, 08:54 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: INDIA Age: 38
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | W580i LOCKED TO AT&T UNLOCKED SUCESSFULLY WITH SETOOL:)- Code: v0.915053/UNI CARD SERIAL: 000xxxxx Loaded 51 flash descriptors SIGNED MODE (USING SERVER) CFG:100001000000 ChipID:9900,EMP protocol:0301 Speed:921600 FLASH ID:897E OTP: LOCKED:1 CID:51 PAF:1 IMEI:01157200447017 CERT:N/A FLASH CID:52 COLOR:RED Model (from GDFS):W580i Brand:ATT MAPP CXC article: R8BE001 prgCXC1123480_CINGULAR_LA MAPP CXC version: R8BE001 Language Package: CINGULAR CDA article: CDA102774/102 CDA version: R25A Default article: cxc1123364 Default version: R8BE001 PROVIDER: MULTIPLE Network LOCKED RESTORATION FILE PRESENT FOR DETECTED FIRMWARE BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE Elapsed: 10 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED PRELOADER SECURITY BYPASS ENABLED CFG:111001000000 ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:01157200447017 CERT:N/A FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID:897E LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed INSERT SIM CARD, FULLY TURN PHONE ON GO TO GAMES MENU AND RUN EXECUTOR AFTER PHONE TURNS OFF OR HANGS REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK FINALLY PRESS "READY" ChipID:9900,EMP protocol:0301 Speed:921600 Starting embedded bootloader... INT LDR:DB2020_PRELOADER_FOR_SETOOL2 LDR:DB2020 LOADER FOR SETOOL2 FLASH ID:897E FOUND VERSION "R8BE001_CXC1123480_CINGULAR_LA" USERCODE RESET TO "0000" Searching... Firmware SIMLOCK check determined. Unlock FINISHED Elapsed: 228 secs. WBR sahil2000ind |
The Following 3 Users Say Thank You to sahil2000ind For This Useful Post: |
01-20-2015, 10:07 | #2 (permalink) |
Freak Poster Join Date: Apr 2011 Location: punjab
Member: 1562820 Status: Offline Sonork: [email protected] Thanks Meter: 32 | RUNNING v 1.1405/01.12/UNI CARD SERIAL 0********* USBFLASH DRIVER VERSION 03.00.00.00 CFG:000000000000 PROCEDURE WAS STOPPED BY USER FAILED TO SETUP PHONE Unlock FAILED Elapsed: 2 secs. SIGNED MODE (USING SERVER) CFG:100000000000 ChipID: 9900, EMP protocol: 0301 PHONE DOMAIN: "RETAIL" PHONE CID: 0052 SPEED: 115200 LDR: 071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M FLASH ID: 897E OTP: LOCKED:1 CID:51 PAF:1 IMEI:01127100499126 CERT:RED ACTIVE CID: 52 COLOR: RED Model (from GDFS): W580i MAPP CXC article: R7AC001 prgCXC1123480_CINGULAR_LA MAPP CXC version: R7AC001 Language Package: CINGULAR CDA article: CDA102774/102 CDA version: R17A Default article: cxc1123364 Default version: R7AC001 NETWORK LOCKED PROVIDER: 310-150 PROVIDER: 310-170 PROVIDER: 310-410 PROVIDER: 311-180 PROVIDER: 310-980 SECURITY UNITS BACKUP CREATED. Elapsed: 9 secs. SIGNED MODE (USING SERVER) CFG:100000000000 ChipID: 9900, EMP protocol: 0301 PHONE DOMAIN: "RETAIL" PHONE CID: 0052 SPEED: 115200 LDR: 071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M OTP: LOCKED:1 CID:51 PAF:1 IMEI:01127100499126 CERT:RED CURRENT CID: 52 COLOR: RED LDR: 061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR: 080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID: 897E LDR: 070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 GDFS startup executed USERCODE RESET TO "0000" Unlock DONE Elapsed: 63 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110000000000 ChipID: 9900, EMP protocol: 0301 PHONE DOMAIN: "RETAIL" PHONE CID: 0052 SPEED: 115200 LDR: 071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M OTP: LOCKED:1 CID:51 PAF:1 IMEI:01127100499126 CERT:RED CURRENT CID: 52 COLOR: RED FLASH ID: 897E Downgrading security ... DETACH CABLE FROM PHONE, THEN CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") ChipID: 9900, EMP protocol: 0301 BOOTROM MODE DETECTED SPEED: 115200 RESET: 070703 1106 NPACXC1250329_DB2020_CERTRESETLOADER_P3AA GOT SEED: 6B3CE6382380072C0060DB79 P96 AUTH PASSED Restarting ... DETACH CABLE FROM PHONE, THEN CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") ChipID: 9900, EMP protocol: 0301 BOOTROM MODE DETECTED SPEED: 115200 LDR: DB2020 LOADER FOR SETOOL2 CURRENT CID: 49 COLOR: BROWN Setting up GDFS ... WRITING CLEAR SIMLOCK UNITS ... SIMLOCK CODES SET TO "63122313" SIGNING ... Unlock DONE Elapsed: 104 secs. |
6600-s locked to 3 unlocked ok with genie. | POACH | Genie Universal | 0 | 10-15-2009 18:27 |
SAMSUNG S8300 LOCKED TO VODAFONE UNLOCKED SUCESSFULLY BY Z3x IN NO TIME:)- | sahil2000ind | Z3X-Team Products | 1 | 09-27-2009 20:32 |
Samsung a707 locked to at&t connect good with infinity-box)- | sahil2000ind | Infinity-Box | 1 | 07-13-2009 09:31 |
SONY V630i CID 53 LOCKED TO VODAFONE UNLOCKED SUCESS WITH UNIVERSAL BOX:)- | sahil2000ind | Universalbox | 3 | 06-19-2009 10:15 |
N82 Locked to orange Unlock Success With Orange Firmware | sharaz191 | BB5 Box by D.K. | 7 | 01-07-2009 18:28 |
