04-09-2009, 09:04 | #1 (permalink) |
Freak Poster Join Date: Aug 2008 Location: Vienna
Member: 833567 Status: Offline Thanks Meter: 9 | W580i problem HELP!! thats my logs v0.915034/UNI CARD SERIAL: 00036794 Loaded 51 flash descriptors ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0053 Speed:921600 Flash ID check:2019 Flash props sent ok OTP: LOCKED:1 CID:51 PAF:1 IMEI:35598902825724 CERT:RED FLASH CID:53 COLOR:RED no ack during gdfs_readvar ! SCRC READ FAILURE Elapsed: 53 secs. |
04-09-2009, 11:41 | #2 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Pakistan/UAE/WorldWide
Member: 417298 Status: Offline Sonork: 100.1578269 Thanks Meter: 18,268 | Quote:
post all logs here BR | |
04-09-2009, 13:54 | #3 (permalink) |
Member: 833567 Status: Offline Thanks Meter: 9 | W580 not respond v0.915030/UNI CARD SERIAL: 00036794 Loaded 51 flash descriptors ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0053 Speed:921600 Flash ID check:2019 Flash props sent ok OTP: LOCKED:1 CID:51 PAF:1 IMEI:35598902825724 CERT:RED FLASH CID:53 COLOR:RED Model:W580i Brand:Generic MAPP CXC article: R8BE001 prgCXC1123362_GENERIC_LA MAPP CXC version: R8BE001 Language Package:EUROPE_2 CDA article: CDA102568/1 CDA version: R2A Default article: cxc1123364 Default version: R8BE001 PROVIDER: 232-05 Network LOCKED RESTORATION FILE PRESENT FOR DETECTED FIRMWARE BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE SECURITY UNITS BACKUP CREATED. Elapsed: 12 secs. ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0053 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35598902825724 CERT:RED FLASH CID:53 COLOR:RED ldr_on_ldr hdr no ack (00) Elapsed: 52 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED. ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0053 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35598902825724 CERT:RED FLASH CID:53 COLOR:RED PATCH:071120 1355 HANCXC9876543210_DB2020_MEM_PATCHER_R2A012 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 Flash ID check:2019 Flash props sent ok LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed DISCONNECT PHONE NOW INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM155 PHONE READY TO PROCEED EXECUTOR STARTED REMOVE CABLE FROM PHONE REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS "READY" ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0053 Speed:921600 Trying to launch embedded bootloader... embedded flashloader not responds ! Elapsed: 268 secs. |
04-09-2009, 13:57 | #4 (permalink) |
Member: 833567 Status: Offline Thanks Meter: 9 | Here the logs after: Open COM port OK PROCEDURE WAS STOPPED BY USER Can't load ID loader ! Elapsed: 5 secs. ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0053 Speed:921600 Flash ID check:2019 Flash props sent ok OTP: LOCKED:1 CID:51 PAF:1 IMEI:35598902825724 CERT:RED FLASH CID:53 COLOR:RED no ack during gdfs_readvar ! SCRC READ FAILURE Elapsed: 44 secs. |
04-09-2009, 14:21 | #5 (permalink) | |
open software go in setting tab click only third option [enable preloader security bypass] return main select usb press unlock repair BR | |
acount id problem.help uregent plz [SOLVED] | dani2080 | PolarBox 3 | 2 | 03-29-2010 12:46 |
W580i Problem need help urgently | romeoluv56 | SETool2 | 18 | 02-04-2010 17:03 |
W580i problem please HELP!! | nova_mobil | SETool2 | 6 | 02-25-2009 21:08 |
W580i Unlock/Flash Problem....HELP! | Rowdy1 | SETool2 | 20 | 09-07-2008 16:59 |
Need Help Unlocking SE W580i! Please Help! | babycafe | Seking Server | 1 | 01-18-2008 01:35 |
