02-24-2009, 21:18 | #1 (permalink) |
Freak Poster Join Date: Aug 2008 Location: Vienna
Member: 833567 Status: Offline Thanks Meter: 9 | W580i problem please HELP!! i want to unlock one W580i setool ask me to turn on the phone with simcard and conect the usb cabel but it give me an error . now when i press Identfiy i get this logs: v0.915030/UNI CARD SERIAL: 00036794 Loaded 51 flash descriptors ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:921600 Flash ID check:2019 Flash props sent ok OTP: LOCKED:1 CID:51 PAF:1 IMEI:35344802932862 CERT:N/A FLASH CID:52 COLOR:RED no ack during gdfs_readvar ! SCRC READ FAILURE Elapsed: 42 secs. eny one have the same problem?? and how i can slove it? BR |
02-25-2009, 00:09 | #2 (permalink) |
Registered User Join Date: Apr 2007 Location: ==**Syria**== Age: 44
Member: 493205 Status: Offline Sonork: 100.1581647 Thanks Meter: 526 | reflash phone with correct cid and after that try unlock it with another flash (main+fs)but you need to (test sim card) witch work for any provider and select (1 +2+3+4+5+)choice in setting tap donn't try to unlock phone without flash coz will be corrupted gdfs file Good Luck |
02-25-2009, 11:04 | #3 (permalink) |
Member: 833567 Status: Offline Thanks Meter: 9 | w580i problem I do what you said but i have error !! see logs: v0.915026/UNI CARD SERIAL: 00036794 Loaded 51 flash descriptors ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:921600 Flash ID check:2019 Flash props sent ok OTP: LOCKED:1 CID:51 PAF:1 IMEI:35344802932862 CERT:N/A FLASH CID:52 COLOR:RED no ack during gdfs_readvar ! SCRC READ FAILURE Elapsed: 915 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED. PRELOADER SECURITY BYPASS ENABLED. ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35344802932862 CERT:N/A FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:2019 Flash props sent ok LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed GDFS startup failed (1D) loader GDFS startup failed, that is fatal Elapsed: 16 secs. |
02-25-2009, 11:42 | #4 (permalink) |
No Life Poster Join Date: Mar 2008 Location: London
Member: 722656 Status: Offline Sonork: 100.1584918 Thanks Meter: 294 | try to download main and fs for the same cid from support. select phone model, add main and fs and in settings select singed mode and complete phone after flash (only these two) now flash you phone. if it goes well then your phone should turn on and after that you can unlock your phone, be selecting signed mode and alternative security bypass in setting and click on unlock/repair. you have to have the simcard to which the phone is locked or you have to use test sim card. if it gives you the same error then it looks like your gdfs is corrupted. with setool only test point will fix this problem. |
02-25-2009, 21:08 | #7 (permalink) |
Member: 833567 Status: Offline Thanks Meter: 9 | Thanks , phone now is working again but the display is see the letter not correct and not clear some one told me that i must change the display. enyone have idea thanks |
W580i Problem need help urgently | romeoluv56 | SETool2 | 18 | 02-04-2010 17:03 |
Customer's w580i Phone dead after unlocking!! Now GDFS problem PLEASE HELP ASAP!!! | djdownfawl | SETool2 | 13 | 11-26-2009 08:49 |
k800i network stage problem please help me antenna problem make a call restart please | prakash40 | Sony Ericsson Hardware Repair | 1 | 09-24-2009 14:12 |
Brothers Help me :My problem with FuFeNu DCT4 Logger What the problem please help.... | Mohamed_Alsayed | Nokia Digital Core Technology 4 ( DCT-4 ) | 3 | 09-20-2008 01:55 |
