03-31-2010, 11:46 | #1 (permalink) |
Freak Poster Join Date: Feb 2008 Location: BD
Member: 696456 Status: Offline Thanks Meter: 86 | W580i SIMLOCKS NOT DETECTED how to solved ? UFS #48057 READY SIGNED MODE (USING SERVER) PRELOADER SECURITY BYPASS ENABLED CFG:101000000000 PROCEDURE WAS STOPPED BY USER Can't load ID loader ! Elapsed: 3 secs. CFG:000000000000 ChipID:9900,EMP protocol:0301 Speed:921600 FLASH ID: 897E OTP: LOCKED:1 CID:49 PAF:1 IMEI:35240101778635 CERT:N/A FLASH CID:51 COLOR:RED Model (from GDFS):K700 MAPP CXC article: R1GB001 prgCXC1250200_GENERIC_CY MAPP CXC version: R1GB001 Language Package: M_EAST_N_AFR CDA article: CDA102568/6 CDA version: R5A Default article: cxc1250489 Default version: R1ED001 PROVIDER: 000-00 SIMLOCKS NOT DETECTED RESTORATION FILE NOT PRESENT "R1GB001_CXC1250200_GENERIC_CY" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED Elapsed: 6 secs. Any information help plz...................... |
03-31-2010, 12:01 | #4 (permalink) | |
No Life Poster Join Date: Jun 2007 Location: Talk to *** and He Will Listen
Member: 532761 Status: Offline Sonork: 100-1592994 Thanks Meter: 1,104 | Quote:
when software you use then identify again, if rest file is present in settings tab use server enable alternative enABLE preloader tick unlock | |
The Following User Says Thank You to venuno For This Useful Post: |
03-31-2010, 12:30 | #6 (permalink) |
Member: 532761 Status: Offline Sonork: 100-1592994 Thanks Meter: 1,104 | hope it can help you! Se Tool Video Tutorials by mauro1947 |
03-31-2010, 16:29 | #7 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,772 | WHAT IS WRONG WITH THAT PHONE !??!?!?! is it still locked, or WHAT ??? if still locked, and showing no simlocks detected, do next : 1. select main + fs file, reflash phone with signed mode + customize after flash 2. power on, wait to initialize, power down, 3. go to settings, tick signed mode + use alternative bypass 4. in main tab, press recovery, use COM interface 5. now phone is brown, go to empty fill tab, load file, from setool\eroms\db2020\DB2020EROM_CNV_RED53_BROWN_CID 49_DB2020.ssw 6. press flash, after done, phone is fully factory unlocked, like it was never locked. b.r. ALex |
04-10-2010, 10:23 | #8 (permalink) |
Freak Poster Join Date: Jun 2007 Location: dhaka
Member: 537394 Status: Offline Thanks Meter: 19 | see my problem and solution DAMAGED FIRMWARE,GDFS OR EMPTY PHONE CONTINUE ON YOUR OWN RISK PHONE STATE: "RETAIL" FLASH CID: 0053 Speed:921600 FLASH ID: 897E OTP: LOCKED:1 CID:51 PAF:1 IMEI:35651402255229 CERT:RED FLASH CID:53 COLOR:RED Model (from GDFS):W580i Brand:Generic MAPP CXC article: R6BC002 prgCXC1123362_GENERIC_LA MAPP CXC version: R6BC002 Language Package: ROGERS CDA article: CDA102568/1 CDA version: R2A Default article: cxc1123364 Default version: R6BE001 PROVIDER: 000-00 SIMLOCKS NOT DETECTED RESTORATION FILE PRESENT FOR DETECTED FIRMWARE Elapsed: 8 secs. |
7510a charger not sopported how to solve? | jamels | Nokia Hardware & Hardware Repair | 1 | 11-29-2009 12:43 |
Blackberry 8800show jvm error 513 and not start, how to solve? | svchost | BlackBerry (RIM) | 6 | 11-28-2009 11:00 |
AVG detects Setool as Virus, How to solve this? and i know it isnt a virus anyway!., | dmaetrey | SETool2 | 7 | 06-25-2009 02:37 |
smartcard not found how to solved? | lorenzo roberto | UST Pro II | 1 | 01-27-2009 13:51 |
plz card reader not found how to solve | melgsm | FuriousGold | 3 | 09-05-2008 17:07 |
