Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2002 Age: 45
Member: 11288 Status: Offline Thanks: 0
| w595s dead i need help please i have a dead 595s flashing ok but cant cutomise it's recognised as w910 this is the unlock log SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") CFG:110000000000 ChipID:C900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,52,1,35750302220572] OTP LOCKED:1 CID:52 PAF:1 IMEI:35750302220572 CERT:RED LDR:2009-06-26 15:47 CXC1250843_DB31XX_CS_LOADER_ACC_SDRAM_R2A082 LDR:2009-06-26 15:48 CXC1250780_DB31XX_CS_LOADER_APP_SDRAM_R2A082 GOT SEED:89B4609E34807F7425C0D935 P96 AUTH PASSED RESTARTING... ChipID:C900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,52,1,35750302220572] OTP LOCKED:1 CID:52 PAF:1 IMEI:35750302220572 CERT:RED DEVICE KEY:69033F2B9DF8226BAF105663DFD6AEE4 (1) LDR:2009-06-26 15:54 CXC1250781_DB31XX_RESET_LOADER_ACC_SDRAM_R2A082 LDR:2009-06-26 15:54 CXC1250782_DB31XX_RESET_LOADER_APP_SDRAM_R2A082 GOT SEED:00FDDCB334807F7425C0D935 P96 AUTH PASSED RESETTING SECURITY TO FACTORY STATE... RESTARTING... ChipID:C900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,52,1,35750302220572] OTP LOCKED:1 CID:52 PAF:1 IMEI:35750302220572 CERT:BROWN LDR:2010-03-02 17:56 CXC1250777_DB31XX_PRODUCTION_LOADER_ACC_SDRAM_R2A0 96 LDR:2010-03-02 17:56 CXC1250778_DB31XX_PRODUCTION_LOADER_APP_SDRAM_R2A0 96 WRITING SEMCBOOT... PREPARING SECURITY... PHONE DOMAIN: "RED" WRITING CLEAR SIMLOCK UNITS... SIMLOCK CODES SET TO "84474370" SIGNING... DEVICE KEY RESTORED Unlock DONE Elapsed: 50 secs. i can flash phone but cant cutomise it this is the flash log SIGNED MODE (USING SERVER) CFG:100000000000 ChipID:C900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,52,1,35750302220572] OTP LOCKED:1 CID:52 PAF:1 IMEI:35750302220572 CERT:RED LDR:2010-03-02 17:53 CXC1250843_DB31XX_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH SIGNATURE AUTH LDR:2010-03-02 17:54 CXC1250780_DB31XX_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA writing "C:\Documents and Settings\Administrateur\Bureau\S-E\w595s R3EG004_APP_SW_1213_1537_GENERIC_LT_REDBROWNBLUE_C ID52_49_DB3150.software" ALLOWED DOMAINS: BLUE BROWN RED MAXIMUM CID: 52 Will flash 822 blocks... ssw file accepted writing "C:\Documents and Settings\Administrateur\Bureau\S-E\w595s R3EG004_FS_FRANCE_LT_REDBROWNBLUE_CID52_49.softwar e" ALLOWED DOMAINS: BLUE BROWN RED MAXIMUM CID: 52 Will flash 595 blocks... ssw file accepted Elapsed: 234 secs. please woh to solve this problem and woh to write gdfs to this phone thanks |
| | #4 (permalink) |
| this is the screenshoot of soft i can flash phone but soft dont customise phone event i tick use server + customise phone after flash any help please |
| | #6 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Jan 2010 Location: romania Age: 22
Member: 1202098 Status: Offline Thanks: 9
| remove all sw tick signed mode+customize phone after flash then press flash or get a cust pack from support, add it in misc edit, check signed mode, press write script. |
| | #7 (permalink) |
| this is the identify log phone is recognised as w910 RUNNING v 1.107/UNI CARD SERIAL 000xxxxx USBFLASH DRIVER VERSION 02.02.00.05 CFG:000000000000 ChipID:C900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,52,1,35750302220572] OTP LOCKED:1 CID:52 PAF:1 IMEI:35750302220572 CERT:RED LDR:2010-03-02 17:53 CXC1250843_DB31XX_CS_LOADER_ACC_SDRAM_R2A096 LDR:2010-03-02 17:54 CXC1250780_DB31XX_CS_LOADER_APP_SDRAM_R2A096 Model (from GDFS):W910i MAPP CXC article: R1EA030 prg12009123_GENERIC_SH MAPP CXC version: R1EA030 Language Package: RUSSIA CDA article: No CDA CDA version: Default article: 1200-5451 Default version: R1FA035 PROVIDER: 000-00 SIMLOCKS NOT DETECTED Elapsed: 83 secs. event i remove all sw and tick use server and customise phone soft stuk on starting file system but phone not costumised how to write gdfs to this phone , i need ta for this phone |
| | #8 (permalink) |
| Code: POSSIBLE PROBLEMS AND METHODS OF REPAIR CID 49,51,52,53 damaged trim area (ta_open errors) 1. select proper model or model,based on same chipset 2. skip that step, if phone already r&d (brown). convert phone to r&d (brown) domain, for that unlock phone in alternative security bypass mode with brown domain set. 3. if your phone based on db3150 chipset - add to firmware area Shinobu_TA.ssw if your phone based on db3200 chipset - add to firmware area elle_ta.ssw if your phone based on db3210 chipset - add to firmware area Shiho_TA.ssw if your phone based on db3350 chipset - add to firmware area aino_ta.ssw (exception should be done for latest db3350 phones: w20,j10,j20 - aino_ta.ssw will not work for them) 4. set ecc mode: none (0) 5. on settings, check only signed mode 6. press flash 7. get gdfs package from proper model working phone, add it to misc. field 8. press write gdfs 9. unlock phone using alternative security bypass mode 10. reflash phone fully. alternative way, need to use at least setool2 1.08 1. select proper model or model,based on same chipset 2. skip that step, if phone already r&d (brown). convert phone to r&d (brown) domain, for that unlock phone in alternative security bypass mode with brown domain set. 3. select in misc. edit proper gdfs package, DO NOT unzip gdfs package, just select it as is. 4. on settings, check only signed mode 5. press write gdfs 6. unlock phone using alternative security bypass mode 7. reflash phone fully. phone does not startup or stuck on "please wait" unlock phone using alternative security bypass |
| | #9 (permalink) |
| thanks for answer but this not help , phone file system can't be started soft stuck on starting file system like this screen2 but noting writed screen3 |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Need software upgrade for Nokia 5110 | ptkrf | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 26 | 09-25-2012 02:41 |
| HELP!!! BACKGROUND SCREEN LOGO | Michael Go | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 6 | 12-25-2011 23:56 |
| Help with 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 3 | 05-25-2009 16:29 |
| need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 1 | 06-02-1999 16:23 |
| need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 0 | 05-26-1999 11:35 |
