01-22-2009, 17:10 | #1 (permalink) |
Freak Poster Join Date: Jan 2006
Member: 224881 Status: Offline Thanks Meter: 9 | W610 flash problem it was R8BA024 _ 1250752_TMOBILE_NA and I have flashed with R8AB024_1250747_GENERIC_NA.ssw R8AB024_FS_EUROPA2_NA_Red_Cid52.ssw problem and the phone is dead with white screen here is the log: SIGNED MODE (USING SERVER) PRELOADER SECURITY BYPASS ENABLED. ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35272502402059 CERT:RED FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:2019 Flash props sent ok LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed DISCONNECT PHONE NOW INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM111 PHONE READY TO PROCEED EXECUTOR STARTED REMOVE CABLE FROM PHONE REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS "READY" ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 Trying to launch embedded bootloader... INT LDRB2020_PRELOADER_FOR_SETOOL2 LDRB2020 LOADER FOR SETOOL2 Flash ID check:2019 Flash props sent ok FOUND VERSION "R8BA024_CXC1250752_TMOBILE_NA" can't open file "C:\Dokumente und Einstellungen\Boya\Desktop\SETool Software\v0.915016\setool2g\setool2g\rest\R8BA024_ CXC1250752_TMOBILE_NA" writing "C:\Dokumente und Einstellungen\Boya\Desktop\SE Tool\SE Firmware\W610\CID 52\R8BA024_1250374_GENERIC_TH.ssw" CURRENT FLASH FILE CID:52 SSW uses full hash, hash len is:9200 Will flash 460 blocks... SSW loading returns:0 writing "C:\Dokumente und Einstellungen\Boya\Desktop\SE Tool\SE Firmware\W610\CID 52\R8BA024_FS_EUROPE_2_NA_RED_CID52.ssw" CURRENT FLASH FILE CID:52 SSW uses full hash, hash len is:3620 Will flash 181 blocks... SSW loading returns:0 USERCODE RESET TO "0000" Searching... Firmware SIMLOCK check determined. LDR:060426 1726 HANCXC1329133_DB2020_FILESYSTEMLOADER_P5G loader startup: executed loader GDFS startup: executed wrong response, break. loader fs startup failed, that is fatal Elapsed: 734 secs. can any one help please!!!! |
07-29-2009, 18:42 | #7 (permalink) |
Major Poster Join Date: Sep 2005 Location: MX-KEY is the BEST NOKIA TOOL. Age: 49
Member: 179612 Status: Offline Thanks Meter: 15 | SIGNED MODE (USING SERVER) CFG:10001100000000 ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35272502168770 CERT:N/A FLASH CID:53 COLOR:RED PATCH:071120 1355 HANCXC9876543210_DB2020_MEM_PATCHER_R2A012 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 Flash ID check:897E Flash props sent ok writing "C:\Documents and Settings\*****\Desktop\r6bc002_cxc1250751_na_red_c id53.software" CURRENT FLASH FILE CID:53 SSW uses full hash, hash len is: 9200 Will flash 460 blocks... SSW loading returns:0 writing "C:\Documents and Settings\*****\Desktop\r6bc002_fs_apac_na_red_cid5 3.software" CURRENT FLASH FILE CID:53 SSW uses full hash, hash len is: 4020 Will flash 201 blocks... SSW loading returns:0 LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed loader GDFS startup: executed can't get packet start. FS startup failed,error is 00 [ 0] loader fs startup failed, that is fatal Elapsed: 906 secs. |
07-29-2009, 19:09 | #8 (permalink) |
Member: 179612 Status: Offline Thanks Meter: 15 | Code: 01:04:12 D-Ultimate Unlocker v3.04 by Cruiser Team 01:04:12 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 01:04:12 Initializing... ! 01:04:12 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 01:04:12 2. Choose the phone model ! 01:04:12 3. Select the desired options ! 01:04:12 4. Please connect the phone either via USB while holding 2-5… ! 01:04:12 - or via a serial cable and double-click on it in the device list 01:05:16 Selected phone: W610 01:05:17 Connecting via Generic FTDI Cable (COM11)… 01:05:17 Device driver version: 2.2.4.0 01:05:17 Device driver date: 6-27-2007 01:05:17 Connecting to the baseband CPU... 01:05:17 Entering baseband CPU service mode... 01:05:17 Detected chipset: DB2020 01:05:17 Boot mode: ROM 01:05:18 Sending loader... 01:05:18 IMEI: 35272502168770 01:05:19 OTP CID: 51 01:05:19 Effective CID: 53 01:05:19 Restarting phone … 01:05:21 Sending loader... 01:05:22 Communicating with server… ! 01:05:34 News: DOWNLOAD THE LATEST VERSION OF D-ULTIMATE UNLOCKER 3.07. OLDER VERSIONS WILL BE DENIED ACCESS TO THE SERVER. ! 01:05:35 News: FREE A2 CID 53 unlock for 5 days! All Cruiser dongle owners with 1+ supreme credit (from 07/30 0:00 to 08/03 23:59 UTC) ! 01:05:39 News: ATTENTION: New credit consumption policy applies from July 30, see Cruiser support forum for details ! 01:05:43 News: There is a newer version of Ultimate Unlocker (v4.01). ! 01:05:44 News: Your credit consumption policy: Level 1 (Novice) 01:05:45 Remainig credit (supreme): 1.02 01:05:51 Remainig credit (supreme): 1.02 01:05:52 Restarting phone … 01:05:55 Sending loader... 01:06:00 Code NCK for relock: 1437963340977351 01:06:00 Code NSCK for relock: 3692520006349289 01:06:00 Code SPCK for relock: 9102121284695791 01:06:00 Code CCK for relock: 3885330343763031 01:06:00 Code PCK for relock: 7361983437805744 01:06:00 Code ESLCK for relock: 2482811500785265 01:06:00 Code NCK for unlock: 4589063542331239 01:06:00 Code NSCK for unlock: 7165286755019042 01:06:00 Code SPCK for unlock: 2448453427472350 01:06:00 Code CCK for unlock: 9069317897018319 01:06:00 Code PCK for unlock: 5752725415450850 01:06:00 Code ESLCK for unlock: 1472059754930662 01:06:00 To enter a code, type < * * < on the phone with SIM-card inserted 01:06:00 Writing flash… 01:06:02 Turning off the phone... 01:06:04 Done. |
E52 RM-469 Flashing problem.Flash ID not supported for this loader (RAPUv11_algo_xsr1 | rafik2533 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 04-04-2010 20:38 |
w610 bluetooth problem | alex1123 | Sony Ericsson Hardware Repair | 1 | 05-09-2009 09:28 |
W610 flashed with K610 flash | drancill | Sony Ericsson | 3 | 09-17-2008 07:49 |
sonyericsson w610 keypad problem | shree59 | Sony Ericsson Hardware Repair | 0 | 05-27-2008 18:06 |
W610 customize problem. | plentong | Cruiser Suite | 0 | 06-29-2007 14:12 |
