10-15-2008, 17:37 | #1 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Pakistan
Member: 49285 Status: Offline Thanks Meter: 51 | w700 Trying to launch embedded bootloader... v0.914040/UNI CARD SERIAL: 000000000 Loaded 51 flash descriptors Open COM port OK ChipID:8040,EMP protocol:0301 PHONE IS BLACK (00000000) NO VALID FLASH CID DETECTED (103) skipping empty loader... Can't load ID loader ! Elapsed: 36 secs. Open COM port OK ChipID:8040,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:49 Speed:921600 Flash ID check:200D Flash props sent ok OTP LOCKED:1 CID:49 PAF:1 IMEI:35167301146475 CERT:RED FLASH CID:49 COLOR:RED Model:W700i Brand:Generic Trade MAPP CXC article: R1CA021 prgCXC1250514_EU_1_CR MAPP CXC version: R1CA021 Language Package:EUROPE_1 CDA article: CDA102580/9 CDA version: R6A Default article: cxc1250522 Default version: R1CA021 PROVIDER: 000-00 SIMLOCKS NOT DETECTED USERCODE:51214 RESTORATION FILE PRESENT FOR DETECTED FIRMWARE Elapsed: 3 secs. Open COM port OK ChipID:8040,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:49 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:35167301146475 CERT:RED REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS "READY" Open COM port OK Trying to launch embedded bootloader... embedded bootloader not responds ! Elapsed: 108 secs. Open COM port OK ChipID:8040,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:49 Speed:921600 Can't load ID loader ! Elapsed: 4 secs. Open COM port OK ChipID:8040,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:49 Speed:921600 Flash ID check:200D Flash props sent ok OTP LOCKED:1 CID:49 PAF:1 IMEI:35167301146475 CERT:RED FLASH CID:49 COLOR:RED Model:W700i Brand:Generic Trade MAPP CXC article: R1CA021 prgCXC1250514_EU_1_CR MAPP CXC version: R1CA021 Language Package:EUROPE_1 CDA article: CDA102580/9 CDA version: R6A Default article: cxc1250522 Default version: R1CA021 PROVIDER: 000-00 SIMLOCKS NOT DETECTED USERCODE:51214 RESTORATION FILE PRESENT FOR DETECTED FIRMWARE Elapsed: 28 secs. Open COM port OK ChipID:8040,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:49 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:35167301146475 CERT:RED REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS "READY" Open COM port OK Trying to launch embedded bootloader... embedded bootloader not responds ! Elapsed: 119 secs. Open COM port OK ChipID:8040,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:49 Speed:921600 Can't load ID loader ! Elapsed: 4 secs. Open COM port OK ChipID:8040,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:49 Speed:921600 Can't load ID loader ! Elapsed: 4 secs. Open COM port OK ChipID:8040,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:49 Speed:921600 Flash ID check:200D Flash props sent ok OTP LOCKED:1 CID:49 PAF:1 IMEI:35167301146475 CERT:RED FLASH CID:49 COLOR:RED Model:W700i Brand:Generic Trade MAPP CXC article: R1CA021 prgCXC1250514_EU_1_CR MAPP CXC version: R1CA021 Language Package:EUROPE_1 CDA article: CDA102580/9 CDA version: R6A Default article: cxc1250522 Default version: R1CA021 PROVIDER: 000-00 SIMLOCKS NOT DETECTED USERCODE:51214 RESTORATION FILE PRESENT FOR DETECTED FIRMWARE Elapsed: 32 secs. Open COM port OK ChipID:8040,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:49 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:35167301146475 CERT:RED REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS "READY" Open COM port OK Trying to launch embedded bootloader... embedded bootloader not responds ! PROCEDURE WAS STOPPED BY USER Elapsed: 97 secs. Open COM port OK ChipID:8040,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:49 Speed:921600 Flash ID check:200D Flash props sent ok OTP LOCKED:1 CID:49 PAF:1 IMEI:35167301146475 CERT:RED FLASH CID:49 COLOR:RED Model:W700i Brand:Generic Trade MAPP CXC article: R1CA021 prgCXC1250514_EU_1_CR MAPP CXC version: R1CA021 Language Package:EUROPE_1 CDA article: CDA102580/9 CDA version: R6A Default article: cxc1250522 Default version: R1CA021 PROVIDER: 000-00 SIMLOCKS NOT DETECTED USERCODE:51214 RESTORATION FILE PRESENT FOR DETECTED FIRMWARE Elapsed: 4 secs. Open COM port OK ChipID:8040,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:49 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:35167301146475 CERT:RED REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS "READY" Open COM port OK Trying to launch embedded bootloader... embedded bootloader not responds ! PROCEDURE WAS STOPPED BY USER Elapsed: 100 secs. Open COM port OK unknown ChipID (5A00), RETRY phone pre-boot failed,possible RECOVERY needed. Elapsed: 24 secs. Open COM port OK ChipID:8040,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:49 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:35167301146475 CERT:RED REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS "READY" Open COM port OK Trying to launch embedded bootloader... embedded bootloader not responds ! Elapsed: 160 secs. RECOVERY MODE STARTED Open COM port OK err: 45 (C9) loader prologue returns invalid status Open COM port OK REC:070307 0947 NPA4_CXC1326739_DB2010_SEMC_RECOVERY_P2A Fetching phone data from OTP OTP LOCKED:1 CID:49 PAF:1 IMEI:35167301146475 CERT:RED THAT WILL KILL YOUR PHONE, ABORTED Elapsed: 3 secs. RECOVERY MODE STARTED Open COM port OK err: 45 (C9) loader prologue returns invalid status Open COM port OK REC:070307 0947 NPA4_CXC1326739_DB2010_SEMC_RECOVERY_P2A Fetching phone data from OTP OTP LOCKED:1 CID:49 PAF:1 IMEI:35167301146475 CERT:RED THAT WILL KILL YOUR PHONE, ABORTED Elapsed: 3 secs. Open COM port OK ChipID:8040,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:49 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:35167301146475 CERT:RED REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS "READY" Open COM port OK Trying to launch embedded bootloader... embedded bootloader not responds ! Elapsed: 68 secs. |
V8 bootloader screen-tried to flash -an error-help | zonetrichur | Scout | 9 | 01-22-2010 16:11 |
Trying to launch embedded bootloader.... | san9090 | SETool2 | 3 | 03-10-2009 04:22 |
K510i flashing stop at .......Trying to launch embedded bootloader... | kamransohail786 | SETool2 | 10 | 08-17-2008 15:29 |
help for w700 ((((Trying to launch embedded bootloader...))))) | mamalhacker | SETool2 | 2 | 07-04-2008 16:51 |
W850i embedded bootloader | atiisgr8 | SETool2 | 3 | 10-09-2007 14:08 |
