08-16-2010, 13:38 | #1 (permalink) |
Freak Poster Join Date: Oct 2007
Member: 617865 Status: Offline Thanks Meter: 111 | w810 cannot customize ,why? can't get packet start. GDFS startup failed,error is 00 [00] loader GDFS startup failed, that is fatal adn the whole loge is as below: RUNNING v 1.085/UNI CARD SERIAL 00087845 USBFLASH DRIVER VERSION 02.02.00.05 SIGNED MODE (USING SERVER) CFG:101000000000 ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:35906100000856 CERT:RED PATCH:061204 1529 HAN_DB2010_MEM_PATCHER_R2A007_CXC9876543210 0 LDR:060718 0842 LIE_DB2010_FLASHLOADER_R2A003_CXC1326738 FLASH ID: 2019 LDR:070524 1030 AN2CXC1327364_COMPACT_SEMC_CS_LOADER__R3A010 can't get packet start. GDFS startup failed,error is 00 [00] loader GDFS startup failed, that is fatal Elapsed: 203 secs. now what to do ? |
08-16-2010, 13:57 | #3 (permalink) |
Member: 617865 Status: Offline Thanks Meter: 111 | i do as you say,the log is : RUNNING v 1.085/UNI CARD SERIAL 00087845 USBFLASH DRIVER VERSION 02.02.00.05 SIGNED MODE (USING SERVER) CFG:100000000000 RESET MODE STARTED ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 RESET:070703 1100 NPACXC125870_DB2010_CERTRESETLOADER_P5F FLASH ID: 2019 GOT SEED:C5EAB1032180957A05803500 P96 AUTH PASSED OTP LOCKED:1 CID:49 PAF:1 IMEI:35906100000856 CERT:RED PHONE SUCCESSFULLY RESET TO DEVELOPER STATE Elapsed: 13 secs. CFG:000000000000 ChipID:8040,EMP protocol:0301 PHONE STATE: "DEVELOPER" FLASH CID: 0051 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:35906100000856 CERT:BROWN LDRB2010_RESPIN_PRODLOADER_SETOOL2 FLASH ID: 2019 writing "C:\Documents and Settings\sun\Desktop\New Folder\v1.085\gdfs_in_ssw_format\db2010\w810_gdfs_ in_ssw_format.ssw" CURRENT FLASH FILE CID:UNIVERSAL SSW uses dynamic hash, dynamic hash len is: 32 Will flash 32 blocks... Setting up GDFS... OTP WRITE NOT EXECUTED WRITING CLEAR SIMLOCK UNITS... SIMLOCK CODES SET TO "64840053" SIGNING... Elapsed: 43 secs. CFG:000000000000 ChipID:8040,EMP protocol:0301 PHONE STATE: "DEVELOPER" FLASH CID: 0051 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:35906100000856 CERT:BROWN LDRB2010_RESPIN_PRODLOADER_SETOOL2 FLASH ID: 2019 writing "C:\Documents and Settings\sun\Desktop\New Folder\v1.085\eroms\db2010\db2012_erom_cid51.ssw" CURRENT FLASH FILE CID:36 Converting firmware... SSW uses dynamic hash, dynamic hash len is: 2 Will flash 2 blocks... Setting up GDFS... can't get packet start. packet not acknowledged (17) setGDFS_params failed failed to setup GDFS FINALIZATION FAILED. Elapsed: 72 secs. now mobile is dead. |
08-16-2010, 17:48 | #5 (permalink) |
No Life Poster Join Date: Jun 2010 Age: 14
Member: 1315677 Status: Offline Thanks Meter: 1,437 | That is a wrong way HOW TO WORK WITH A1-BASED PHONES CID 49 1. select proper model 2. on settings, check "unlock during flash process" 3. add to firmware area proper gdfs in ssw format 4. if desired, add to firmware area proper main,fsimage 5. press flash Video http://files.setool.net/video/index....air%20GDFS.rar |
The Following User Says Thank You to :Aishur: For This Useful Post: |
08-16-2010, 17:50 | #6 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: Chandigarh,India Age: 40
Member: 220603 Status: Offline Thanks Meter: 1,164 | Quote:
08-17-2010, 12:06 | #9 (permalink) | |
Freak Poster Join Date: Apr 2008 Location: Dublin
Member: 746630 Status: Offline Thanks Meter: 23 | Quote:
08-17-2010, 15:39 | #11 (permalink) |
Member: 746630 Status: Offline Thanks Meter: 23 | now stuck on sony ericsson screen, any body please help, how to return the phone in original state?: I try to flash ,and change IMEI to GDFS IMEI nothing seem to work( I had imei mismatch gdfs imei was different so I change it) im not sure if I've done right thing?here is the log: RUNNING v 1.081/UNI CARD SERIAL 000**** USBFLASH DRIVER VERSION 02.02.00.05 POSSIBLE GDFS FILE DETECTED, EXTRACTING PHONEBOOK PHONEBOOK NOT DETECTED IN GDFS FILE CFG:000100000000 ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:35233601912100 CERT:RED PATCH:061204 1529 HAN_DB2010_MEM_PATCHER_R2A007_CXC9876543210 0 LDR:060718 0842 LIE_DB2010_FLASHLOADER_R2A003_CXC1326738 FLASH ID: 897E REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS "READY" STARTING BOOTLOADER... INT LDRB2010_RESPIN_ID_LOADER_SETOOL2 LDRB2010_RESPIN_PRODLOADER_SETOOL2 FLASH ID: 897E FOUND VERSION "R4DB005_CXC1250320_VODAFONE_HN" writing "C:\Documents and Settings\Administrator\Desktop\R4DB005_1250320_VOD AFONE_HN.ssw\R4DB005_1250320_VODAFONE_HN.ssw.cry" CURRENT FLASH FILE CID:49 SSW uses dynamic hash, dynamic hash len is: 340 Will flash 340 blocks... writing "C:\Documents and Settings\Administrator\Desktop\r4db005_eu1_fs.ssw\ r4db005_eu1_fs.ssw.cry" CURRENT FLASH FILE CID:49 SSW uses dynamic hash, dynamic hash len is: 157 Will flash 157 blocks... Setting up GDFS... IMEI MISMATCH ! ORIGINAL IMEI:35233601912*** CURRENT IMEI:04857555048*** "USB" INTERFACE DETECTED AND IMEI IS MISMATCHED PLEASE SELECT "COM/UFS" AS INTERFACE WRITING CLEAR SIMLOCK UNITS... SIGNING... LDR:COMPACT_SEMC_FS_LOADER_SETOOL2_V26 loader GDFS startup executed loader FILESYSTEM startup executed Processing script "C:\Documents and Settings\Administrator\Desktop\BOX\SeTool\v1.081\g dfs_in_bin_format\db2010\W810_GDFS.bin"... Elapsed: 480 secs. CFG:000100000000 ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:35233601912100 CERT:RED PATCH:061204 1529 HAN_DB2010_MEM_PATCHER_R2A007_CXC9876543210 0 LDR:060718 0842 LIE_DB2010_FLASHLOADER_R2A003_CXC1326738 FLASH ID: 897E REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS "READY" STARTING BOOTLOADER... INT LDRB2010_RESPIN_ID_LOADER_SETOOL2 LDRB2010_RESPIN_PRODLOADER_SETOOL2 FLASH ID: 897E FOUND VERSION "R4DB005_CXC1250320_VODAFONE_HN" writing "C:\Documents and Settings\Administrator\Desktop\R4DB005_1250320_VOD AFONE_HN.ssw\R4DB005_1250320_VODAFONE_HN.ssw.cry" CURRENT FLASH FILE CID:49 SSW uses dynamic hash, dynamic hash len is: 340 Will flash 340 blocks... writing "C:\Documents and Settings\Administrator\Desktop\r4db005_eu1_fs.ssw\ r4db005_eu1_fs.ssw.cry" CURRENT FLASH FILE CID:49 SSW uses dynamic hash, dynamic hash len is: 157 Will flash 157 blocks... Setting up GDFS... IMEI MISMATCH ! ORIGINAL IMEI:35233601912*** CURRENT IMEI:04857555048*** "USB" INTERFACE DETECTED AND IMEI IS MISMATCHED PLEASE SELECT "COM/UFS" AS INTERFACE WRITING CLEAR SIMLOCK UNITS... SIGNING... LDR:COMPACT_SEMC_FS_LOADER_SETOOL2_V26 loader GDFS startup executed loader FILESYSTEM startup executed Processing script "C:\Documents and Settings\Administrator\Desktop\BOX\SeTool\v1.081\g dfs_in_ssw_format\db2010\w810_gdfs_in_ssw_format.s sw"... Elapsed: 492 secs. |
08-17-2010, 16:00 | #12 (permalink) | |
Member: 1315677 Status: Offline Thanks Meter: 1,437 | Quote:
To repair the imei (YOU MUST HAVE THE REST FILE OR CREAT IT) tick ALLOW IMEI CHANGE WHILE UNLOCKING UNLOCK/REPAIR SAY OK AT THE POPUP TO SELECT OTP IMEI(ORIGINAL) OR PERFORM ALL AT ONCE | |
5190 patial flashes - why are they so hard to find? | Bads | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 7 | 04-14-2001 03:18 |
why so much battle with black listed phones? | Zianna | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-06-2001 16:10 |
Why do not tel we the solution for 8210 ?????? | PADERF | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-18-2000 00:15 |
3210 i cannot unlock | pizza man | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 08-12-2000 16:02 |
Silly question!! Why is it impossible to read out the mastercode of Nokia phones???? | MyKe | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 09-26-1999 14:31 |
