03-26-2011, 14:54 | #1 (permalink) |
Banned Join Date: May 2008
Member: 783336 Status: Offline Thanks Meter: 21 | w810 cid 50 flash../?? NEW SECURITY (RESPIN) PHONE ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0050 Speed:115200 FLASH ID: 2019 OTP: LOCKED:1 CID:50 PAF:1 IMEI:35657301897325 CERT:RED FLASH CID:50 COLOR:RED setGDFS_params failed failed to setup GDFS Elapsed: 7 secs. CFG:000000000000 how to solve this problem |
03-26-2011, 15:11 | #2 (permalink) |
No Life Poster Join Date: Feb 2008
Member: 696136 Status: Offline Thanks Meter: 210 | Do reset procedure with "comport" or "ufs" interface. that is so-called reset procedure. 1. go to emptyboard tab 2. select proper model 3. on settings, check "signed mode" 4. press recovery 5. after succeful recovery 6. on settings uncheck all 7. if gdfs totally damaged, add to firmware area proper gdfs in ssw format,otherwise skip that step 8. add to firmware area proper EROM (EROM CID >= OTP CID) 9. press flash 10. if needed,reflash phone on usual semc tab with needed settings. B.R |
03-26-2011, 15:19 | #3 (permalink) |
Member: 783336 Status: Offline Thanks Meter: 21 | i try this method but show me this error.. PHONE STATE: "RETAIL" FLASH CID: 0050 PLEASE CONNECT PHONE IN "BOOTROM" MODE Elapsed: 11 secs. CFG:000000000000 NEW SECURITY (RESPIN) PHONE ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0050 Speed:115200 OTP: LOCKED:1 CID:50 PAF:1 IMEI:35657301897325 CERT:RED LDR:060712 1520 HAN_DB2012_FLASHLOADER_R1A002_CXC1250695 FLASH ID: 2019 PHONE CID NOT SUPPORTED IN THAT MODE Elapsed: 5 secs. |
03-26-2011, 15:55 | #7 (permalink) |
Member: 783336 Status: Offline Thanks Meter: 21 | phone is dead... here is 1st log identifiy CFG:100000000000 NEW SECURITY (RESPIN) PHONE ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0050 Speed:115200 FLASH ID: 2019 OTP: LOCKED:1 CID:50 PAF:1 IMEI:35657301897325 CERT:RED FLASH CID:50 COLOR:RED setGDFS_params failed failed to setup GDFS Elapsed: 7 secs. CFG:000000000000 |
03-26-2011, 15:57 | #8 (permalink) |
Member: 783336 Status: Offline Thanks Meter: 21 | RUNNING v 1.01/UNI CARD SERIAL 00016544 USBFLASH DRIVER VERSION 02.02.00.05 Found 1 FTDI device(s). UFS #16792 READY CFG:000000000000 NEW SECURITY (RESPIN) PHONE ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0050 Speed:115200 OTP: LOCKED:1 CID:50 PAF:1 IMEI:35657301897325 CERT:RED PHONE CID NOT SUPPORTED IN THAT MODE Elapsed: 8 secs. SIGNED MODE (USING SERVER) CFG:100000000000 RESET MODE STARTED NEW SECURITY (RESPIN) PHONE ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0050 Speed:115200 RESET:070703 1100 NPACXC125870_DB2010_CERTRESETLOADER_P5F FLASH ID: 2019 GOT SEED:AB1CAB702280DD7015D012DB P96 AUTH PASSED OTP: LOCKED:1 CID:50 PAF:1 IMEI:35657301897325 CERT:RED PHONE SUCCESSFULLY RESET TO DEVELOPER STATE Elapsed: 76 secs. SIGNED MODE (USING SERVER) CFG:100000000000 NEW SECURITY (RESPIN) PHONE ChipID:8040,EMP protocol:0301 PHONE STATE: "DEVELOPER" FLASH CID: 0051 skipping empty loader... FAILED TO SETUP PHONE Elapsed: 9 secs. SIGNED MODE (USING SERVER) CFG:100000000000 PROCEDURE WAS STOPPED BY USER FAILED TO SETUP PHONE Elapsed: 4 secs. CFG:000000000000 NEW SECURITY (RESPIN) PHONE ChipID:8040,EMP protocol:0301 PHONE STATE: "DEVELOPER" FLASH CID: 0051 Speed:115200 OTP: LOCKED:1 CID:50 PAF:1 IMEI:35657301897325 CERT:BROWN LDRB2010_RESPIN_PRODLOADER_SETOOL2 FLASH ID: 2019 writing "L:\Program Files\Setool V1.01\gdfs_in_ssw_format\db2010\w810_gdfs_in_ssw_f ormat.ssw" CURRENT FLASH FILE CID:254 SSW uses dynamic hash, dynamic hash len is: 32 Will flash 32 blocks... writing "L:\Documents and Settings\monu\My Documents\Downloads\W810_R4EA031_MAIN_GENERIC_HN_R ED50\db2012_erom_cid50.ssw" CURRENT FLASH FILE CID:36 Converting firmware... SSW uses dynamic hash, dynamic hash len is: 2 Will flash 2 blocks... Setting up GDFS... OTP WRITE NOT EXECUTED WRITING CLEAR SIMLOCK UNITS... ALL UNLOCK/LOCK CODES SET TO "53405707" SIGNING... Elapsed: 260 secs. |
need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-16-2019 19:37 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
Nokia Flash Content. | Phantom | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-01-2000 23:28 |
