04-03-2010, 20:41 | #1 (permalink) |
No Life Poster Join Date: Jan 2008 Location: pakistan
Member: 683063 Status: Offline Sonork: 100.1617868 Thanks Meter: 136 | w810 insert correct sim card SIGNED MODE (USING SERVER) CFG:100000000000 ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:115200 FLASH ID:897E OTP: LOCKED:1 CID:49 PAF:1 IMEI:359061.......... CERT:RED FLASH CID:49 COLOR:RED Model (from GDFS):W810i MAPP CXC article: R4EA031 prgCXC1250316_GENERIC_HN MAPP CXC version: R4EA031 Language Package: C_ASIA CDA article: CDA102555/10 CDA version: R7A Default article: cxc1250324 Default version: R4ED001 PROVIDER: 000-00 SIMLOCKS NOT DETECTED USERCODE:0000 RESTORATION FILE PRESENT FOR DETECTED FIRMWARE Elapsed: 9 secs. |
04-05-2010, 02:09 | #7 (permalink) |
No Life Poster Join Date: Sep 2008 Location: Philippines
Member: 853601 Status: Offline Thanks Meter: 251 | try to use USB cable, uncheck all, then check unlock/repair tab, then follow instructions on the screen appeared, sometimes if executor does not exist, you should flashed another firmware.... If it is a 5 locks phone,click on empty tab, like we do in repair gdfs, wrtie erom... used version 1 or v1.01, it's free |
04-05-2010, 02:26 | #8 (permalink) |
No Life Poster Join Date: Nov 2007 Location: inside nck
Member: 628112 Status: Offline Sonork: 100.1589052 Thanks Meter: 3,726 | uncheck all in tab setting,click unlock repair,if u have 5 locks closed then only repair gdfs can solve,its free just do recovery,write good gdfs and erom no need flashing after ur phone will be unlocked bRo toutou_gsm |
04-05-2010, 10:03 | #9 (permalink) |
Crazy Poster Join Date: Mar 2010
Member: 1271366 Status: Offline Thanks Meter: 6 | bro try to use usb cable n check ur setool setting click on signe mode , enable alternative security bypass , enable preloder bypass and customize phone after flash click on identify option. if ur bypass n restoration file present .than try to unlock ur phone n follow instruction on ur screen. best of luck bro |
04-05-2010, 10:04 | #10 (permalink) | |
No Life Poster Join Date: Sep 2007 Location: algeria
Member: 591880 Status: Offline Thanks Meter: 561 | Quote:
but for db2012 cid50 (w810) it can be 5 lock closed and here we need reset operation correct me if im wrong | |
1000% working solution for w810 insert correct sim | dreameye | Sony Ericsson | 5 | 05-20-2009 05:25 |
W810 insert correct sim after full flash ! | ehsan_lzl | DreamBox | 7 | 03-04-2009 16:07 |
k320 insert correct sim card with test card | fofolpo | SETool2 | 6 | 01-28-2009 14:47 |
Z310a, whwn I put test sim card it shows insert correct sim card. | manistar | SETool2 | 6 | 01-21-2009 20:11 |
w810 after flashing insert correct sim card | ikram tabassum1 | SETool2 | 4 | 10-24-2008 16:57 |
