01-02-2010, 04:47 | #1 (permalink) |
Cheater -Don't Deal with him- Join Date: Dec 2007
Member: 643212 Status: Offline Thanks Meter: 19 | w810i 5 locks after flashing done by SEtool The Phone is Dead. So I decided to flash the phone, but after flashing the phone is 5 locks. Eto ung picture ng 5locks: [img=http://img406.imageshack.us/img406/5271/w8105locks.th.jpg] Procedure: 1. Flash the phone (Main and Fs) 2. Write the "seczone" from the backup folder created by the SEtool. Here's the logs: [HTML]OTP: LOCKED:1 CID:49 PAF:1 IMEI:35906100070930 CERT:RED w810 program v0.914038/UNI CARD SERIAL: 00059248 Loaded 51 flash de******ors Open COM port OK Can't load ID loader ! PROCEDURE WAS STOPPED BY USER Elapsed: 15 secs. Open COM port OK ChipID:8040,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:49 Speed:921600 Flash ID check:2019 Flash props sent ok OTP LOCKED:1 CID:49 PAF:1 IMEI:35906100070930 CERT:RED FLASH CID:49 COLOR:RED IMEI MISMATCH ! GDFS IMEI:35906100020285 Model:W810i Brand:Generic MAPP CXC article: R4CE012 prgCXC1250317_CHINA_HN MAPP CXC version: R4CE012 Language Package:S_ASIA_LEVAN CDA article: CDA102555/110 CDA version: R2A Default article: cxc1250324 Default version: R4CE012 PROVIDER: 000-00 SIMLOCKS NOT DETECTED USERCODE:0000 RESTORATION FILE PRESENT FOR DETECTED FIRMWARE Elapsed: 3 secs. Processing ****** "D:\SETOOL\v0.915043\backup\35906100070930\3590610 0070930_12_27_2009_4_21_46_PM.fixup"... Open COM port OK ChipID:8040,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:49 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:35906100070930 CERT:RED PATCH:061204 1529 HAN_DB2010_MEM_PATCHER_R2A007_CXC9876543210 0 LDR:060718 0842 LIE_DB2010_FLASHLOADER_R2A003_CXC1326738 REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS "READY" Open COM port OK Trying to launch embedded bootloader... INT LDRB2010_RESPIN_ID_LOADER_SETOOL2 Flash ID check:2019 Flash props sent ok FOUND: R4CE012_CXC1250317_CHINA_HN Restore from:R4CE012_CXC1250317_CHINA_HN LDR:COMPACT_SEMC_FS_LOADER_SETOOL2_V26 loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed Writing GDFS var 0000:001C len:0001 Success Phone detached Elapsed: 60 secs. Open COM port OK ChipID:8040,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:49 Speed:921600 Flash ID check:2019 Flash props sent ok OTP LOCKED:1 CID:49 PAF:1 IMEI:35906100070930 CERT:RED FLASH CID:49 COLOR:RED IMEI MISMATCH ! GDFS IMEI:35906100020285 Model:W810i Brand:Generic MAPP CXC article: R4CE012 prgCXC1250317_CHINA_HN MAPP CXC version: R4CE012 Language Package:S_ASIA_LEVAN CDA article: CDA102555/110 CDA version: R2A Default article: cxc1250324 Default version: R4CE012 PROVIDER: 000-00 SIMLOCKS NOT DETECTED USERCODE:0000 RESTORATION FILE PRESENT FOR DETECTED FIRMWARE Elapsed: 3 secs. Processing ****** "D:\SETOOL\v0.915043\backup\35906100070930\3590610 0070930_12_27_2009_4_21_46_PM.seczone"... Open COM port OK ChipID:8040,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:49 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:35906100070930 CERT:RED PATCH:061204 1529 HAN_DB2010_MEM_PATCHER_R2A007_CXC9876543210 0 LDR:060718 0842 LIE_DB2010_FLASHLOADER_R2A003_CXC1326738 REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS "READY" Open COM port OK Trying to launch embedded bootloader... INT LDRB2010_RESPIN_ID_LOADER_SETOOL2 Flash ID check:2019 Flash props sent ok FOUND: R4CE012_CXC1250317_CHINA_HN Restore from:R4CE012_CXC1250317_CHINA_HN LDR:COMPACT_SEMC_FS_LOADER_SETOOL2_V26 loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed Writing GDFS var 0000:0013 len:0124 Success Writing GDFS var 0000:0006 len:01AA Success Writing GDFS var 0000:000E len:006A Success Writing GDFS var 0000:001C len:0001 Success Writing GDFS var 0000:0018 len:0001 Success Writing GDFS var 0000:00AA len:000A Success Phone detached Elapsed: 55 secs. Open COM port OK ChipID:8040,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:49 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:35906100070930 CERT:RED PATCH:061204 1529 HAN_DB2010_MEM_PATCHER_R2A007_CXC9876543210 0 LDR:060718 0842 LIE_DB2010_FLASHLOADER_R2A003_CXC1326738 REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS "READY" Open COM port OK Trying to launch embedded bootloader... INT LDRB2010_RESPIN_ID_LOADER_SETOOL2 Flash ID check:2019 Flash props sent ok FOUND: R4CE012_CXC1250317_CHINA_HN Restore from:R4CE012_CXC1250317_CHINA_HN Elapsed: 34 secs. [/HTML] Here's the Finished product: [img=http://img188.imageshack.us/img188/7863/w8105locksdone.th.jpg] |
The Following User Says Thank You to rhedhead_21 For This Useful Post: |
01-13-2010, 21:34 | #7 (permalink) |
Junior Member Join Date: May 2007 Location: mexico
Member: 517524 Status: Offline Thanks Meter: 1 | PHONE STATE: "RETAIL" FLASH CID: 0050 Speed:460800 OTP: LOCKED:1 CID:50 PAF:1 IMEI:35657301483100 CERT:RED LDR:060712 1520 HAN_DB2012_FLASHLOADER_R1A002_CXC1250695 Flash ID check:897E Flash props sent ok LDR:070410 1405 HANCXC1327364_COMPACT_SEMC_CS_LOADER_1_R3B009 loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed Writing GDFS var 0000/0013/0124 Writing GDFS var 0000/0006/01AA Writing GDFS var 0000/000E/006A Writing GDFS var 0000/001C/001C Writing GDFS var 0000/0018/0001 Writing GDFS var 0000/00AA/000A Phone detached Elapsed: 49 secs. is ok unlock with 5 locks |
k320 5 lock close done by setool {T.P} | khurram86 | SETool2 | 5 | 02-12-2009 15:10 |
Z610 change flash ic from k610 phone and repair gdfs done by setools | ayhen42 | SETool2 | 5 | 11-24-2008 11:24 |
another w880 5 locks closed successfully repaired by setool | ASHIF | SETool2 | 11 | 09-29-2008 02:06 |
K610 change flash ic and repair gdfs done by SETOOLS | ayhen42 | SETool2 | 0 | 07-30-2008 02:58 |
the phone is locked after flashing it by hwk | adam92se | HWK | 3 | 11-03-2005 00:03 |
