W810i Configuration error after unlock done
W810i after unlocked
Configuration error.Please contact your network operator or service centre
status : locked by cingular
tools : fusion box & cable k750
procedure :1st, unlock using this method -> go setting check 123 then goto sony ericson, set exact model and hit unlock/repair
(usb CABLE gamit ko dito)
5/22/2014 10:34:03 AM Elapsed: 38 secs.
5/22/2014 10:34:15 AM SIGNED MODE (USING SERVER)
5/22/2014 10:34:15 AM CFG:100000000000
5/22/2014 10:34:20 AM ChipID: 8040, EMP protocol: 0301
5/22/2014 10:34:20 AM PHONE DOMAIN: "RETAIL"
5/22/2014 10:34:20 AM PHONE CID: 0049
5/22/2014 10:34:20 AM SPEED: 921600
5/22/2014 10:34:21 AM LDR: 061113 1250 ALUCXC125872_COMPACTPRODUCTION_ID_LOADER P3L
5/22/2014 10:34:21 AM OTP: LOCKED:1 CID:49 PAF:1 IMEI:35235001072446 CERT:RED
5/22/2014 10:34:21 AM CURRENT CID: 49 COLOR: RED
5/22/2014 10:34:21 AM LDR: 061204 1529 HAN_DB2010_MEM_PATCHER_R2A007_CXC9876543210 0
5/22/2014 10:34:22 AM LDR: 060718 0842 LIE_DB2010_FLASHLOADER_R2A003_CXC1326738
5/22/2014 10:34:22 AM FLASH ID: 897E
5/22/2014 10:34:25 AM LDR: 070524 1030 AN2CXC1327364_COMPACT_SEMC_CS_LOADER__R3A010
5/22/2014 10:34:25 AM Executing CSCA-based unlock.
5/22/2014 10:34:25 AM Backup security data ...
5/22/2014 10:35:01 AM GDFS startup executed
5/22/2014 10:35:01 AM Erasing locks ...
5/22/2014 10:35:01 AM DISCONNECT PHONE NOW
5/22/2014 10:35:01 AM REMOVE SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN
5/22/2014 10:35:01 AM INSTALL PHONE MODEM DRIVERS IF NEEDED
5/22/2014 10:35:01 AM SEARCHING FOR PHONE, "STOP" TO ABORT
5/22/2014 10:35:20 AM PHONE FOUND AT COM49
5/22/2014 10:35:28 AM PHONE READY TO PROCEED.
5/22/2014 10:35:36 AM GOT SEED: 00119293
5/22/2014 10:35:37 AM ACTIVATION COMPLETED. USERCODE RESET TO "0000"
5/22/2014 10:35:37 AM Unlock DONE
5/22/2014 10:35:37 AM Elapsed: 82 secs.
problem after this method power on the phone pump up this error on the screen.
Configuration error.Please contact your network operator or service centre |
2nd, download the file on the support and flash the phone. after the flash goto this method.
goto Setting check signed mode
back to Sonyericson set exact model hit (RECOVERY) wait after done
goto Setting uncheck signed mode
goto EmtyFill & Repair
add gdfs.ssw same cid and (FLASH) wait after done
add eroms.ssw same cid and (FLASH ) WAIT AFTER DONE
RECOVERY
CFG:100000000000
RESET MODE STARTED
PHONE DOMAIN: "DEVELOPER"
PHONE CID: 0049
SPEED: 921600
RESET: 070703 1100 NPACXC125870_DB2010_CERTRESETLOADER_P5F
FLASH ID: 897E
GOT SEED: B18F5C9821805E6015E0AF11
P96 AUTH PASSED
OTP: LOCKED:1 CID:49 PAF:1 IMEI:35235001072446 CERT:BROWN
PHONE SUCCESSFULLY RESET TO DEVELOPER STATE
Elapsed: 9 secs.
CFG:000000000000
PHONE CID: 0051
FLASH GDFS
CFG:000000000000
PHONE CID: 0051
SPEED: 921600
LDR: DB2010_RESPIN_PRODLOADER_SETOOL2
FLASH ID: 897E
writing "D:\SETOOL\gdfs_in_ssw_format\db2010\w810_gdfs_in_ ssw_format.ssw"
CURRENT FLASH FILE CID: UNIVERSAL
SSW uses dynamic hash, dynamic hash len is: 32
Will flash 32 blocks ...
Setting up GDFS ...
OTP WRITE SKIPPED
WRITING CLEAR SIMLOCK UNITS ...
SIMLOCK CODES SET TO "66833372"
SIGNING ...
Elapsed: 42 secs.
FLASH EROMS
PHONE CID: 0051
SPEED: 921600
FLASH ID: 897E
writing "D:\SETOOL\eroms\db2010\w810_erom_red49.ssw"
SSW uses dynamic hash, dynamic hash len is: 4
Will flash 4 blocks ...
Setting up GDFS ...
OTP WRITE SKIPPED
SIMLOCK CODES SET TO "07804235"
SIGNING ...
Elapsed: 12 secs. |
AFTER THAT GOTO SETTING CHECK 123
goto Sonyericson set model again (no/erase load flashfile) and FLASH
ALTERNATIVE SECURITY BYPASS ENABLED
CFG:111000000000
PHONE CID: 0049
SPEED: 921600
FLASH ID: 897E
Downgrading security ...
PHONE CID: 0049
SPEED: 921600
GOT SEED: 32114A2821805E6015E0AF11
P96 AUTH PASSED
Restarting ...
PHONE CID: 0051
SPEED: 921600
CURRENT CID: 51 COLOR: BROWN
LDR: COMPACT_SEMC_FS_LOADER_SETOOL2_V26
FILESYSTEM startup executed
using GENERIC phone customization
tpa/preset/custom/C3_PCA_G3v2.cer
tpa/preset/custom/CONTENT_DOWNLOAD_HOOK_2.itm
tpa/preset/custom/customize.xml
tpa/preset/custom/DESKTOP_HOOK_2.itm
tpa/preset/custom/Entrust.net Root Certificate.cer
tpa/preset/custom/Entrust.net_WTLS_Root_Certificate.wcrt
tpa/preset/custom/FM_PICTURES_HOOK_3.itm
tpa/preset/custom/FM_SOUNDS_HOOK_3.itm
tpa/preset/custom/FM_THEMES_HOOK_3.itm
tpa/preset/custom/FM_VIDEOS_HOOK_3.itm
tpa/preset/custom/GAMES_HOOK_3.itm
tpa/preset/custom/GTE_CyberTrust_Root.cer
tpa/preset/custom/GTE_Cybe_Trust_Root_WTLS.wcrt
tpa/preset/custom/Root.cer
tpa/preset/custom/SEMC_E2E_Root_CA.crt
tpa/preset/custom/SETT_RINGTONE_HOOK_3.itm
tpa/preset/custom/ThawtePremium.der
tpa/preset/custom/ThawteServerCA.cer
tpa/preset/custom/Utiroot.cer
tpa/preset/custom/VeriSignClass3Root.cer
tpa/preset/custom/Verisign_Class_3_CA_WTLS.wcrt
Phone detached
Elapsed: 135 secs.
