10-21-2008, 09:08 | #1 (permalink) |
No Life Poster Join Date: Jul 2008
Member: 818352 Status: Offline Thanks Meter: 266 | W810i Flashing error FLASH CID detected:49 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:35233701428069 CERT:RED PATCH:061204 1529 HAN_DB2010_MEM_PATCHER_R2A007_CXC9876543210 0 LDR:060718 0842 LIE_DB2010_FLASHLOADER_R2A003_CXC1326738 REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS "READY" Open COM port OK Trying to launch embedded bootloader... INT LDRB2010_RESPIN_ID_LOADER_SETOOL2 Flash ID check:897E Flash props sent ok FOUND: R4CE012_CXC1250320_VODAFONE_HN Restore from:R4CE012_CXC1250320_VODAFONE_HN writing C:\Documents and Settings\azeem\Desktop\R4CE012_1250320_VODAFONE_HN .ssw.cry CURRENT FLASH FILE CID:49 SSW uses dynamic hash, dynamic hash len is:339 Will flash 339 blocks... SSW loading returns:0 writing C:\Documents and Settings\azeem\Desktop\r4ce012_america2_fs.ssw.cry CURRENT FLASH FILE CID:49 SSW uses dynamic hash, dynamic hash len is:157 Will flash 157 blocks... incorrect address [45C10000/00010000] Elapsed: 504 secs. Any Mate Help will be Appreciated i am get incorrect Adress error Regards,Trigger |
10-21-2008, 09:33 | #2 (permalink) |
No Life Poster Join Date: Jul 2007 Location: Dubai, UAE Age: 38
Member: 547967 Status: Offline Thanks Meter: 653 | Hello u should also described the condition of the Unit but 1. try on lower speed 2. Check the flash file version+cid match with Unit 3. Flash Problem Thanxs |
10-21-2008, 10:55 | #6 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Quote:
Change flash file if not ok than change flash ic or rehot ic & than flash again.........! | |
06-15-2011, 10:04 | #8 (permalink) | |
No Life Poster Join Date: Jun 2011 Age: 13
Member: 1597873 Status: Offline Thanks Meter: 169 | Quote:
if error still acoured try to upgrade cid of ur phone then flash with the same CID firmware. PS: software first before proceed to HW. wbr, setool_helper | |
w810i flash error | care | Sony Ericsson Hardware Repair | 2 | 07-07-2007 10:05 |
w810i flashing error for four days ,hehehehehe | mccm | Cruiser Suite | 9 | 04-08-2007 00:49 |
w810i flashing error | sundar83 | Cruiser Suite | 3 | 03-27-2007 10:07 |
w810i flashing error and opt/gdfs imei not same | solution4mobile | Universalbox | 1 | 02-25-2007 15:00 |
W810i flash error 302401, pls help!! | Abbasin1 | SonyEricsson (USB-Smart) | 1 | 05-31-2006 08:36 |
