11-03-2010, 01:24 | #1 (permalink) |
Freak Poster Join Date: Sep 2010
Member: 1406087 Status: Offline Thanks Meter: 26 | W810i help needed PLEASE!!! It was working fine until I connected it to my SETool box, then it refused to start. Here is a log of what appears when I click on "IDENTIFY"... v0.915057/UNI CARD SERIAL: 00005xxx Loaded 51 flash descriptors CFG:000000000000 ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 FLASH ID:2019 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35657401335288 CERT:RED FLASH CID:49 COLOR:RED IMEI MISMATCH ! GDFS IMEI:35906100020285 Model (from GDFS):W810i Brand:Generic MAPP CXC article: R4CE012 prgCXC1250316_GENERIC_HN MAPP CXC version: R4CE012 Language Package: S_ASIA_LEVAN CDA article: CDA102555/110 CDA version: R2A Default article: cxc1250324 Default version: R4CE012 PROVIDER: 000-00 SIMLOCKS NOT DETECTED USERCODE:0000 RESTORATION FILE NOT PRESENT "R4CE012_CXC1250316_GENERIC_HN" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED Elapsed: 9 secs. I would be greatful if anyone could show me what to do to fix this. Thanks in advance. gpz900ra7. |
11-03-2010, 02:05 | #4 (permalink) |
No Life Poster Join Date: Nov 2008 Location: U.S.A.
Member: 893209 Status: Offline Thanks Meter: 274 | Used v1.01,,, PROCEDURE: >SIGNMODE on SETTINGS TAB >SELECT your MODEL on SE TAB(W810) >PRESS RECOVERY(Used RJ45) >IF RECOVERY SUCESSFULL >GO TO EMPTY FILL TAB >ADD GDFS@EROMS(LOCATE on your SETOOL FOLDER) >FLASH >DONE Br,. Rhyan777 |
11-03-2010, 02:09 | #5 (permalink) |
Member: 1406087 Status: Offline Thanks Meter: 26 | Thing is, I'm only using the box for free usage, and if I upgrade to v1.01 I would then need to buy credits for it. Is there another way to achieve the same results using the version I have got installed on my computer? gpz900ra7. |
11-03-2010, 11:57 | #10 (permalink) |
Member: 1406087 Status: Offline Thanks Meter: 26 | Right, I have downloaded, and installed v1.01, and connected the phone via USB as the phone won't connect using RJ45, this is the log that appeared.... SIGNED MODE (USING SERVER) CFG:100000000000 ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 FLASH ID:2019 OTP: LOCKED:1 CID:49 PAF:1 IMEI:3565740133XXXX CERT:RED FLASH CID:49 COLOR:RED IMEI MISMATCH ! GDFS IMEI:04857555048575 Model (from GDFS):W810i Brand:Generic MAPP CXC article: R4DB005 prgCXC1250316_GENERIC_HN MAPP CXC version: R4DB005 Language Package: S_ASIA_LEVAN CDA article: CDA102555/110 CDA version: R2A Default article: cxc1250324 Default version: R4CE012 PROVIDER: 000-00 SIMLOCKS NOT DETECTED USERCODE:0000 RESTORATION FILE NOT PRESENT "R4DB005_CXC1250316_GENERIC_HN" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED Elapsed: 7 secs. SIGNED MODE (USING SERVER) PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") CFG:100000000000 RESET MODE STARTED ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 PLEASE CONNECT PHONE IN "BOOTROM" MODE Elapsed: 5 secs. Without "SIGNED MODE" this is what appears... CFG:000000000000 ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 FLASH ID:2019 OTP: LOCKED:1 CID:49 PAF:1 IMEI:3565740133XXXX CERT:RED FLASH CID:49 COLOR:RED IMEI MISMATCH ! GDFS IMEI:04857555048575 Model (from GDFS):W810i Brand:Generic MAPP CXC article: R4DB005 prgCXC1250316_GENERIC_HN MAPP CXC version: R4DB005 Language Package: S_ASIA_LEVAN CDA article: CDA102555/110 CDA version: R2A Default article: cxc1250324 Default version: R4CE012 PROVIDER: 000-00 SIMLOCKS NOT DETECTED USERCODE:0000 RESTORATION FILE NOT PRESENT "R4DB005_CXC1250316_GENERIC_HN" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED Elapsed: 7 secs. PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") CFG:000000000000 RECOVERY MODE STARTED ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 can't get packet start. All possible recovery loaders failed. That phone not supported Elapsed: 35 secs. Any ideas guys? gpz900ra7. |
11-03-2010, 22:39 | #11 (permalink) |
Member: 1406087 Status: Offline Thanks Meter: 26 | Here is an update to the W810i saga. I have managed to get some GDFS files that work, and have flashed the phone. It has shown some life, at last, and is busy showing "Please Wait" on the screen. Fingers crossed that it will now work. Many thanks to all of you guys who help me with this problem. gpz900ra7. |
need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 2 | 03-24-2017 16:24 |
need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-26-1999 11:35 |
