10-12-2011, 11:13 | #3 (permalink) |
Product Manager Join Date: Sep 2009 Location: Pakistan Age: 36
Member: 1118710 Status: Offline Sonork: 100.1604414 Thanks Meter: 4,970 | Follow This Step to solve ur Problem Select Proper Modle From List Go to setting Tab & Select these Options 1.Patch OTP <> GDFS Check in Firmware 2. Allow to Change IMEI When Unlocking 3. Finally Press Unlock\Repair Button Try & Post Result. |
10-12-2011, 11:21 | #4 (permalink) |
No Life Poster Join Date: Jul 2010 Location: mindanao L-D-S
Member: 1339214 Status: Offline Thanks Meter: 514 | not done... PHONE STATE: "DEVELOPER" FLASH CID: 0049 skipping empty loader ... FAILED TO SETUP PHONE Unlock FAILED Elapsed: 5 secs. pls idea... Last edited by amar85; 10-12-2011 at 11:30. |
10-12-2011, 11:26 | #5 (permalink) |
No Life Poster Join Date: Dec 2007 Location: Pakistan
Member: 644616 Status: Offline Sonork: 100.1608012 Thanks Meter: 257 | tick sign mode and hit recovery than go to emptyfill tab put gdfs and eerom files hit flash |
The Following User Says Thank You to asifdogar For This Useful Post: |
10-12-2011, 11:28 | #6 (permalink) |
Member: 1118710 Status: Offline Sonork: 100.1604414 Thanks Meter: 4,970 | y u select signed mod option remove this option & then try. |
The Following User Says Thank You to Danish Shafiq For This Useful Post: |
10-12-2011, 11:41 | #8 (permalink) |
Member: 1118710 Status: Offline Sonork: 100.1604414 Thanks Meter: 4,970 | Phone state Nothing Matter this solution is tested by me on many set's on this problem. 2 ways to solve ur Problem brother 1st one Solution i already Posted & second Solution is RESET Method How to Use RESET Method Follow these Step 1. go to emptyboard tab 2. select proper model 3. on settings, check "signed mode" 4. press recovery 5. after successful recovery 6. on settings uncheck all 7. if gdfs totally damaged, add to firmware area proper gdfs in ssw format,otherwise skip that step 8. add to firmware area proper EROM (EROM CID >= OTP CID) 9. press flash 10. if needed,reflash phone on usual semc tab with needed settings. & Post result.. Both Solution is working Solution... |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
